Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Washer Wont Spin Water Off
I have a maytag neptune frontlaoder. Once it fills once it gets to the spin cycle the water wont empty. Have cahnged timer, control board, check cold water inlet screen. Wife getting upset! need help.
  • JNICE82 Mar 03, 2009
    In connection with the question above where would I find the drain pump? Is that in the basement by the sump pump? Please advise signed .....Desperate husband
I have a maytag too and this is a easy one and you will be so relieved when you get this done!! and your wife is going to love you toooo !! just unplug the machine 1ST then go to the back uncscrew the back panel right at the bottom of the machine is a pump its got a hose from the tub into the pump and then it leaves the pump into another hose to which leaves your home.... you can unbolt this.. take the hoses loose on both ends . Next take that the drain and hoses and wash them out / I found only a piece of paper clip around the little propeller of course i had to replace the pump but really its not that expensive. I got mine on line ebay.... like $ 20.00 but if you are lucky then you can clean that good. I even went as far as taking it apart a total of 10 minutes tops, just to find out what could be letting this not spin.... maybe yours wont be so tramatic but if it is be relieved when you know it was this simple to fix !!! good luck to you and yours.
Posted on Mar 04, 2009
  • Maytag Master
  • 3,361 Answers
The obvious place to check would be the drain pump and the drain pump motor.
Disassemble the drain pump and check for a blockage.
Make a jumper wire and connect to the drain pump motor to make sure it works.
Then report back.
Posted on Mar 01, 2009
My neptune won't spin during the spin cycle Water left in the basin clothes are soaked
could be a bad pump or something in the pump like a missing sock it wont spin unless the water is pumped out
Nov 18, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptun will not agitate or spin
Change your timer. or timer sensor. behind your knobs
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH-1 won't stop filling with water
A couple things may be going on here... you may not want to hear, but the Neptune has a had many "consumer related problems".
If your complaint is "will not stop filling with water" I would access your inlet water-valve (typically blue with 2 black battery looking solenoids; where your water-lines connect directly), test for continuity and replace as necessary. Sometimes inlet-water valves also go bad where the complaint is: "no water comes in at all".
Jan 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH4000AWW
I SAY REPLACE TIMER (POWER CONTROL BOARD)
Jan 15, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune on/off button wont stay on
You have to investigate where the burning smell came from. Start at the timer and then check the main board. Also check the drain pump.
Oct 23, 2007 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune doesn't spin at end
Of course, did you find anything clogging your outlet filter, this is most likely the problem. The outlet filter needs periodic cleaning, according to your usage.
Jun 18, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
200 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
