Question about ECHO, Inc. 20 In. Double Sided Hedge Clipper
DO YOU NEED HEARING PROTECTION?
WHAT IS THE DECIBAL RATIO
    Scholar:
  • 76 Answers
I am not sure of the decible rating but it is recomended that you where eye and ear protection with all power equipment for safety. I do know that the decible rating is high enough to cause hearing damage over time.
Posted on Mar 02, 2009
Hi .. please help ..Can I put deionised water 50/50 with castrol radical blue coolant in my Honda cr125 1994 model
Yes, but 50/50 is not the ideal ratio for maximum freeze/boil protection. See the label for best ratio.
Sep 12, 2014 | Cars & Trucks
Gear ratio rearend
The pining noise you are hearing is detonation in the engine and comes from incorrect air/fuel ratio making the engine run too lean, It is spontaneous combustion occurring before spark and tends to drive the piston back down the bore. It is detrimental to the engine and should be rectified asap. Run fault codes and look for sensor problems. Vin numbers are unlikely to show the gear ratio of the rear end as there are 4 ratios for each model of car. Jack up on side of the rear . count the number of turns the pinion does for each revolution of the wheel . Divide that by 2 ( side gears in diff carrier multiply by 2 when driving one wheel)and you will get the ratio. So 10 revolutions of the tire gives 35.5. revolutions at the pinion equals to 17.5 or a ratio of 1.75: 1 ratio
Oct 06, 2013 | GMC Cars & Trucks
What can be done to prevent hearing loss?
The hearing problem should not be ignored otherwise you may have to face its consequence at a later stage. I would suggest you an online site that offers the best health advice. More than 200 expert professionals are dedicated to providing the qualitative facility. They are also expert in Wahrsagen that means you are able to know your future events in a far better way.
Oct 05, 2013 | Health & Beauty
Center channel is too quiet for dialogue from PS3 movies
turn the other speaker decibal levels down then increse main volume until you are satisfied.
Feb 06, 2010 | Denon AVR-1907 Receiver
What is oil to gas ratio? What type of oil what type of gas/
A mixture of 40:1 would give good performance and protection with minimal smoke issues.
3.2 ounces of oil added to 1 gallon of gas would equal a 40:1 ratio.
Don't use outboard motor oil. Water cooled engines on those.Use a 2-Cycle oil specific to AIR COOLED engines.
Hope this hepls!
Sep 26, 2009 | Poulan Featherlite Gas Blower, with Low...
I need to acid wash my grids. What is the ratio for acid and water?
Why not try white vinegar and water first, 50/50 mix. White vinegar is a mild acid, and it is a lot safer to use than acid. If you are going to use Muriatic acid ( "mild" version of Hydrochloric acid), then a good ratio is 1 part acid to 20 parts water. And Always add the acid to the water. You could make a stronger solution, 1part acid to 10 parts water, if needed. But be cautious with any ratio. Follow container directions. Wear eye protection ( an absolute must). Wear gloves, etc. This is dangerous stuff, and you can buy it at Home Depot or Lowes!
Aug 25, 2009 | Pentair FILTER TANK BOTTOM, 48 SQFT
Anyone know the ratio for dilution of 1990 van coolant?
Mix at 50/ 50 for best result and protection will give -30degC freeze protection
Mar 11, 2009 | 1990 Mitsubishi Minivan
ECHO, Inc. 20 In. Double Sided Hedge Clipper Logo
70 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
