Question about Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator
I have a kenmore side by side and the icemaker makes a ticking noise that last about thirty seconds and stops. It happens maybe once an hour. How do we stop the ticking ?
  • 410 Answers
The ticking noise is the icemaker motor. during ice harvest there is a time whne the icemaker motor "stalls" out against the ice before the ice releases into bucket. its during this time the motor is making the noise. this is a sign of motor gear wear. the motor module on the front of your icemaker needs replacing the part number is 8201515 and should run 60-80 dollars. this part is easily replacable. remove front i/m cover and there are 3 phillips screws that hold the module in place.
Hope this answers your question. any furhter questions just leave a comment here and I'll be glad to assist any way I can.. Peyton
Posted on Mar 01, 2009
My Kenmore refrigerator (596.52673200) is making a noise every 3 minutes or so for about 15 seconds. It seems like it is trying to fill the ice maker. There was ice in the little rubber tube leading to the...
Put the icemaker arm in the lock position to turn it off.
If it is the icemaker making the noise, the noise should stop.
If the noise stops,replace the icemaker.
If it does not stop,let us know.
Sep 22, 2010 | Refrigerators
Service engine soon indicator on and a buzzing/whining noise.
i recommend that you take it into auto-zone or a car shop asap. from what you have described the ticking as, it sounds like a bottom knock. as for the whine i don't know.
May 14, 2010 | 2005 Nissan Xterra
My upright freezer works great but it makes a clicking noise like every thirty seconds or so.
These are the parts that would make a clicking noise. it is up to you to pin point where it is coming from:
compressor
timer
icemaker
fan
ok try to pin point if the clicking is coming from the inside or the outside
you can go to sears.com hit the parts link then enter the model number. you can view a diagram and it will show you where the parts are at
hope this helps
Mar 17, 2010 | Kenmore Freezer 14.1 cu. ft. Upright...
Ice maker will not make ice. no ice is being made. no water appears to be in ice cube making area. can hear a ticking noise from icemaker area
Carefully pour water from small glass into ice maker, until the cavity is near filled. Wait a few hours. If it dumps ice, you can usually rule out the ice maker.
If ice maker dumps, then it will be either a bad water valve, Ice building up in fill pipe going into the icemaker, or blocked water line that runs from your water source to the machine.
Caution. If the fill tube going into the ice maker is filled with ice do NOT
use heat such as a hair dryer to melt it. It will melt things you do not want to melt. If it is this problem, you must also replace the water valve because it is leaking slowly causing your problem.
Lastly, in rare cases, the microswitch in the ice maker fails and does not allow water to enter the icemaker.
Oct 22, 2009 | Kenmore Refrigerators
Icemaker noises on almost new GE Profile refrigerator
I have not heard of this issue but if it is coming from the icemaker, then it will have to be replaced. You are still under warranty so call to have them replace it now, otherwise the new icemaker will cost you about $125.
Feb 25, 2009 | GE PDS22SIS Bottom Freezer Refrigerator
Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
(865)945-3808
Feb 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Renault grande senic ticking noise under dashboard
i have a enault traffic 1.9 on an 03 plate, diesel. when i put it into 5th and 6th gear it makes a kinda grinding noise, can anyone help and tell me what this could be. thanks.
Dec 22, 2008 | 2004 Renault 181
Refrigerator is making a loid noise
** the y do sound directly related. water is dripping down your ice maker falling on to bucket? well a small amount of water is also falling onto the evaporator fan assy, freezing and the **ise you hear is that fan blade "cutting" through the ice.you can lift the arm turning the Ice maker to the off position, itll stop calling for water,and your **ise should stop as well
Mar 10, 2008 | Refrigerators
Side by side Kenmore refrigerator
sounds like maybe your water valve for icemaker and door water may be loose take back cover off bottom ref... check out w. valve
Aug 26, 2007 | Kenmore 53642 / 53644 Side by Side...
Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator Logo
130 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
