Question about Sony DSC-T70 Digital Camera
I turned my flash off but don't remember how to
I turned my flash off but don't remember how to turn it back on can you please give me directions on how i turn it back on
  • Anonymous May 11, 2009
    cannot turn the flash on
  • Anonymous May 14, 2009
    couldn't turn flash on did the initialize reset settings thing and that worked
We had exactly the same problem and the only we could get the flash working again was to do back to the default settings. (Home, settings the initialise and then it asks if you want to restore default settings and we said ok.
Hope this helps
Posted on May 14, 2009
My turn signals don't work but the hazzards flash
if your hazzards flash, that means your bulbs will be good but, your turn signal fuse is blown. you should check that first, & don't forget to turn off your hazzards before you can see if your turn signals work again. give it a try.
Dec 01, 2011 | 2000 Dodge Caravan
I have a Bosch she4ap06uc/05 quick wash light flashes. I have tried to reset it and it will not reset. The sump pump work and drains all the water out of the machine. It turns off and on fine but when...
Bosch she4ap06uc/05 This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Nov 13, 2011 | Dishwashers
1997Ford F350 Diesel, Will not turn over, just one click and nothing. Is there a way to test the starter or solenoid? If there is can you please give me directions? Any other things I could check?
Try jumping it, sounds like the battery can be dead. But there is a solenoid on the firewall I believe the left side inner fender (in the engine compartment) you can turn the ignition on and jump the two leads with a screwdriver and see if the motor turns over. Remember this is a huge motor with high compression and the glow plugs have to fire to start. Takes a lot of juice to get it going (thats why it has 2 batteries). Make sure you have charged batteries. If not charge/jump the truck. The starter can only be tested off the truck, a solenoid if bad only cost a few bucks ($20-$30) but they don't fail too often
Oct 15, 2011 | 1997 Ford F350 Crew Cab
FujiFilm fine Pix A 345. Lend won't open upon turning on camera. Camera makes a buzz noise and then the display reads zoom error.
Those things get stuck.
You have to mess with it until it comes unstuck, if it even does.
Try hitting it while you are turning it on. Tap it from all sides and directions.
You might get lucky.
I got mine to come back to life temporarily.
Please don't give me a thumbs down just cause its bad news.
Aug 31, 2011 | Fuji FinePix A345 Digital Camera
I don't have a manual and want to learn how to set the time and date--that's all I need from this watch.
Hi,since you have not stated the model number I can direct you to the web site given below..
please insert your model number (should be on back of watch ) than download the manual..
Hope this helps! Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
http://www.polarusa.com/us-en/support/downloads?product=&category=User+manuals
Aug 03, 2011 | Polar Watches
We just switched the old school turn signals with LED signals but now they all turn on at the same time and don't flash. if we put the old ones back on then they will turn on correctly but still...
You need a equaliser (i think thats what it is called). I had the same problem with a custom bike, the voltage is designed for a certain volt and if you change it than it will not work properly, any after market motorbike shop should have one, they are fairly straight forward to hook up, directions should be in pack.
Jun 09, 2011 | 1981 Yamaha XJ 650
I CAN'T DON'T KNOW HOW TO TURN ON THE FLASH.
To turn the flash ON please follow the instructions below
  • Raise the Flash
  • After pressing the tinualbinale_1.gif button turn the mode dial button tinualbinale_20.jpgon top to choose tinualbinale_16.jpgsymbol.
  • Then press the FUNC.SET tinualbinale_17.jpg button.
  • Once set, tinualbinale_18.jpg symbol will appear. Now the flash is turned on.
Jun 04, 2011 | Canon PowerShot SX130 IS Digital Camera
My iphone 4 submerged in water and sence then the flash is on please advice
Turn it off!
If the water was salty, it gets a bit harder and riskier. If it was a salty water, you have to first put your phone in a non-salty water to get the salt off. Don't leave it there for long, just long enough for the salt to be gone. The time it took in the water it was dropped in is a good choice.
Now remember the first step, turn it off!
Wait for a couple of days. Wait as long as 4 to 5 days to be sure, because it takes really long for the phone to dry. Don't use a hair dryer! Don't put it on a heater. Just put it someplace dry and cool, not direct under the sunlight but also not in dark.
After waiting that long, hopefully your phone will return back to life. If not, you have also lost your chance with the Apple service, because they don't cover water damage. Try your luck though.
Apr 14, 2011 | Apple iPhone Smartphone
I don not know which direction to attach ruuber band that turns the turntable.
My husband had a flash of insight and remembered what he did when he accidently removed it when we bought the turntable. Thanks for checking back!!
Sep 17, 2009 | Sony Audio Players & Recorders
I can't remember how to turn the flash back on to auto flash?
  folloe these steps
camera<settings <Flash< turn it on .    or camera<more<flash<turn it on
Oct 16, 2007 | Sony Ericsson K750i Cellular Phone
Sony DSC-T70 Digital Camera Logo
266 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
