Question about Dell Dimension 4600 PC Desktop
Computer only displays vertical lines and pink background.
Immediately upon boot vertical lines appear on my monitor screen. After serveral minutes the screen becomes pink. and the windowws cursor appears. thats as far as the computer goes. I attempted to use the recovery disk supplied with the computer, but had no result.
    Sniper:
  • 55 Answers
Most likely an issue with the Video Card or Video driver.
* Boot to safe mode by tapping F8 while starting up the computer. Selected safe mode with the keyboard and hit enter. Login to your user account. You should see the words “Safe Mode” on all four corners,
* Open device manager – Right click “My Computer” – Select “Manage” – Selected device manager from the left. Under display driver, you should see your vide card listed. Right click on it and select “Disable”.
Now restart your computer and if this resolves the issue, then the vide card may be at fault. You could also try updating the video driver.
Do let me know if you get this far.
Posted on Mar 02, 2009
Computer will not boot to normal and verticle lines on monitor, dell XPS410, windows vista 32 bit
Unplug the monitor video cable from the computer. Power on the monitor and see if you get the same results. If so then your monitor is defective.
Oct 11, 2012 | Dell Computers & Internet
Screen is white with black vertical lines upon booting up. I can't get beyond this screen.
The video card (built-in on the motherboard) maybe faulty or the LCD screen is faulty.
Connect an external monitor to the video port of your laptop, power up the monitor first then boot up your laptop. If the video card id OK then the laptop will automatically divert the video to the external monitor. Then the problem is a faulty LCD screen.
If the external monitor also displays black vertical lines then you have a faulty video card and since it is part of the motherboard it is impossible to fix.
Feb 11, 2012 | Acer Aspire One Netbook 8.9" Notebook
Sony vaio laptop screen shows vertical lines upon booting then proceeds to windows loading with semi transparent vertical bars on background. Upon logging in, screen displays everything in a large scale...
the screen inverter is on its way out simple to replace unscrew the rim on the outside of the screen pull it off gently at the bottom there is a stip with wire going into it at each end disconnect it remove it do the reverse to put it in i suggest ebay for spares
Feb 11, 2012 | Sony Computers & Internet
A vertical line has appeared just off of the center of the screen. I have unplugged turned off reset and changed the background but the line stayed.
The vertical lines means you have failing T-CON board, part of the LCD panel assembly, it will get worst, new LCD panel will be needed. Westinghouse uses cheaply made screen like CheiMai, not LG/Philips.
http://s807.photobucket.com/home/budm/allalbums
May 19, 2010 | Westinghouse L1975NW Monitor
Monitor is only showing vertical/horizontal gray/white screen
Your video card has fried unfortunately. If you are familiar with the internal workings of a PC you can open it up and check the power cells on the video card itself, they will usually show signs of damage such as cracking etc. I would have a qualified professional take a look at it. I would recommend www.tigerdirect.com as a starting place for finding a new one
Apr 14, 2010 | Acer AL1715 17" LCD Monitor
Monitor screen with pink line
While I've never seen the stripe be pink, it's not impossible for it to appear that color. Your monitor is bad, and isn't easily or cheaply fixed.
Apr 30, 2009 | Computers & Internet
Display has gone bad with fine vertical pink lines
Connect an external monitor to your laptop, if you get a clear image on this monitor the the video card in the laptop is OK.
The fault could be a defective inverter that supplies high voltage to the CCFL lamp or a faulty CCFL lamp. Most likely a faulty CCFL lamp.
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) as reached the end of the life and all you need to do is replacing the CCFL lamp
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 06, 2009 | Toshiba Satellite 5205-S703 Notebook
Immediately upon boot, vertical lines appear on screen. After several minutes the screen turns pick and the windows cursor appears. there is no further change in the display. Mouse appears to work. Not...
My first check would be video drivers if this is a newly built computer. If it is a computer that has been running a while and the problem suddenly appeared I would reseat the RAM and attempt to boot into safe mode, suspecting a virus infection.
Mar 01, 2009 | HP Computers & Internet
A pink vertical line appears suddenly on the screen
Sounds like a hardware problem. You should probably return it as soon as possible.
Dec 19, 2008 | Sony VAIO® VGN-AR370N12 PC Notebook
i have a samsung 15inch monitor.which is only 6month old.giving blue vertical line along the right side of monitor (almost 2 inches from right side) how to remove it plz someone help me.my mail id is kakhilesh83@yahoo.com.thank you..
Apr 09, 2007 | Samsung SyncMaster 740N 17" LCD Monitor
Dell Dimension 4600 PC Desktop Logo
416 people viewed this question
Alun Cox
