Question about LG CHOCOLATE VX8500 Cellular Phone
Faulty battery perhaps
I poured some water on my cell phone by accident. After I dried it still does not work. When I plug it in it start recharging and I can turn it on. But after a few seconds I get this message:
"Heat sensor detected high temperature remove the battery or move the phone to a cool place"
Do you think I should only replace the battery? Or there could be something the phone itself?
thanks
LG chocolate spin 8550
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 96 Answers
It could be either with water damage, and if the phone is still wet inside it will overheat by plugging it in.
Get a bowl of rice, remove the battery and leave the back of the phone open. Put both battery and phone in bowl of rice and leave covered overnight. The rice will soak up any water in the phone or battery.
If this doesn't work the phone has permanent water damage and will need to be replaced.
Posted on Mar 02, 2009
I have one maxwest cellphone it's damaged by water, can it fix it?
Open the phone and remove the battery. Dab all internal surfaces with paper towel to remove as much moister as possible. Then use a hair dryer on medium heat to gently dry the phone completely. Make sure the battery is dry as well. Leave the phone open for a further half hour after drying and then put the battery back in and close the case. Switch on the phone, good luck.
Dec 30, 2014 | Cell Phones
Tip
What To Do if I Drop My Cell Phone in Water?
The small convenient size of cell phones unfortunately also makes these electronics accident-prone, especially when it comes to water. If you drop your cell phone in water it is often possible to salvage it. If you drop your cell phone in water, you may have only seconds to retrieve it, so you need to act fast even if it means retrieving it from the toilet!
The next thing to do if you drop your cell phone in water is to remove the battery immediately without even hesitating to turn off the power. Dry the batter with a towel and set aside to dry thoroughly. The battery itself may or may not work again, fortunately batteries can be replaced fairly inexpensively. Even if the battery does work, it is a good idea to get a new one.
After you have removed the battery, dry off the cell phone with an absorbent towel as best as you can. Use cotton swabs to soak up water in crevices and on any fragile, exposed circuits. It is also helpful to disassemble it if you can and let all the parts dry separately. Just be sure that you know how to put it back together. If it is a flip or sliding cell phone, leave it open.
If you drop your cell phone in a beverage or in salt water, rinse the phone off with fresh water once you have removed the battery. Once you drop the phone in water, the additional rinsing will not do further damage, however, minerals or other materials will.
If you drop your cell phone in liquid that isn’t pure water, you may want to try giving it an alcohol bath. The alcohol will displace minerals and microscopic substances as well as aiding in the evaporation of the fluid. If it is available, you should use an alcohol concentration of 95% rather than rubbing alcohol that usually contains only 70%.
Once your phone is clean, leave it in a warm dry area or near an air conditioner for three days before you attempt to replace the battery and turn it on. This is very important, because although you may think that you have thoroughly dried it, the slightest moisture can react with the battery and cause it to short circuit. If droped your cell phone in water, and want to save it, resist the temptation of turning it on to see if it is working until you have waited at least 72 hours.
on Mar 10, 2010 | Cell Phones
My samsung smooth got wet i let it dry but will not turn on
Wet Cell Phone
Immediately remove the phone from the water,turn off the cell phone remove the battery and SIM card. When you have driedthe cell phone by putting in a warm sunny place for several days or in front ofa warm fan heater for several hours then reassemble the phone. Hopefully itwill work properly but if does not work then it is faulty and you need a newcell phone.
Jul 08, 2012 | Samsung Cell Phones
Mobile in water not working now
Remove The Phone From The Water
The first step is to remove the phone from the water as soon as possible. The less time the phone spends submerged, the greater chance it has of being saved. The plastic covers that come with cell phones do provide some protection, but it takes a mere twenty seconds or less for water to get through these barriers and start causing damage to your phone.
Once you pull the phone from the water, remove the battery immediately. Cutting power is a crucial step when attempting to save a wet cell phone. There are many circuits inside cell phones that can survive getting wet, but only if they are not attached to a power source.
If your cell phone comes with a SIM card, remove it promptly. Do not heat the card, simply pat it dry with a soft towel, and put it aside until the rest of your phone is dry and back to working order. The good news is that SIM cards recover well from water damage. If for some reason, your phone doesn't survive the accident but the SIM card does, there are plenty of places that sell unlocked cell phones. Simply place your SIM chip into the new phone and go.
Salt Water Accident
Please take note; if your phone was submerged in salt water, you must rinse it in fresh water before the drying process begins. Even after the phone is dry, crystals can form and continue to cause damage and erosion.
