Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Purity disturbance how can you identify purity problems and what could be the cause
  • 125 Answers
If the color is missaligned means your tv is having convergence problems and you will need to replace some parts inside the tv
Posted on Mar 02, 2009
I want to delete fb purity and restore fb to what it was prior to installation
The link to the uninstall instructions for FB Purity is actually on the install page itself
htttp://install.fbpurity.com
or you can just go straight to http://faq.fbpurity.com/#uninstall
for the uninstall instructions
Jul 19, 2016 | Computers & Internet
Why is my picture green on my tv?
The screen colors are all derived from three distinct colors. Red, Blue and Green. The colors can change due to a few problems. The purity or converge could have been disturbed due to magnetic interference, one or two of the color amplifiers have stopped working or the picture tube has failed. Color problems can be as easy as circling a high magnetic field coil in front of the set, known as 'degaussing' or extremely technical, frustrating and then hence expensive.
Jul 13, 2014 | ESA Televison & Video
The picture is green ?
The screen colors are all derived from three distinct colors. Red, Blue and Green. The colors can change due to a few problems. The purity or converge could have been disturbed due to magnetic interference, one or two of the color amplifiers have stopped working or the picture tube has failed. Color problems can be as easy as circling a high magnetic field coil in front of the set, known as 'degaussing' or extremely technical, frustrating and then hence expensive. Not much help, I know, but good luck.
Jul 13, 2014 | ESA ET427E 27" TV
Can you use auto air conditioning R134a to fill the unit?
Different connections but this is the same freon.
Good Luck
Mar 21, 2013 | Sub-Zero 650 / O Bottom Freezer...
How do i fix a crooked screen on an older tube t.v.?
The yoke needs to be turned slightly and the picture will move in the same direction as you rotate the Yoke. (located on the neck of the Picture Tube) Just loosen the screw on the yokes clamp slightly then carefully touch only plastic edge of the yoke and turn it slightly while an assistance watches the picture be careful not to slide the yoke up hugher or lower on the neck. It has to saty at the same spot but just rotated slightly.The pic below shows the yoke with yellow arraows. Do not disturb the purity rings (RED ARROW) or it will cause blotches in the picture so its very important not to disturb the item with red arrow.
Mar 06, 2013 | Televison & Video
We can't aline the crosses in the colour picture looks 3d
a broken or misalligned purity ring could caused this problem try replacing it with identical replacement and with asimple manipulation adjustment
Jul 15, 2011 | Panasonic CT-32SL14 32" TV
REDENT PURCHASE OF TV'S Have green in some spots.
This is typically referred to as a color purity problem and can be caused by two main things. The first cause can be stray magnetic fields which can 'magnetize' the TV screen either by something magnetic begint oo close to the screen or having turned the direction of the TV while it is turned on. If this is a purity issue caused by magnetic fields, it can usually be cirrected by powering off the TV for about 1/2 hour and turning it back on. All tube TVs have build in 'degaussing' circuits to cure just this issue.
If this doesn't fix it the other cause is a shifted shadow mask inside the picture tube itself and cannot be corrected.
May 25, 2009 | Televison & Video
Color disturbance on the screen
if you see a green, red or blue color onto the others means that is getting convergence problems
Mar 01, 2009 | Philips 60PP9202 60" Rear Projection...
Samtron 56V monitor
Its aproblem of command section.Check its components one by one.you can identify this section (the front panal buttons goes in this section and a ic in big size and pasted horizantally in the circuit).if the components are ok then change command ic with new one.This will solve your problem.
Jul 27, 2008 | SAMTRON 55V 15" CRT Monitor
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
48 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
