Question about Compaq Computers & Internet
How to connect to external monitor?
Hi all. I turned on my monitor, heard a 'boom' sound, and the monitor went black. Tried pressing the off button and turning it on again, didn't work. Is this probably a problem with the monitor?
Rather than spending money on repairing the monitor, I'm thinking of buying a cheap external monitor. Any recommendations?
Also how do I hook it up (since the laptop monitor is dead)?
  • 1 more comment
  • spectrumvoid Mar 02, 2009
    I don't have a multilmeter, but the sound came from the laptop monitor. The LED lights up (the yellowish-green ones). I hear some whirring noises when I hit the power button. It doesn't sound 'normal', the fan seems to be a bit louder than normal but I'm not really sure because I didn't pay attention when the laptop was functioning.
    Thanks very much.
    I forgot to add: my laptop is a compaq presario V2000.
    ok got it. Thanks!
  • Compaq Master
  • 32,281 Answers
You need to determine the fault first.
Can you determine exactly where the boom came from (the adapter or laptop)?
When you turn on your laptop does the LED lights indicating that there is power to the laptop and you can hear the hard drive spinning as well as the fan?
Do you know the power adapter is OK (you can test it with a multimeter)?
If the laptop is dead then the external monitor is of no use.
The laptop normally has a blue video output connector, usually on the back edge of the laptop where you can connect an external monitor or a data projector. When a monitor or projector is powered up first and then the laptop the display goes to the external video first. You can switch between the laptop screen and external video by clicking the blue Fn + F4 function keys.
Posted on Mar 02, 2009
  • Chris Hingee
    Chris Hingee Mar 02, 2009
    If the LEDs are showing then you have power from the adapter, so you don't need to test it.
    The next step is to borrow a monitor to see if you can get a display on the monitor.
Hp g60t went into hibernation last friday it wouldn't come out of hibernation so i had to hold in the power button and shut down. laptop turns on but no video now the screen stays black. i tried a reset...
This issue could be due to presence of static charges or internal hardware malfunction of the notebook. To isolate the exact cause of the issue, perform the steps provided below.
Step 1: Hard Reset
To perform a hard reset, please follow the steps listed below:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
This will discharge the static charges from the notebook. Now turn on the notebook and check for the issue. If the issue persists, then remove and reseat the memory modules of the notebook and check for the issue.
Step 2: Remove and Reseat the Memory Modules
You can refer the service manual provided below for information to remove and reseat the memory modules of the notebook.
http://h10032.www1.hp.com/ctg/Manual/c01602064.pdf
Refer page no: 52 & 53
NOTE: PDF manuals require the Adobe Acrobat Reader for viewing and printing.
Further, if the issue persists after performing the above steps, then the issue could be due to hardware malfunction of the video card or defective LCD display screen of the notebook. Hence, I recommend you to connect an external monitor to the notebook and then check whether the display works fine on external monitor or not.
Step 3: External Monitor
You can follow the steps listed below to connect an external monitor to the notebook.
1. Turn off the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
At this time, please follow the instructions mentioned below for switching the display to the external monitor:
The notebook's video card supports three modes. Built-in screen only; external video only; and both on simultaneously (mirrored). If you're not seeing the image on the desired device(s), the notebook's video card is probably in another mode. Press FN + F4 to cycle through the display options: Notebook display, External monitor, both.
If you press FN + F4 once, the external monitor will display & there will be no Notebook LCD display.
If you press FN + F4 twice, the external monitor will display & there will be some shading on the Notebook LCD.
If you press FN + F4 thrice, both Notebook LCD & external monitor will display.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook. In either cases, the notebook requires a detailed onsite diagnosis by a service technician.
I believe the information provided would be helpful to isolate the issue with your notebook.
Jun 07, 2010 | HP G60t Notebook
My hp dv4-1435dx screen is blank.It was on then it froze and then went blank. I have tried to fix it by removing the battery and replacing it a number of times. It comes on when started and plays the...
This could be due to presence of static charges on the notebook or hardware malfunction of the video card or defective LCD display screen of the notebook. To resolve the issue, perform the following steps.
Step 1: Hard Reset
This will discharge the static charges from the notebook. Now check if the display works fine or not. Incase, if the issue persists, then the video card or LCD screen must have gone bad, and to isolate the same, please connect an external monitor to the notebook and check for the display on it. You can follow the steps below to connect an external monitor to the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear/side of the computer.
If your notebook is under HP warranty, then contact HP to get the notebook repaired for free of cost.
Jun 01, 2010 | HP Pavilion dv4000 Notebook
No picture on monitor (monitor turns itself off)
You will need to take it for repairs.
Sorry
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 23, 2010 | Dell E773C 17" CRT Monitor
When I turn on my laptop it goes on but the screen is black and it seems locked up. Tried control, alt, delete and turning off and on but nothing works.
in stead of alt crtl del try pressing F8 key on keyboard after you turn it on, it will display a few options. go from thee.
in case it does not stars, you may have a faulty memory ram. it needs to be replaced
Oct 07, 2009 | Computers & Internet
Dell E171FP Monitor goes black after 2 secs
Hi, I don't think the problem is with your monitor. Your monitor sounds like it's doing exactly what it's supposed to do. The monitor is supposed to turn off if there's no cable attached, which means there's no signal input. When the screen goes black, does the power light stay on and turn orange? or does it go off as well? I would recommend that you lower your screen resolution to 1280x1024 or lower in the Display Properties window, then remove your primary monitor, and connect the monitor to your desktop computer. You should see it light up when connected. The monitor auto-senses when there's a computer attached to the cable and when there's a signal. If it doesn't see a signal, it goes black to save power.
Jun 17, 2009 | Dell E171FP 17" Flat Panel LCD Monitor
Moniter went black, power button flashes yellow
it sounds like a capacitor blew from the inverter board.. if u can open it it should be obvious which one the messed up..
May 04, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Monitor screen stays black even though it's on
Remove the memory from your unit - power it up it should beep if full communication is still happening across your m/board. No beeps you board has died. if it beeps and your using two diffent memory modules just fitt one leave the battery out and power it up = if no display pull power swap out the memory and try again. if display occurrs you have a defective memory module - throw that failed unit away
glenn
Mar 07, 2009 | Compaq Computers & Internet
Laptop won't boot up properly
Connect your computers to an external monitor and press the appropriate F key combination (Shift + F7) to switch video output to the monitor. If you see an image on your monitor you have a bad LCD screen or back light inverter. If not you need a new motherboard. Guy that gets ticks, you need a new motherboard anyway.
Feb 18, 2009 | Acer Aspire 9300 Notebook
LCD Problems HP Pavilion DV2000
It sounds like your backlight in the LCD screen has died. However your system should work with an external monitor. When you connected up the monitor to the VGA connector did you change the settings on the system to output to the VGA output ?
Try connecting the monitor before the computer is turned on - then once booted hold the Fn key and press F7. Then pause then press Fn and F7 again to see if you can get the external screen to show your screen. It sounds like a dead back light though.
Aug 22, 2008 | IBM ThinkPad T23 2647 Notebook
Computers & Internet Logo
313 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
