Question about IBM ThinkPad 600X Notebook
The panel on my 600x works for a few minutes then turns off.
When it it goes out I press Fn-F7 a few times and it comes back on. Not very computer savvy, but is there anything I can do to fix?
  • 2 more comments
  • ggad Mar 02, 2009
    The main panel dies out after a few minutes, whether or not an external monitor is connected and/or selected. Do I have a faulty panel? Software problem?
  • ggad Mar 03, 2009
    Yes I can get an image on an external monitor. It is always available. It's just my laptop panel that drops out after a few minutes. When it does I can barely see an image on the panel, very faintly, as the panel is not "lit". Can it be a problem with the lighting circuitry of the panel? Is there a built-in overheating switch?
    If it is a "problem with the video switching part of the electronics" as you suggest, is that a hardware or a software problem. Can a novice fix it, or do I try to fing a qualified tech?
    Thx 4 your help
  • ggad Mar 03, 2009
    I do not see a redish/pinkish hue, but I do get some very slight flickering, with a slightly dimmed screen. Nonetheless your solution makes alot of sense to me. I'm not sure if it's worth having the CCFL backlight repaired. Might be cheaper to stick with an external flat panel, as I don't need the laptop to be mobile. Thanks for your advice. I think u nailed it!
  • ggad Apr 09, 2009
    Thanks for your help. I'll give it a shot as soon as I can. Where would I buy such an inverter?
    Problem Solver:
  • 18 Answers
Your problem definitely sounds like the inverter - when you press FN-F7 you're restarting it and giving it a mild jolt. Luckily, it is a breeze to replace - undo two screws and pop off the screen bezel and it's just behind the contrast control. Get the service manual for the 600X from Lenovo's website which gives full stripdown details.
Posted on Apr 08, 2009
  • IBM Master
  • 32,281 Answers
There is an external video connector on the back edge of your laptop. When you connect an external monitor or a data projector to this video connector, you can switch the video information between the laptop's LCD screen and the external display on the external monitor or data projector using the Fn-F7 keys.
By pressing it several times you cycle it with various options, these are :-
LCD only
External video only
LCD and external video
Posted on Mar 02, 2009
  • 1 more comment
  • Chris Hingee
    Chris Hingee Mar 02, 2009
    If you can see a display then the LCD screen is OK.
    Can you get an image on an external monitor?
    If you have to press Fn-F7 keys to bring back the display it could a problem with the video switching part of the electronics.
    This may be possible to be repaired.
  • Chris Hingee
    Chris Hingee Mar 03, 2009
    Haaa! now that you mentioned that you see a faint image on the LCD screen, this points to a LCD backlight problem.
    It could be a faulty inverter - It is eaisly replaced or it is a faulty CCFL lamp - most likely this is the problem and it is more difficult to replace (lot more work and requires soldering skills).
    A defective CCFL backlight may has the following symptom:
    • Screen flashs on red/pink and off.
    • Picture stays on in red and slowly be come normal.
    • Picture flickering with dim display.
    • Picture flickering on and off.
    You can fix it yourself or get it repaired. Have a look at
    http://www.lcdparts.net
  • Chris Hingee
    Chris Hingee Apr 09, 2009
    They have details of parts, can select parts by laptop make and model. They also have info for Do It Yourself.
The screen is really dark
Locate the Fn (Function) key on your keyboard. It may be on the bottom left side with dark blue letters. Locate the two "brightness" keys near the top of the keyboard. These will be in the "F" keys, possibly if F6 and F7. They should have little sun pictures or something similar to indicate brightness. Hold down the Fn key while pressing F7, or whichever "F" key your laptop uses to increase brightness. Tap F7 repeatedly until you reach the desired brightness. Fn must be held down as you continue to tap. Hope this helps.
Dec 07, 2012 | Intel EasyNote E4 715 Notebook
Hi I have an aspire one laptop but all of a sudden the screen has stopped working but power is going too the computer please help, do u think it could be a loose conection at a solder point connecting the...
