Question about HP Audio Players & Recorders
SPEAKERS DON'T WORK THO THERE IS A LARGE SPEAKER BOX
WHEN SET UP, PERSON GOT SPEAKERS TO WORK, BUT SINCE HE LEFT HAVE NOT BEEN ABLE TO GET ANY SOUND. A LARGE SPEAKER BOX CAME WITH 3 SMALLER SPEAKERS. DON'T KNOW HOW TO FIX?
  • 77 Answers
CONNECT TO THE CPU BACK, SOCKET PROVIDED, USE THE SPEAKER MANUAL
Posted on Apr 07, 2009
My acer aspire 7741z-4643 speakers wont work
Try reinstalling the audio drivers.
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Audio drivers.If that don't solve the problem maybe you blew the speakers.
May 02, 2012 | Computers & Internet
Good afternoon, I recently bought a SA VE325 speaker set it contained a subwoofer, 4 little boxes and a mid-large box which you haeb have tpo piuyt above uyour tv. Now the problem is we have no cCENTER to...
Hello there looking at the manual i would assume that the mid-large box is actually your centre speaker.
Did you mean that there are no connections left on the back of your amplifier? For a centre speaker this system uses all passive speakers apart from the subwoofer which has a built in amplifier for just the subwoofer, your hifi or home cinema amplifier would need to have at least 5 separate channels to operate the centre speaker as well as the front and rear speakers.
Ideally you would need a 5.1 channel or 5 channel amplifier with subwoofer pre output, any would do but to make things simple one with a digital optical or coaxial input would be best as this can easily carry multi-channel audio with just one connector.
The other alternative if your amplifier does not have a centre speaker output are:
· to get another basic mono stereo amplifier to power the centre speaker on its own however if your main amplifier does not have a pre out connector for a centre speaker you will have to change the volume independently on both amplifiers
· don
Aug 27, 2011 | Sony SA-VE325 System
Need help installing speakers to receiver
On the back of the receiver you will find the connections for the right and left speaker, OR if it is surround sound you will find, right front, right rear, left front, left rear, and center or bass. The connections can be RCA type jacks or they can be wire clip type.
Depending on the connections on the receiver and on the speakers, the wire will have to match the connections on each end. The wire needs to be large enough to handle the power output of the receiver. Wire can not be too large but it can be too small. Larger wire is more expensive, so there is no benefit in purchasing excessively large wire. Packaging should designate the power handling capability of the wire. The wire should not be much longer than is necessary to place the speakers where you want them. Too long wire unnecessarily cuts down on the power to the speakers. Don
Jun 21, 2011 | Yamaha DVX-C300 System
The sub on the left speaker don t play and the light went off but the mid and tweeter have sound coming out
The amplifier that drives the built in subwoofer has stopped working. The first thing to do is check that the power cord is plugged in to a live power outlet. Next, replace the fuse which you'll find on the large black metal plate on the back of the speaker. Use only the size and type fuse specified. If that does not work contact Definitive customer service at (800) 228-7148.
Apr 02, 2011 | Definitive BP7006 Main / Stereo Speaker
Can't get the subwoofer to work when the fronts are set LARGE?
The manual implies that 'subwoofer=Yes' is independent of the rest of the speaker settings, but that it would be set AFTER selecting the other speaker configuration from the list of 11 possibilities.
Jun 08, 2010 | Sherwood RD-6106 Receiver
The subwoofer is not working on our Bose 5.1 surround speakers.
First of all you should never indicate speakers as Large unless they can produce below 20Hz (which is very low), otherwise always set your speakers to Small.
Second, did you also indicate in teh setupmenu that you have a subwoofer? Because if all speakers are set to Large some receivers will omit a subwoofer because Large indicates the speakers can reproduce all sounds even below 20Hz.
So walk through your setup menu, say YES when the sub (SFW) is asked for and that should do the trick.
Apr 06, 2009 | Yamaha RX-V663 Receiver
Weird surround sound speaker behavior with Denon 2105 7.1
Sounds interesting.
It may sound silly, but can you check all your speaker cables again and confirm whether they are connected to the right connections. please check all cables as also the severed one and please repair it also.
Now please go to the system-set-up and do an auto setup and set up your speakers. Listen to the test tones and confirm that they are coming out of the correct speaker.
Once these are set, then if still there is mismatch of sounds, then we could further trouble shoot.
Mar 08, 2009 | Denon AVR-2105 Receiver
JBL CREATURE II Computer Sattelite Speakers Sound Problem
check on the speaker software were you can set master volumeetc. check for balance volume .
Oct 27, 2007 | JBL CREATURE II Computer Speakers
Can i use small satelite speakers with my big front speakers?
Hi, I asume your setting up a home theater with five speakers a center left and right and rear surrounds don't know if you have a subwoofer. The large speakers in the front will work fine if you set the amp to large front speakers the bass will be sent to these. If you have a subwoofer set, the amp to small front speakers and the bass will be directed to it. Also try to get a center channel speaker that sounds somewhat like your large speakers.
Feb 14, 2007 | Yamaha AX-596 Amplifier
42 people viewed this question
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
rfredey
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
