Question about HP Photosmart R717 Digital Camera
Will my old Hp R717 support a 2GB Kodak Memory card?
Every time I try to put this memory card in my camera the LCD screen goes blank/white and I can't seem to do anything!  Any ideas?
    Problem Solver:
  • 7 Answers
Is the Kodak card 'SD' or 'MMC?' This camera can use either of these but no other type. Try to format it in the camera if you can.
Posted on Jan 14, 2010
  • 3 Answers
Have you tried formating it on your computer?
Posted on Apr 26, 2009
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
My sandisk 256 memory card won't work in my kodak c183. I previously used it in a nikon camera. All pictures have been deleted from the card. When I insert it, the camera screen goes blank and nothing...
Try Formatting it in the camera you plan to use it in, also make sure the cards format is compatible, some older cameras wont take the new memory cards on the market today. Cheer's.
Jan 26, 2011 | Kodak C183 Digital Camera
We insert a memory chip into our Kodak EasyShare C190 camera. The read-out informs us that the memory card requires formatting. We click on "OK." The camera goes into a "formatting" mode, then informs us...
Your camera is only supporting SD/MMC Cards (up to 2 GB) and KODAK SDHC Cards (up to 8 GB).
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Jan 04, 2010 | Kodak Easyshare C190 12MP Digital Camera...
Put new memory card in camera but has formatting problem. When memory card is put in it says the new memory card requires formatting. When I continue it states that formatting will delete everything in...
New batteries first!! Make sure they are "GOOD"
May have a bad or incompatible card.
Will you camera take pictures without a card in it?
If yes, you have a bad or incompatible card.
Try another card
Here is all the information you'll need to solve this:
Read it.
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=8814&product=EKN031714
Dec 24, 2009 | Kodak EasyShare Z612 Digital Camera
My sanyo xacti camera has a blank white screen
have the same camera and the same problem you have?
have you found a fix?
if you do can you contact me at danielmartinez_es@hotmail.com
Nov 03, 2009 | Sanyo Cameras
WHERE is the port to put my memory card from camera into my HP?
HP Laptops don't come with a built-in card reader.
You have two options:
  1. Use the USB cable that came with your camera to download your pictures. This plugs into your camera right next to where your card goes. Your computer will recognize the camera as a "removable drive". Click the Start button, click on My Computer, and click on the drive (usually E or F) that is called "Kodak EasyShare").
  2. Go to Best Buy or similar and purchase an HD Card Reader. These cost about $20-$30.
Mar 12, 2009 | Kodak EasyShare Z710 Digital Camera
Formatting a HP 4GB Memory card
The best thing that you can do is to try to format the card from a laptop with a built in card port or use a card reader and format it on your computer.
Feb 06, 2009 | Kodak EasyShare C613 Digital Camera
Help with kodak M753 camera and memory card!
If you format the card, the pictures are gone leaving you with a blank memory card.
Format the card in your camera, then load it up in your computer and see if the cycle goes away.
Once you get a picture on the memory card and in your computer, keep an eye on the memory specs reporting on the computer and see if there is anything unusual. I've heard of a few defective cards but its rare.
Jun 21, 2008 | Kodak Easyshare M753 Digital Camera
Screen goes blank after memory card is in?
Are you putting it in the rightway round? Check the illustration under the cover or the manual. If you are contact HP tech help for the model of camera.
May 12, 2007 | HP Photosmart 620 Digital Camera
LCD Screen shows Kodak Logo when turned on then goes blank.
You've probably corrupted the firmware download. If the camera is still recognized by your PC then I'd try downloading the firmware again and try to load it again into the camera. I don't wish to upset you but corrupting the firmware can in some instances make the camera unusable. Your manual should tell you if there's a reset and how to do it. Don't forget the camera's firmware can also be upgraded by loading the update onto the memory card and running it from there. GOOD LUCK BMW
Jul 03, 2006 | Kodak EasyShare C330 Digital Camera
HP Photosmart R717 Digital Camera Logo
89 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