Let Your Phone Dry
The next step you must take to save a wet cell phone is to allow the phone to dry. A great method in providing an optimum drying environment is to set the phone on the vent found on the back of a television set or cable box. The low heat emitted will gently dry your cell phone. Another trick to help speed drying is to place the phone in a bowl of dry rice. This will help draw out the moisture. You can also try placing the phone in a plastic baggie with a few silica packs that come in purchases such as shoes and electronics. Silica, like rice, absorbs moisture.
The important part of the drying process is to place the phone uncovered, in a warm, dry place and allow the moisture to evaporate completely. Another alternative is to place the phone on an air conditioner. The cold air will not damage the phone and the air from an air conditioner is very dry allowing the water to evaporate quickly.
Drying should take approximately three days at which time you can check to make sure the phone is clean and dry. It is at this time that you can re attach the battery and check if the phone works. If it doesn't, wait a few more days and try again. If the phone still doesn't work, take it to your local dealer, they may be able to repair it. Be prepared; getting a cell phone wet will void your warranty and most cell phones are equipped with a water damage indicator so the dealer will know the phone has been H2O compromised.
Alternative Drying Methods
There is an alternative way to save a wet cell phone that includes an alcohol soak. Alcohol is hygroscopic which means that it attracts water. Soaking your phone in denatured alcohol, or a 95% alcohol solution (regular rubbing alcohol is about 75%), soaks up all the water in the phone. When the liquid is dumped out, only alcohol, which will evaporate, remains. Make sure that the alcohol you use is denatured with only methanol as the chemicals found in other types can be damaging. This kind of alcohol can be purchased at your local hardware store. The alcohol soak may work best for phones that have been damaged by salt water or other liquids such as coffee.
Battery Caution
When attempting to save a wet cell phone, make sure you do not heat the battery as it could leak or even explode. Lithium-ion batteries are especially sensitive. In addition, many cell phones have plastic parts that can melt. Above all, do not try to save a wet cell phone by placing it in a microwave. You will destroy the electronic components and possibly the microwave in the process.
The above steps will help to save a wet cell phone, but be prepared. Often the phone will survive but the battery will not and the purchase of a new one may be in order. Good Luck!
Dec 05, 2010 | Nokia 2690 Cell Phone
My daughters LG Xenon cell phone has been working fine until last night. She charged it, started working fine then shut off and won't come back on. I plugged it into the charger and it started working,...
battery short circuited change the battery and see that you do not charge overtime. second is recharge only after the battery has compltely been used from previous charging
Oct 14, 2010 | LG Xenon GR500 Cell Phone
I accidently went swimming with my cell phone in my pocket. I let the phone dry for a couple of days and it recharged and was able to send a call but the speaker never worked again. I purchased a new...
Unfortunately you have no chance. You're very lucky that the flooded phone worked for so long afterwards, but the water will have left conductive residues as it dried out and these have effectively fried your phone.
Sep 21, 2010 | Cell Phones
I accidently wet my cell phone. I went to a att store and a represenative said to try putting the phone in a bag with rice. Now it just turns on...but... There is no! sound.
Water normaly leaves something after it evaporates too make sure it is propely cleaned and dry.
Open the phone, remove battery,sim and memory card. Dis-assemble the phone so your left with just the circut board. Used distilled water as it will not leave anything when it evaporates. Make sure the Phone has dryed propley re-assemble with sim, battery and memory card.
Hope the sound works
Jun 27, 2010 | Cell Phones
I dropped my phone yesterday in water. I took it out quickly and dried it off. It works perfectly fine now but the navigation keys' back light won't turn off. When my phone is off the lights are still on...
There is still some water, perhaps corrosion now, inside the phone.
The best thing to have done is to pull the battery off as soon as it happened, and take it to retailer so that they can get it dried out before damage occurred.
Since your phone is now damaged, your recourse likely will be to replace the phone using insurance / oops protection, or start carrying an extra battery.
Jun 13, 2010 | Nokia 6760 Cell Phone
LG Dare water damage
how long has your phone been in rice? 2 days? that is how long it is supposed to be in rice. you could try recharging the battery for how ever long it takes for it to load. but those phones are pretty delicate so unfortunately there is a good chance its gone.
Jun 27, 2009 | LG Dare VX9700 Cell Phone
Mobile phone not working
change the battery dude!!!!!!!!!!!!
Aug 07, 2008 | Sony Ericsson K790i Cellular Phone
LG CHOCOLATE VX8500 Cellular Phone Logo
337 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
