Question about Viking VEDV1200 Kitchen Hood
Viking VEDV1200 fan not spinning
How do you remove the fan from the motor to replace the bushings on a Viking VEDV1200 external fan or do you remove the whole housing?
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
Oven and works but fan not working bush ad66tb
The fan could be greasy and "stuck", you'd have to take it out to check.
Unfortunately replacement fans are quite expensive:
Bush AD66TB Fan Motor 230V 23W Cl
Jul 15, 2016 | Ovens
Holmes HTF 3409 AR Tower Fan Will Not Turn On
We bought one from our neighbors in a garage sale that did NOTHING when turned on. If you attempt to turn the fan on and you cannot feel, or hear, it make any kind of humming sound, mostly likely the thermal fuse in the motor is open. An ohms check of the windings will reveal an open fuse. Probably 99.99% of all people will have to thrown their fans away at that point as it would be too costly to have it repaired as the fuse was never intended to be replaced. As an electronics tech for 40 years I am cheap enough and experienced enough to be able to find the fuse and replace it, albeit it can be a little tricky. The reason the fuse blew (opened) is because the shaft that the fan spins about was gunked up from years of accumulating dust, etc. The lubricant that is suppose to let the bushings (no bearings, just two bushings; one on the top and one on the bottom) spin freely gets guey over the years and slows the fan down and it can't spin freely anymore. That causes the motor to overheat trying to get the fan to spin. The overheated motor in turn blows the fuse to prevent a fire. SO, if you can catch the problem before it gets to the point to blowing the fuse you can salvage your fan and get a lot more years of normal use out of it. If you notice your fan running slowly, or if it doesn't coast for a little while when you turn it off (it stops fast or suddenly) or if you stick something through the air fins in the front cover (WITH THE POWER DISCONNECTED) and attempt to spin the motor but it doesn't spin freely, then the bushings are drying up and the motor is about to blow open the motor thermal fuse. If you can find a friend who is handy they can disassemble the fan fairly easily and relub the bushings. Otherwise, it's dumpster material.
Aug 06, 2012 | Holmes Products HT40RCL-U Tower Fan
NuTone LS100 fan is squiling when it runs. Spinning the fan blade by hand when it isn't running doesn't make any noise. Am I correct in thinking that the motor needs to be replaced?
Sounds like it may actually be the bushing pack inside if the motor. Spinning the blade by hand is not going to spin it fast enough to hear the problem. If the unit is new, I would recommend returning it for exchange of a new unit. If it more than 1yr old, it's out of warranty and will be cheaper to just replace it rather than repairing it.
For less than $100 you can buy a newer, more efficient model. Depending on the size of the room is how should judge what unit to buy. An under sized unit will not pretty much nothing, except make noise and remove some of the steam. Remember to buy a fan with the lowest SONE rating as it will have the highest quality motor housing and best air removal.
Keith
Feb 28, 2011 | Broan-NuTone N-LS100 Exhaust Fan Exhaust...
Fan does not come on
This will take some work, and some elbow grease, but what happened is the motor bushings most likely seized. Try turning the blades with your hand. If they are stiff, the bushings are seized. What you will have to do is take the fan apart. First by removing the blades, then by taking the motor off of the frame. Then depending on the type of bolts/ screws that hold the motor together, remove them. Then split the motor apart by taking a flat blade screwdriver and sliping it between the two pieces of the motor and turning it so they slip apart. then once the motor is apart, shine up and clean the motor's shaft so it is clcan and shiny. then do the same for the bushing/ beringholes in the motor's casing. then drip some oil in the berings, and on the motor shaft, and put the motor back together. then put it back on the frame, and plug the fan in. turn it on. the shaft should just spin without any help. if this does spin, put the blades back on, and put the guard back on. Then you sucessfully rebuilt the motor and the fan!
Aug 12, 2010 | Lakewood High-Velocity Fan
Reddy Heater 110K btu motor won't start.
Bearing have gone bad in the electric motor. You will have to replace the electric motor. They are expensive but still cheaper than buying a whole new heater.
Jan 05, 2010 | Reddy HEATER RH125T 125,000-BTU...
Model # yg2047b. I had this fan installed in June, worked fine,now it hums..what could the problem be?
If the fan does not spin and the motor hums, you have a stuck rotor. It may be due to bushing/bearing alignment problem or a lubrication problem.
Try to spin the fan blade manually. It should turn freely, otherwise the rotor is stuck. Remove fan blade and put few drops of lubricating oil on the bushings/bearings and manually turn the shaft to free it up. Alignment of shaft and bushings/bearings must be after lubrication is done and the rotor is still stuck. Move the shaft up and down and side to side until it smoothly spin when manually turned.
Aug 30, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Fan makes a whining noise as though it is struggling to turn
Check the bushings for alignment and lubrication. Dried accumulated dirt makes the rotor stuck and hard to turn. If this is the case, remove the oscillation gear assembly at the back of the motor. Lubricate the front and rear bushings while manually turning the fan to loosen it. Do it until the fan smoothly spins. You can use engine oil as lubricant or even cooking oil but don't let it flood the motor assembly.
If the fan smoothly spins when manually turned but still makes a whining noise when plugged and switched on, align the bushings.until desired result is obtained.
Note: These procedures are based on my actual experience and makes a perfect result. Extra effort is the only investment.
Aug 20, 2009 | Schaefer Outfitters Dryers
Fan motor
Most likely a lubrication problem. These motors can easily become "gummed up" from use. I normally would remove the motor and hold it with the shaft vertical, I would then apply a few drops or 3in1 motor oil just above the bushing (bearing) and allow gravity to move the oil into the bushing while turning the motor by hand. I would flip the motor over and do the same to the other bushing. This motor should spin quite freely. Do not over oil. once the motor is spinning freely, wipe any excess oil from motor and reassemble and test.
Let me know what you find
clarkco
Feb 12, 2009 | Ecoquest Flair Air Purifier
Clothes dryer ran ok an hour ago - not now
you may have a bushing problem on the drive motor due to dirt or flint. you can check that by removing the belt and try rotating the motor manually. see if it is easy to turn or not.check also the bushing if you can move the shaft sideways..if it has a slack then its a bushing problem. replace the drive motor.
Feb 03, 2008 | Dryers
Viking VEDV1200 Kitchen Hood Logo
88 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
