Question about GE DVLR223 Dryers
Need to replace the front felt seal - GE gas dryer
The front felt seal has broken on my dryer. I opened the top and saw it jammed in there. I got it out and can order another but not sure where it goes. Can you explain a bit or give me a hint?
Thanks,
Andy
  • 686 Answers
Since you got the top opened, now look inside the front panel toward top remove screws or hex screws now you can remove the front panel. Undo the door switch wires before removing the front panel. The felt seal should be glued to the front panel aroun the opening to the drum you should be able to tell where it was.
Posted on Mar 02, 2009
How do I get the front panel off a ge mod djsr473et6ww cloths dryer.
GE Dryer Repair - How to Take Apart, Open, or Disassemble ...
? 6:21
https://www.youtube.com/watch?v=AgsOwIwoygc
Feb 22, 2013 - Uploaded by canyonman1963
Tags: GE, General Electric, Frigidaire, Electrolux, electric, dryer, open, remove, take apart ...
Dryer Repair - Replacing the Lower Front Drum Felt Seal ...
? 9:42
https://www.youtube.com/watch?v=XoYP_YsGP68
Jun 7, 2011 - Uploaded by PartSelect
Dryer Repair - Replacing the Lower Front Drum Felt Seal (GE Part .... on this dryer....how do you remove the ...
Nov 03, 2015 | GE Dryers
Brown marks left on clothing -- occasionally My dryer is not gas but electric but that wasn't a choice on here.
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
A piece of felt like material is hanging from the inside (top) front of the dryer. What is this? Can I fix it myself?
The felt is the seal that keeps the clothes from falling inside the dryer. The front of the dryer needs to be removed and the seal replaced (you can glue it back, but this usually means the seal is worn out)
Apr 21, 2010 | GE DBXR463GB Gas Dryer
REPLACE FRONT FELT SEAL WE9M30
On the DPSR610EGWT if you open the dryer door and look at the top of that opening There are two small phillips screws that hold down the top of the dryer. Unscrew those, lift the top and then slide it to the left to remove the top. Next, near the top of the seams between the front and side panels is a screw. Unscrew the small screw and the front will lift off. Be careful because the drum is supported by the front and there are also wires connected on the left. Hope this helps!
Apr 10, 2009 | GE DPSR610EGWT Electric Dryer
Zippers get caught in seal around dryer door and twist around and break off
I had the same problem with zippers and socks. Solution was as simple as replacing the felt seal at the top of the dryer door.The drum rides on the felt seal that has plastic guides imbedded in it. It's function is to seal and more importantly act as a guide for the drum.
Check the drum at the front edge if the gap around it is not the same or if the drum is wobbley when you lift it by hand that is probably the problem.
You will need to open the dryer cabinet. Mine had 2 catch springs at the front top edges that were released by pressing with a thin flat object that will fit between the top and bottom cabinet(butter knife). Once the top can be lifted you may find a couple of screws that secure the front panel and door. Once removed the front panel can be popped off and lifted out (careful of door switch wires).At this point you csn see the felt at the top of the door . It is glued in place and is easily removed. your local appliance part supplier can supply you with a replacement that comes with the glue and installation instructions.
Put the dryer back together and no more burnt socks and ruined zippers.
Jan 22, 2009 | Frigidaire FGQ332ES Gas Dryer
GE Profile Dryer: Felt came off
Jan 14, 2009 | Dryers
Squeaky dryer drum...felt thing came off how to replace it?
Squeaking is cause by the drum bearing worn out and telling the tale. As it get thinner and thinner it begins to rub against the metal outer casing it is embellished in. To inspect it you must rmove tyhe front and get the drum out. Start by opening the the door and removing the screws holding down the top. Then raise the top and get the screws out thathold the front on. Use the rear acces panel(if applicable) to get the idler loose or access that idler from the front.e24a4b7.jpg
Jan 12, 2009 | GE DVL223EBWW Electric Dryer
Front felt drum seal on ge came off---hard to repair?
Open the dryer door. At the top of the door opening, there should be two screws holding the top of the dryer down. Remove those screws and the top will rotate up, giving you access to the drum.
Nov 19, 2008 | GE DBXR463GB Gas Dryer
Felt tub seal
http://www.partselect.com/dryer+ge-open-cabinet+repair.htm
Here is a link that shows how to do this.
Feb 14, 2008 | GE DCCD330EDWC Dryer
GE DVLR223 Dryers Logo
551 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
