Question about Maytag Chassis Built-In Air Conditioner M7X05F2A
Heat only come on sometimes
We have a thru wall ac/heater,model # mew12w7e Rev-a.Serial # fr673957 164E.Probably right at 5 years old.If and when the heat does come on it only stays on for a short time.
    Sergeant:
    Novelist:
  • 277 Answers
Http://www.applianceaid.com/a-c.html
click the link directly
Posted on Mar 01, 2009
I need to know how the a.c unit works its a old one its a Alaskan MODEL NO.5-P SERIAL NO. 8093422
How it works??? How about what it is not doing?? Takes four years to learn how acs work.
Jul 25, 2017 | Heating & Cooling
Sounds like a truck
If the heater is more then a few years old the heat exchanger is probably corroded. Air flow from the blower motor can't squeeze thru the exchanger fins and causes loud vibrations. It can sometimes be cleaned but usually requires replacement of the heat exchanger. If you are not familiar you should definitely have a professional sevice the unit. Continued use in its current state can cause many other issues. Be prepared because the heat exchanger is the most expensive part of the heater and the most difficult to replace
Jan 10, 2014 | Water Heaters
My 10 year old whirlpool super capacity 456's right front control knob started to burn with flames shooting out. Disconnected plug from wall and have been using lighter to start burners. Any idea as
there's a wiring harness with 4 or sometimes 5 switches depending on the model you have that slides onto the valve so when you turn the knob that burner will light,the switch most likely shorted out.if this is a regular stove with an oven and burners on top look down at the bottom,under the oven door you'll see a draw,open the draw and look on the frame not on the draw on the frame and you'll find a tag with the model and serial number on it,send the model number and i can look up your model.
Nov 20, 2011 | Kitchen Ranges
I have a 5-6yr old Maytag 11kBTU thru-wall AC unit
It should have screws on either side of the plastic part. Take those off and it will take some work to remove it. I cannot find my manual.
May 24, 2010 | Maytag M7Y10F2A Air Conditioner
Weatherking GUW75AD3 How ling is the warranty on the heat exchanger?I cannot find my owner's manual.
5 to 10 years depending on the model you can probably look it up by model and serial number on the wetherking website.
Dec 12, 2009 | Heating & Cooling
I am trying to determine the specs on my Rheem Criterion II lx2000 heating/AC unit unit installed in Sept 99, I blieve it was manufactured 2/5/99 based on AC Pump serial number 6263F259928697 Model RAMB...
rheems site is secure for dealers only but i can tell you. its a 3 ton unit 12 SEER R22 unit. The coil (rcga) is a 3 ton coil The AC is a 1999 and coil 1998. the # you have for the heater is accually just the honeywell gas valve. the model for the heater would be on the inside wall near the gas valve.
Sep 19, 2009 | Heating & Cooling
AC 'squeak'
inside fan blade could be hitting styrofom houseing
Aug 27, 2009 | Fedders A6Y12F2D Thru-Wall/Window Air...
Dyna-glo parts
thermocouples you can buy from any heating spares oulet or national energy a hone well is most common for useing as a replacement
Feb 03, 2009 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Maytag Chassis Built-In Air Conditioner M7X05F2A Logo
115 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
