Question about Uniden BC60XLT-1 Handheld Scanner
How to install a new charging plug inside the scanner?
The charging plug has been broken out of the scanner. I've tried to use batteries but it didn't work. A person at radio shack told me the circuit has been cut, which is why batteries wouldn't work. When I took the scanner apart, I see three points broken off the circuit board in a small white square named J3. Any ideas?
    Sergeant:
  • 274 Answers
If I am picturing this correctly I see two senerios, you have a 3 point pad and the trace is broken between each of them. Then you could try soldering a #30-36ga buss wire across each of the breaks. Use a very fine tip low watt soldering iron and 60-40 solder with very little flux. Delicate operation, use patience. You should take the board out of the case if possible. If your are really "good" you could "pull" a solder bead across each break. The other picture I have is the whole connection is pulled up. Down side is you may have also broken the solder pads inside and through the board. If that is the case can't be fixed. But try re-soldering it back down to the board by pushing down at the same time heating with a soldering iron. Hopefully you won't short anything. You may get lucky and suceed.
Posted on Aug 22, 2007
  • tofelectroma
    tofelectroma Mar 03, 2012
    i Have the ubc 73xlt and it has the white plug between the two boards broken i was just woundering if any one has the circuit diagram so i can try fixing it as some of the tracks have gone but do have a new plug to go in just need to see where all the pins go
How do I replace document feeder,broken?
Hi
You state that this "was new out of box" the machine. If this is so and particularly if the machine is new then you should take it back to the vendor for him to replace with a working unit, because clearly the one you have is "not of Merchantable Quality".
Hope this is helpful, if so would you please register that with Fixya
Cheers
Jan 26, 2015 | PANDIGITAL Handheld Wand Scanner Wfeeder...
Scanner keeps shutting off
Is it a 528 ? Mines doing the same thing ,,,can't figure it out
Feb 27, 2013 | Radio Shack Radio Communications
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
EEE PC 1005P won't charge, can it be a motherboard problem?
honestly you've done everything correctly that i could think of. one last thing you could try to root out a problem with the os. is boot the computer from hirens boot disk and load the portable Windows. see if the battery is detected in hirens. then youll know if its a Windows problem or not.
personally i feel the board is the issue but it doesn't hurt to check the complete os.
Feb 26, 2017 | Computers & Internet
Very low battery life
I have the same camera. It sounds to me that there is a fault with the camera itself and not the battery. You might be better sending Canon an email and asking them. My battery lasts forever so I would think if you already purchased another battery you've eliminated that problem. It might be the contacts inside the camera that are not accepting the full charge. Does the camera battery on screen show that it's full after you've charged it? Maybe trying charging it overnight and then trying it out the next day.
Dec 27, 2011 | Canon PowerShot SD300 / IXUS 40 Digital...
Radio shack iscan trunking scanner, pro-107
I no longer provide support for any scanners. As a Police Dispatcher I was working when two police officers were ambushed and killed because a person listening to a scanner told the suspects the police were coming. They should be outlawed.
Dec 19, 2011 | Radio Shack Radio Communications
I have a Coby Kyros MID7020 and does not power on. The battery is charged. Can you hlep me? Thanks a lot Franco, JGM
If the battery is fully charged but still your unit does not work, the problem could be a lost contact inside your scanner. It could be a factory defect. What you've got to do is to call your service provider about it. They can definitely help you solve it. Thanks.
Jul 10, 2011 | Computers & Internet
Charger plugged in but battery isn't charging. laptop only comes on when plugged.
If you've been using that same laptop battery for a few years then it probably needs to be replaced. Batteries get old and stop working properly after a while. You'll have to go out and buy a new one.
May 10, 2011 | Computers & Internet
I have broken the six AA batteries holder for my Radio Shack PRO-60 scanner, where can I buy a replacement?
Any Radio Shack store should be able to order one for you Before you go that route though, check eBay. The battery holders come in several shapes, but you might find one that will work for you - at a bargain price.
Bill B.
Listening in professionally since the 60's
Mar 16, 2011 | Radio Shack Pro-84 Handheld Scanner
Uniden BC60XLT-1 Handheld Scanner Logo
85 people viewed this question
Top Uniden Radio Communications Experts
Steve
Marvin
Marvin
Van Allen II
Van Allen II
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
