Question about Kenmore Dryers
The barrel squeaks loudly when it starts but once it gets warm it quietens down. is it a belt? or are there roller bearing that are dry?
  • Kenmore Master
  • 3,361 Answers
Remove and clean the rear drum rollers.
After inspection decide if they should be replaced.
Posted on Mar 01, 2009
Constant loud squeaking
Squeaking is normally caused by a bad bearing or a slipping drum belt.
Feb 28, 2015 | Dryers
Dryer drum has an intermittent squeak when running
there is a belt tension'er it might need to be replacing or temp fix greasing or drum bearing replacing or temp fix greasing to do this you will have to remove the drum
May 28, 2012 | Frigidaire GLEQ2152ES Electric Dryer
My Kenmore front loading dryer, 970-C85192-00 starts drying with a load squeaking noise. Once it warms up it stops. Could it be a belt?
usually this is a drum roller replace both very inenspensive and u can order parts directly threw sears.com recheck model number get off appliance data tag on appliance
Jan 28, 2011 | Dryers
The belt squeaks
Generally the belt does not squeak although the roller the belt rides on does from a dried out roller bearing
It will be time to replace both items
May 31, 2010 | GE DWSR463EGWW Electric Dryer
My Maytag Model MDG8057BWW first squeaked then began loudly knocking. What is causing this; everything is drying well otherwise.
The drum to the dryer has a belt with a belt tensioner on it. The roller for the tensioner has a frozen bearing that will not turn giving the roller a flat spot on it. This is causing the noise you hear. sears.com can provide you parts to service this belt and roller as a kit form for replacement
Apr 12, 2010 | Dryers
Loud squeaking when you first turn on the dryer, it usually calms down after the dryer has gotten warm and the squeak is not so loud. Also tags from clothes are getting caught around the inside rim of the...
The problem is your bearing is nearing the end of its life. I just had mine apart and put a touch of axle grease on the drum main bearing, I also put a touch of this on the idler roller shaft (avoid getting any on the belt). Do not use petroleum jelly (Vaseline product) as it will turn into a liquid at the temperature the dryer runs at .
Dwight
Mar 31, 2010 | GE DBXR463EDWW Electric Dryer
Dryer squeekes on and off
Hello.
Intermittent squeaking usually arises from drum rollers, a bearing at the back of the tub or the pulley for the belt. Locate where the squeak is coming from the loudest and you can narrow down the cause.
Loud in the back middle: Drum bearing kit
Loud in the back bottom: Drum rollers.
Loud in the top front: Drum glides
Lound in the bottom front: Belt pulley.
Jul 21, 2009 | Dryers
KENMORE DRYER
Hello ENRIGHT11 Welcome to Fixya
My name is Huum,
You said,
DRYER MAKES VERY LOUD NOISE WHEN RUNNING. ALTHOUGH IT HEATS UP AND BEGINS TO DRY, IT STOPS RUNNING COMPLETELY AFTER ABOUT 5 MINUTES. IF YOU WAIT AN HOUR, YOU CAN START IT AGAIN, BUT IT AGAIN SOUNDS VERY LOUD (ALMOST A RATTLING SOUND) AND THEN SHUTS OFF AFTER 5 MINUTES
Faulty Blower Wheel
If you hear a great deal of noise coming from the blower area of the dryer when it is running, then the blower wheel could be defective.
The are many different designs for blower wheels and just as many unique failure modes. Vanes (fins) can break off the wheel and bounce around in the blower breaking more pieces. The blower can break around the coupler with the shaft. This can cause the blower to spin loosely on the shaft. The blower can form cracks which cause it to vibrate, etc.
You should also not be surprised to find foreign debris in the blower. The occasional bird, rodent or squirrel has been known to bypass the out vent cover. If they crawl into the exhaust tube the first thing they come into contact with is the blower wheel.
If the blower wheel is not spinning, or if it is missing vanes, it is not moving air efficiently. As a result, heat is not removed from the heat source and it can trip the high limit switch or blow the thermal cut-off.
Worn Belt
A worn belt can stretch and/or become brittle with age. The belt can then slip on the drum or motor to cause squeaking. If this is the case, the solution is to replace the worn belt.
The belt is not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, worn drum glides or worn drum rollers depending on brand and style.
When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are economical easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Recent Customer Symptoms:
Dryer makes loud noise when turned on. Dryer works and heats up OK but makes too much noise.
Worn Drum Glides
Some dryer models are equipped with Drum Glides. The front of the dryer rests on these glides. They provide a low friction surface on which the drum spins. After time however, this glides wear down. Much like an automobile brakes, these glides make a load grinding noise when they wear thin. This griding against the drum usually leaves a bare metal stripe that is visible at the point of contact. If the glides are worn, the solution is to replace them.
The drum glides not the only items that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, a worn belt or worn drum rollers depending on brand and style.
When replacing the Drum Glides it is a good idea to also change the Drum Support Rollers, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new.
Worn Rear Drum Bearing
Some dryer models are equiped with a Rear Drum Bearing. The rear of the drum rests on this bearing. It provides a low friction surface on which the drum spins. After time however, this bearing will wear down. If the bearing is worn, the solution is to replace it.
The rear drum bearing not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum glides, a worn belt or worn drum rollers depending on brand and style.
When replacing the rear drum bearing it is a good idea to also change the drum glides, drum support rollers, drum belt, idler pulley and clips depending on make and model. All of these items are economical and easily changeable when replacing the rear drum bearing. The upside is that your dryer will operate like new.
Worn Drum Support Rollers
Some dryers such as Whirlpool/Kenmore brands are equipped with Rear Drum Support Rollers. The weight of the dryer drum rests on these rollers. They provide a low friction surface on which the drum spins when in operation. After time however, these rollers wear down. When they wear, often times they begin to elongate and form a non-round 'cam' shape. The result is that when the dryer is turned on it creates a rumble that sounds as though you are trying to dry a pair of tennis shoes. This sound is usually the drum being forced up and down on the non-round wheels. If the rollers are worn, the solution is to replace them.
When replacing the Drum Rollers it is a good idea to also change the Front Drum Glides, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new. Whirlpool
Kenmore models have a dryer maintenance kit that contains all of these items in a single kit.
Thank You For trusting us with your question
Please remember to leave a
solved rating before you leave!
Jan 21, 2009 | Kenmore 63942 Dryer
Whirlpool Imperial Dryer Model #LAE8800A0
these bearings are dry plastic pads if i am, correct, these can be lubricated very slightly with a little silicone grease where they are rubbing on when the drum rotates
if you cant use silicone grease, more or less any will do that is thick and doesn't smell, only use a very small amount so it doesn't go on the clothes
a very small amount is enough to stop the pad being dry but not enough to see? almost like wipe it on then wipe it off,
also lubricate the the pulley wheel on the belt tensioner (the little small wheel at the bottom if it has one
Oct 13, 2007 | Dryers
Dryers Logo
35 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
