Question about KDS Valiant 6380iPTD-01 Notebook
F75 code showing on my vail ecotec pro24 - KDS Valiant 6380iPTD-01 Notebook
  • Anonymous Mar 18, 2009
    I had the same problem. A vaillant engineer came down. It means either there is a leak in the system or the pump has gone. In my case, the pump had gone but it was in warranty, otherwise it would have cost £130 for a new one.
Where is my fuel pressure regulator? how to change it. 2006 chevrolet malibu lt 2.2l ecotec engine.
Most are located on the fuelrail with the injectors or built into the fuelpump assembly inside the fueltank.
Mar 05, 2016 | 2006 Chevrolet Malibu LT
Where is the MAP sensor located on a 2004 Chevy Cavalier 2.2 ecotec dohc?
On your intake manifold, #3 in diagram. My info showed two wires, one is gray, the other is orange with black tracer.
Nov 11, 2014 | 2004 Chevrolet Cavalier
Got a f.75 on boiler have to put pressure up to 2.0 bar before it starts
I take it this is a Vaillant EcoTec boiler? If your having to pressurise to 2.0 before the F75 goes, there's a strong probability there's a problem with the water pressure sensor. These can sometimes just have dirt/sludge in them, and can be cleaned, however a lot of the time they just need to be replaced. F75 can also mean there's a circulation problem through the boiler, and you will get the same fault code. If you have the old rubber hoses on the flow and return pipes, these can be prone to blocking/restricting and Vaillant have actually modified this part whereby by the pipes are solid copper.
Dec 04, 2012 | KDS Valiant 6380iPTD-01 Notebook
Need engine code for vauxhall corsa b 1.2 16v ecotec engine
Corsa b- x12xe
Corsa c- z12xe
I thought the 16v engine started on the corsa c tho so would assume its the later
Aug 13, 2012 | Cars & Trucks
My boiler is showing a f75 error code, can u please help me to fix it
F75 is the pcb not acknowledging the pumping kicking in from the sensor measuring the change in pressure.
Most likely cured by changing the sensor, its a known issue with the Ecotec plus range (I assume that's what you have as you haven't told us). user_offline.png quote.png F75 is the pcb not acknowledging the pumping kicking in from the sensor measuring the change in pressure.
Most likely cured by changing the sensor, its a known issue with the Ecotec plus range (I assume that's what you have as you haven't told us). user_offline.png quote.png F75 could be the pcb not sencing the pump coming on from the sensor measuring the change in presure.
Mar 10, 2011 | Heating & Cooling
My valiant ecotec pro24 boiler wont heat the radiators up,i hav hot water.i just got new meter fitted 2nite+its been 10month since i last used my gas,my pressure is 1.6bar but just cant get heat from...
Have you checked automatic air bleeder on main supply line. I would make sure it is working and bleed each radiator if possible. If you haven't used heat for 10 months I would suspect a build up of air in system. I hope this helps you. Thanks
Nov 29, 2010 | Heating & Cooling
MY VAILLANT BOILER IS DISPLAYING F75.
WHAT IS MY BOILER IS SHOWING F75 WHAT DO I DO?
Nov 28, 2010 | Fedders AEY08F2FCOM Wall/Window Air...
My vaillant ecoTec plus shows F49 , new vrt 360
F.49 eBUS undervoltage Short circuit on eBUS, overload on eBUS or two power sources on eBUS with different polarity F.61 Gas-valve control defective Short circuit/earth (ground) leak F.49 eBUS undervoltage Short circuit on eBUS, overload on eBUS or two power sources on eBUS with different polarity F.61 Gas-valve control defective Short circuit/earth (ground) leak i pasted the answer below hope it worked
Aug 02, 2010 | Heating & Cooling
Vaillant ecotech plus f75 code not firing up
F75 is telling you that the pcb has not recognised the slight increase in pressure that is created when the pump kicks in. I hate to say this, but it is a known issue with the ecotec plus range. Usually cured by replacing the sensor (old ones orange) in the bottom left of the boiler. New versions are now black. Can also be caused by muck in the sensor due to poor flushing when the system was installed.
Feb 26, 2010 | KDS Valiant 6380iPTD-01 Notebook
KDS Valiant 6380iPTD-01 Notebook Logo
265 people viewed this question
Top KDS Computers & Internet Experts
Cleverer2
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
