Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Color disturbance on the screen
How can you identify convergence problems andwhat could be the cause?
  • 125 Answers
If you see a green, red or blue color onto the others means that is getting convergence problems
Posted on Mar 02, 2009
Why is my picture green on my tv?
The screen colors are all derived from three distinct colors. Red, Blue and Green. The colors can change due to a few problems. The purity or converge could have been disturbed due to magnetic interference, one or two of the color amplifiers have stopped working or the picture tube has failed. Color problems can be as easy as circling a high magnetic field coil in front of the set, known as 'degaussing' or extremely technical, frustrating and then hence expensive.
Jul 13, 2014 | ESA Televison & Video
Distorted Picture
Could you explain a bit more clearly by what you mean by "shifted"? A pic here would help..
Jun 27, 2008 | Hitachi 53FDX20B 53" Rear Projection...
The picture is green ?
The screen colors are all derived from three distinct colors. Red, Blue and Green. The colors can change due to a few problems. The purity or converge could have been disturbed due to magnetic interference, one or two of the color amplifiers have stopped working or the picture tube has failed. Color problems can be as easy as circling a high magnetic field coil in front of the set, known as 'degaussing' or extremely technical, frustrating and then hence expensive. Not much help, I know, but good luck.
Jul 13, 2014 | ESA ET427E 27" TV
Where are the convergence boards located or how are they identified?
Look for the large metal heatsink...
More info below also....
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 22, 2010 | Hitachi 57F510 57" Rear Projection...
The menu option (blue color) or USER mode H:48. 4KhZ V:60Hz is appearing automatically on the screen. It is disturbing us to work
USER mode H:48. 4KhZ V:60Hz is appearing automatically on the screen. It is disturbing us to work problem
Nov 23, 2010 | Computers & Internet
Color is warped and the convergence colors setup on the setup screen will not reslove the issue, Problems was most like caused by an electrical surge.
Could be?Might not,these are very common problems on DLP tvs convergence board are dead.The tv have convergence problems,it dead.The tv convergence board require the 2 STK convergence ICS and some or all it resistors are dead.These parts require changing,to solved convergence problems.The shop will $300-350 for parts and labors.
Jul 12, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Wavy horizonal disturbance in picture
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 07, 2010 | Televison & Video
Purity disturbance
if the color is missaligned means your tv is having convergence problems and you will need to replace some parts inside the tv
Mar 01, 2009 | Philips 60PP9202 60" Rear Projection...
Convergence problem
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
You can download the manual here. Insrtuctions for auomatic convergence are described. I copied the instructions below.
Automatic Convergence
Your HD Monitor’s picture tubes might have been disturbed during delivery or
after you moved the HD Monitor, causing the color in your HD Monitor to be
out of alignment. The colors adjust by starting auto convergence.
IMPORTANT: Auto convergence works best once the HD Monitor has
warmed up for at least an hour. If you've just unpacked your HD Monitor,
it's a good idea to repeat the Auto convergence function when the
HD Monitor's been running for at least an hour. See page 38 for more
information about Auto convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu
appears. The cross in the middle of the screen should be yellow. If it is not,
use the arrow buttons to move the red cross to overlap the green cross.
Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle
of the screen. If it is not, use the arrow
Sep 23, 2008 | RCA R52WM24 52" HDTV Projection Television
Convergence
Color tubes are OK. Do not adjust. The issue at hand is called
convergence alignment.The repair involves-------
1)Pull chassis
2)Replace convergence IC's
3)Recheck alignment
work should be done by a skilled technician........T.
Oct 24, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
85 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
