Question about Fisher and Paykel (IWL12)
Inside the dryer
The white piece inside the dryer that suppose to turn the clothes around will not turn anymore. It has been like this every since we washed clothes and there were crayons in someone pockets. Is there a way I can take that out or make it turn again?
  • 277 Answers
click the link directly.
Posted on Mar 01, 2009
Forgot to put the lint trap back into LG Ventless Dryer DLEC855W. Clothing might have gotten stuck inside. Dryer now making grinding noise and drum is moving slowly. Is it time to call a repairman?
The filter simply allows the dryer air to pass through and trap the lint so it will not collect in the exit tube or on the outer vent parts. If anything, the clothes inside the bin will just spin around and be there when you finish. The noise inside the dryer could be from something that was in the pant or shirt pocket and was floating around.
Mar 01, 2014 | LG Electronics DLEC855W Electric Dryer...
I have a frigidaire dryer model#FEQB2152FEO. A big white plastic piece broke off around the inside front. It looks white and circular and it seems like it was maybe a seal or ring around the drum?
did you ever get a solution for your problem with your dryer? i have same frigidaire dryer model number and the plastic ring on the front inside just broke off in mine last week and im not sure what to do to fix it.
Apr 11, 2010 | Frigidaire Dryers
Clothes get caught between the drum and the front of the inside nonmovable part of the dryer and we are getting snags of the clothing inside and ruining the clothes
there is suppose to be a felt type piece that goes on the drum to full that gap it may have fell off . its a struggle to put on unless the drum is accessible. you can pop the top of the machine off to get better access.
Aug 23, 2009 | GE DBXR463EDWW Electric Dryer
Dryer wont turn inside but gets hot and turns on
If it's not turning at all, the belt is probably broken. If it turns a little and then stops, the belt is slipping. In either case, the belt needs to be replaced.
May 11, 2009 | Dryers
Inside of dryer is turning blue. How do I clean it? My clothes do not seem to be affected by whites are staying white...but I can't figure out what to do about this.
My best guess, is it is your blue jeans. fingernail polish remover..non acetone usually does the job. Stay in a well ventillated area when doing this. Good luck.
Apr 20, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer makes alot of noise when drying clothes.
First you will have to locate the two screws inside the dryer. Open the door and look up inside the trim around the opening of the dryer. Take them out then the top of the dryer will come right out. Look at the very from of the dryer. There should be 4 small "slides" attached to a trim piece. If there are any missing that is probably your problem. I just went through this problem. The pieces each are no longer than an 2" each but cost almost 8.00 a piece. They are easy to replace though. You might also have to replace the whole trim piece as I did because it was completely worn out. Very easy to replace.
Jan 13, 2009 | GE DWXR483EBCC Electric Dryer
maybe you have high iron content in your water?? if so theres a product called iron out. supposedly it works well. good luck
May 23, 2017 | Kenmore Dryers
Frigidaire crown series dryer
The back of the drum has a hub (a flat steel piece with a shaft and ball) which allows the drum to turn. That ball rides in a plastic "cradle". Unfortunately on the crown series...if the ball and cradle are not greased regularly, the plastic wears. This allows the drum to "sag". The front end of the drum is lower than the back. You can confirm this by running your finger around the front of the drum. You'll notice that the top of the drum is almost flush with the body of the dryer and the bottom of the drum is 3/4 of an inch lower that the the body. This allows clothes to slip into the gap at the bottom and then they are spen to the top pof the drum were the lodge between the body and the top of the drum. The turning drum burns the clothing. Replace the plastic piece that the hub rides in.
Dec 28, 2007 | Washing Machines
A dark residue inside of dryer
Sounds like an ink pen was left in the clothing during wash and leaked out when put in the dryer
Oct 21, 2007 | Maytag HYE3658AY Electric Dryer
Dryer putting black smears on clothes
The white plastic pieces just inside the font of the drum are the front bearings there are aboutfour of these, you will need to take the front of the machine to put them in, your clothes are probably picking up black smeres from where the plastis bearings have worn.
Oct 18, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
