Question about Equipex PZ-330 Electric Single Oven
Electric oven element over-heating/thermostat light stays on
I have a Baumatic electric oven to which I have just replaced the broken element as it was not heating up anymore. Unfortunately, after switching the oven back on, I notice that the element keeps overheating, becoming incandescent and the RED thermostat light stays on and fails to regulate it. Before switching the oven off I checked if the thermostat light would go off by lowering from 250 to 75, but the red light stayed on. Can someone help me determine if the original spark that damaged the element I changed in the first place, as maybe also damadge the thermostat.. what I should do now? I don't feel safe using the over as it is now. any suggestions.. many thanks
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: electric fan oven overheating
It sounds like the thermostat is faulty, make sure the sensor is not detached inside the oven compartment, as this will affect the thermostatI if it is. If o/k, then the only option is to replace the thermostat. If it is fan assisted, then make sure the fan is working o/k as well.
Please leave a rating for my comments.
Thganks.
Posted on Mar 02, 2009
Why has baumatic B501SS oven covered in light gray coating inside when heated, now not working
It sound like the heating element burned out. Check the element and see if there is a burned spot or blister somewhere along the element. If so the element will need replacing.
May 03, 2014 | Baumatic B180 Electric Single Oven
Electric oven dont work
sounds like the heating element, also check the thermostat
Apr 06, 2010 | Baumatic B180 Electric Single Oven
My Baumatic B180W-B oven does not heat up. The
If the oven is electrically heated, then more than likely, the oven element has failed.
This is located behind a removeable cover at the rear of the oven.
Feb 21, 2010 | Baumatic B187 Electric Single Oven
Thermastat or element ?
Could be both parts are faulty from symptoms you describe.
The indicator light should not be on if it is in the off position, this would suggest the thermostat is faulty.
On the other hand, if the element is faulty, then obviously, there will be no heat
To be certain if the element is faulty or not, then you need to test the element with a meter.
Jan 20, 2010 | Baumatic B180 Electric Single Oven
Electric fan oven overheating
Thganks.
Mar 01, 2009 | Equipex PZ-330 Electric Single Oven
Baumatic B501SS Built In Stainless steel electric single oven
If the fan is working in the main oven and there is no heat, then it will be a faulty element.
Remove the cover at rear of oven
and you will see the round element. remove it and replace with new one.
Plz rate my solution .
Thanks.
Jan 17, 2009 | Baumatic B180 Electric Single Oven
Beaumatic B151SS Single Oven Problem
Disconnect the element, and run the oven for at least 30 mins,,if it does not blow fuse, then more than likely it is a faulty element.
What I cannot understand is that you say the thermostat light is on after the fues has blown? I would have thought that the light would be not be on, if the fuse has blown.
If after replacing fuse and the stat is in the off position, and the indicator light is on then indeed the stat is faulty.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Baumatic B151 Electric Single Oven
Oven not heating up but fan and light on
oven not heating up but light coming on fan working and grill working . it allso heats up on other settings but not enough to cook
Jul 04, 2008 | Baumatic B187 Stainless Steel Electric...
Oven fault code
I think your thermostat is broken, try replacing it with a new one.
Oct 15, 2006 | Baumatic B205SS Stainless Steel Electric...
Equipex PZ-330 Electric Single Oven Logo
226 people viewed this question
Top Equipex Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Equipex Oven Expert? Answer questions, earn points and help others
