Question about Amana PTH123B25AJ Heat Pump Air Conditioner
Hisense heat pump wont start cant find agent access to parts
I can start my heat pump on aircon setting but not heat setting. then cuts out. problem is finding someone who can access parts to fix. had a company look at it and first said motor was seized and then it started up but only under the aircon mode. then it cuts out. im being told no one can get parts and buy a new one but would prefer to get it fixed - can any one help me with not only problem but who can get parts for this to be fixed please - thanks
  • brayl Mar 02, 2009
    finally found someone to look at it today and its fine. not sure why it stopped working - but thanks anyway
  • 462 Answers
I have some older AMANA parts books but I'll need the MFG number to look up anything. If you can discribe what it does I may be able to recomend a generic replacement
Posted on Mar 02, 2009
Why would a fuse be independant from the fuse box, and be hidden somewhere where it cant be found,and what does input shorted to the ground.
it means that either the power board in the inside unit is faulty and not sending messages to the power board on the compressor unit
if you didn't get the ac service agent out to do the checks, then any other electrician/ac mechanic will not be trained in the product
if you did get the service agent out then complain to the manufacturer about the faulty service
Jan 13, 2017 | Cars & Trucks
I have a hisense 50H5G and i cant figure why it wont go to 1080. Its says 480 and i have a hdmi cable and hidef channels. Please help
Try to change from your HIDEF output setting from 480 to 1080 if output from HIDEF not proper then your TV also not work at 1080
Jan 25, 2015 | Hisense Televison & Video
My hisense screen wont rotate
Open Quick Settings and tap on Auto Rotate or go to Settings, System, Accessibility, Auto-rotate screen.
Jul 21, 2014 | HQRP AC Power Adapter micro USB Charging...
My aircon weakend
Possibly needs to be recharged or checked for leaks by a qualified Air con service agent.
Feb 12, 2013 | Air Conditioning and Heat for Chevrolet...
Diagram for a Nissan TD27-T fuel injection pump
cant help here and even if you can get a diagram of parts then a lot of them are only obtainable through a official agent ,cant remember the name on the pump let alone pronounce it .Also you will need special tools to get it apart and a even more specialist equipment to set it all up ,try the scrapyard for a runner
Nov 20, 2011 | Cars & Trucks
My Trane thermostat (TCONT600AF11MAA) is supposed to have 1.5 degrees of heat pump "rest" above the desired setting before turning on the heat pump. The thermometer reading does not change yet...
Friend! All thermostat is calibrated to cut in and cut off at the end of - or + 1 degree end.
Example: If you set 23 degree, it will cut off in 21 degree and cut in @25 degree. So accordingly you set the temp.
Secondly, don't set temp near to your room temp.Minimum difference should be 3 degree. If your room temp 12 degree, set at least 15 degree for heat and if room temp 28, set at least 25 degree for cool.
Hope it's helpful?
Jan 02, 2011 | Heating & Cooling
My rc aircon when set to heating cannot sustain the heat & cuts off before it reaches the selected room temp, THe cooling works OK still. Is it the thermostat or something else
check the evaporator coil and make sure it is clear of all dust and debris. run the t stat up to the highest setting and see if the heat cuts off then.
Aug 27, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
No tricks, just make sure its picking up voltage at the same point your compressor is. Make sure the fan is actually a functioning motor.
Nov 08, 2009 | Heating & Cooling
I have a 1995 S420 U.S model, I am the first and only owner. the car only has 20,000 original miles. no accident or even a dint or scratch on the car,maintained regularly. never had any problem . The...
Di he put a tracer dye,usualy green,in when he recharged the aircon?It will usualy show a leak pretty quick,You may have a pressure safety switch thats faulty,usualy screwed into the aircon pump on the high pressure side and if it senses a low pressure problem it shuts the air con down to protect itself.It will have two wires running to it and joining the two wires will reactivate the aircon.Not advisable to leave wired up in this way as the air con charge also lubricates the pump and running it dry will require pump replacement if left running too long.Cant help with air con specialist as im in australia Good luck
Dec 11, 2008 | Mercedes-Benz 420-Series Cars & Trucks
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
379 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