Hi
have you by any chance pressed one of the keys on the top row of the keyboard by mistake
one of those keys will turn on/off the screen some laptops the key is F7 or maybe FN+F7
another option is
turn off laptop
press power on key and at the same time press the F8 key a few times and it may take you into
the repair options and you could try some of those options in there
if none of these work
another option is
press the power key then press ALT+F10 and this may take you into the recovery option
then follow the onscreen instructions
good luck
hope this helped you
Mar 27, 2011 | Computers & Internet
I've tried pressing fn and f7 at the same time and it won't work, neither will any of the other suggestions. And my computer keeps saying that the touchpad is enabled. Is there anything else that I can do...
Try hitting just the F7 key only. I had an issue with an HP Mini laptop and was hitting the Fn and the F7 key and found the key combination didn't work when I pressed both Fn and F7. But it did work when I just hit the F7 key (even though "F7" was written in blue, the same color as the Fn key, it turned out that I didn't need to press Fn and the key for F7 to gain the functionality of the F7 key. HP tech support informed me of that when I called them due to a similar issue I experienced a while back).
Try to hit F7 alone. That may help you out.
As for the touchpad, it should be enabled. (Unless you're using a different pointing device and want it disabled). There are options where you can turn off the touchpad on start up, but I would advise against doing so.
Dec 28, 2010 | Acer Aspire 5315 Notebook
My Canon LV-5210 displays no image for my computer. It has worked fine in the past. And it did not work a couple days ago and then it worked OK yesterday when we accidentently pushed the Input buttom. But...
If your projector displays no image, this could be a variety of problems. First, check that the projector has power. On the top of the LCD or DLP projector should be some lights. With power, those lights will be on. If it has power, check to make sure that the projector lamp is firing. If so, go to the source. Make sure that it is connected with a VGA cable or USB cable to your computer, or with an RGB cable, S-Video cable or DVI connection to your VCR/DVD Player. From a laptop computer, the VGA cable should be connected to the VGA out connection, and into the VGA in connection on the projector. Are both ends tight?
If everything has checked out so far, the solution probably lies with the external monitor port. Check this by holding the Fn key on the keyboard, then press the F7 key. (On some computers, the key might be F5 or F3. Try these if F7 doesn't work) Each time you press the Fn / F7 combination, you will cycle your display through the following settings:
* Press Fn / F2 or F2 once: The laptop screen only
* Press Fn / F2 or F2 twice: The projector port only
* Press Fn / F7 or F2 three times: Both the laptop and projector port
* Wait a few seconds after each time you press the key combination to let the LCD or DLP projector refresh. Nine times out of ten this will result in seeing your projected image.
this should help you :)
Aug 26, 2010 | Canon LV-5210 Multimedia Projector
I can't get a picture when I hook my projector up to my laptop.
HELLO,
If your LCD or DLP projector displays no image, this could be a variety of problems. First, check that the projector has power. On the top of the LCD or DLP projector should be some lights. With power, those lights will be on. If it has power, check to make sure that the projector lamp is firing. If so, go to the source. Make sure that it is connected with a VGA cable or USB cable to your computer, or with an RGB cable, S-Video cable or DVI connection to your VCR/DVD Player. From a laptop computer, the VGA cable should be connected to the VGA out connection, and into the VGA in connection on the projector. Are both ends tight?
* Press Fn / F7 once: The laptop screen only
* Press Fn / F7 twice: The projector port only
* Press Fn / F7 three times: Both the laptop and projector port
Hope this helpout....
Jun 17, 2010 | HP Digital Projector Vp6110 Multimedia...
IBM T61 remains with dark blank screen but is on.
Connect it to another monitor,and see if it comes on. Your screen may be damaged.
Feb 22, 2010 | Lenovo ThinkPad T61 Notebook
Acer Notebook Keyboard is locked
Just hold down Fn then press F7 or F8 keys to unlock keyboard.
Good luck.
Aug 14, 2009 | Acer Aspire 4315 Notebook
Computer used to work with projector, and now doesn't?
Have you tried pressing Fn F5? On my system (HP), by computer monitor goes dark when I connect the projector. Pressing (Function) FN F5 toggles the video between Computer Monitor, Projector, or Both.
Check the function settings for your computer. On my Compaq laptop at home, the video function is F4, so there may be different settings for your computer.
Jan 10, 2009 | Office Equipment & Supplies
IBM ThinkPad 600X Notebook Logo
174 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
