Question about JVC KDAVX44 Car DVD Player
I put my unit in my 2003 honda civic ex and the tail lights quit.
I installed the untit in my car and the tail lights stopped working. i am not sure if the grounds tie into its ground. i was told that it might be the problem.... any inputs?
  • loungelizzar Mar 02, 2009
    Thanks man. i am going to try that but i am also tyhinking that it might be a bad ground because the system is alot bigger than the origional head unit... i am thinking that the dimmer switch in not getting a good ground and it might be tracing back into the lights and stuff. i will try it all.
    Novelist:
  • 149 Answers
I would Put the origanal stereo back in to the car to check to see if the problem still presists. If so you may want to check you fuses. I know at times when hooking up a system we do end up popping a few fuses, not on purpose but it does happen. Just check those two things and you may find your problem. Also you might want to put new light bulbs in too so you know that you have known good bulbs.
Posted on Mar 01, 2009
My dash lights and tail lights quit working in my honda accord ex 2001 fuses are good help
Do you have an aftermarket sound system installed, that is the problem, it causes a failure in the light control unit.
Oct 18, 2016 | 2001 Honda Accord 3.0 EX
2000 civic ex change ignition
Fix your car right away, by clicking the link
1996 2000 HONDA CIVIC REPAIR MANUAL
Jun 07, 2016 | 2000 Honda Civic
No dash lights or tail lights on my 1994 honda accord ex
I have right now the same problem. I just pulled the fancy/shmancy radio head out of my (Honda) 1992 Acura Integra and the whole dash is now a mess. It had been professionally installed. The dome light now doesn't work, the "door open" warning lights stay on, the clock is messed up, etc.
I installed the fancy head in another car, in a 1992 Honda Civic. That works perfectly. Sounds like you need to find a professional installer to re-do your new head.
I think the dash lights and the taillights are on the same circuit/fuse.
Jan 01, 2013 | 1994 Honda Accord
Are 00 Honda civic tail lights compatible with 99 Honda civic.
As long as it is the same body style (ex. 2 door) they will interchange from 98-00
Mar 11, 2011 | 1999 Honda Civic
How do I replace tail light assembly on 2001 Honda Civic EX coupe?
To remove the tail light assembly to be replaced, you need to access the fasteners from inside the trunk.
Remove the black plastic retainers holding the trunk liner in place on the side you wish to replace. Once you have removed the retainers, peel back the trunk liner in the area you will be working on. Disconnect the light bulb sockets (be careful not to break any bulbs). The tail light assembly itself is held in place by 4 - 8mm nuts on the bolts that protrude about 1/2". An 8 mm deep well socket works well, but an open-end wrench will do the same job, just slower. Some of these also hold the wiring in place, so take note of where everthing goes. To put it all back together, just reverse the process.
Jul 28, 2010 | 2001 Honda Civic
The left one quit working about 6 weeks ago today
Hello! a device called the Tail Light Relay; Located in the under dash fuse/relay box is the likely culprit...It controls the left/right brake lights but not the middle brake light...Also check that the L/R brake lights have a solid ground...Use an ohm meter...Zero ohms to negative battery terminal...
Guru........saailer
Apr 30, 2010 | Pyle Pl1157rd Led Brake Lights Light Bulbs...
Overheats once in a wile no codes on scanner.
I have a 2002 Honda Civic Ex, it has been over heating but only in stop and go traffic, never on the freeway, i have replaced, timing belt, water pump, cooling fan relay, cooling fan switch, flushed radiator. There is no white smoke coming from the tail pipe and the oil is clean, when the car gets hot i can smell the coolant pretty strong, car has never completly overheated gets about 3/4 of the way til red.
Jul 01, 2009 | 2003 Honda Civic
2004 honda civic ex
this doesnt make any sense what swiych are the talking about it should be on your bill what it is
Nov 04, 2008 | 2003 Honda Civic
JVC KDAVX44 Car DVD Player Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
