Question about Kwikset 907 907-15 Satin Nickel Smart Code Smart Code Deadbolt with One Tou
Need to have a master key for all locksets
Have multiple locksets need one key to fit all
  • 672 Answers
Any locksmith can rekey the locks to a single Master. Some make house calls, but it costs less to take them off and take them if this is feasible.
Posted on Sep 27, 2009
Remove key beeper location please
Sounds more like you need to replace the key lockset. To remove the lockset, you have to have access to it first. Once in there, turn the key to the run position. You will find a slot/hole to push a pin into it and pull the lockset out.
May 21, 2016 | Cars & Trucks
I am a realtor and cannot open the 5400d master lock
you will need to cut it off.or remove the door knob on the lockset.
Oct 25, 2013 | Master Lock 5400d: Portable Select Access...
Reset security system
You'll have to get the ignition key and lockset from the old column and put it in the new. Theres a chip on top of the lockset that is encoded with the security system. You can do a key relearn, but you have to have the original chip.
Jun 05, 2013 | 2000 Chevrolet Cavalier
How do you key alike locksets
Frequently, you can purchase pared entry sets at the Ace Hardware or other fine retail hardware store ... or they can be special ordered for you if you need more than two. My preference is to support the local hardware store ... however, you should know that some of the so called BIG BOX stores can do this service for you for a fee. And of course, the lock smith in your town can perform all kinds of magic with your locks, like creating a Master Key system. One key for you roe everything, a different key for the milk man and cleaning lady, a individual key for every bedroom and closet, special key for the garage and shed etc.
Thanks for your question.
Feb 03, 2011 | Kwikset Professional Door Lock...
The Yale lock on my Front door in becoming increasingly difficult to open with the right key. I'm worrie dthat one day soon I wont beable to open it at all. What is wrong with the lock? Could I use...
Yes I would useWD-40 to spray in lock. Insert key part way in lock and spray a small amount on key and into lockset if tou can, If you can fit spray nozzle into keyhole ,and spray liberally. You can also use dry graphite to lube lock mechanism. I would check to make sure that your keys aren't bent or worn to the point that I hope this helps you. Thanks they can't engage all tumblers inside lockset. I would also make sure that latch on lock is lining up with strike plate in door frame. One easy way to do this is to use a felt tip marker to cover strike plate on door frame and open and close door several times. Where ink from marker is rubbed off will show you where latch is contacting strike plate. If it is out of aligmment this will make it harder to open or lock with key. If necessary adjust strike plate for better fit. I hope this helps you. Thanks
Nov 17, 2010 | Garden
I have a 1991 300e merecedes and i drove it all week no problem now i cannot get the key to turn in the ignition i tried moving the steering wheel jiggling the shifter and moving the key around even...
when locksets start wearing out sometimes the key will only start the car with a certain side up. also you can try tapping the key when it is in and see if that works. It's probably time for a new lockset and key
Jun 17, 2010 | 1990 Mercedes-Benz Mercedes Benz Sl Class
Cannot remove an old schlage door knob. There is a small hole on the underside of each handle. What do I need to do to get the handles off? I don't know name or item # but the page makes me choose one.
It is a small allen key (hex head) that comes with the lockset when purchased. They are just threaded into the handle (knob) and sets into a reset when threaded in. You can take some putty and push it into the hole and gently remove to make a negative imprint of the allen key, go to a local home center like Lowes or H. Depot and match it up. You can buy a set of allen keys that are like a pocket knife with multiple allen keys. Note, it is very thin. An alternative is to purchase another similar Schlage lockset, open carefully, use the key, and return the lockset saying it is the wrong one. Not nice to do, but in this economy every penny counts. I hope this helps and good luck.
Oct 24, 2009 | Schlage BE365-CAM BE365CAM505 Lifetime...
2009 G6 keys stolen. can i lock out the electronic
You can take a new transponder key(s) (dealer issue for current lockset) and remote(s) (ebay) to the dealer for a complete reprogram. Whomever stole your original will still be able to get in your car, but will not defeat the alarm system nor be able to start the car. The alternative is to replace the locksets as well and nobody has the cash for that.
Sep 13, 2009 | 2006 Pontiac G6
Constant beeping
It sounds like the lock master reset might have been inadvertantly pushed when the coverplate was removed at some point. I would suggest you remove the batteries, reinstall them and reset the lockset and enter in new pass codes (you can use the same ones as before, if you wish).
I've attached the owner's manual, just in case you've misplaced yours, so you can reprogram the lockset and have the instructions for future use and reference.
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Just so you know, Weiser and Kwikset were once the same company and offerred the same lock under both names, so don't worry about the manual having the Weiser brand name on it.
Hope you find this Very Helpful - Best regards!
Aug 18, 2009 | Kwikset 907 907-L03 Lifetime Polished...
Weiser combination lock for front door
You can reset the lockset to change the master code and then enter in other codes for use by contractors, delivery people, etc. which you can then delete as you wish without having to give out the master code.
Rather than give you the simple step-by-step instructions for resetting the lockset, I've provided a link to the user manual so you can have it available for use and reference, as I assumed you didn't have yours any longer.
Hope you find this Very Helpful and best regards!
May 17, 2009 | Weiser Lock POWERBOLT ELEC DEADBOLT
Kwikset 907  907-15 Satin Nickel Smart Code Smart Code Deadbolt with One Tou Logo
194 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
