Question about Panasonic CQ-C1303U CD Player
Reset clock I have a Pioneer clock radio in my 1996 Roadmaster buick stationwagon. Had to put a new battery in the car today, and can't figure out how to reset the clock in it. Thanks for any info. Louise
    Novelist:
  • 149 Answers
Go to this weblink and click on the link at the bottom that says operating instructions. It will pop up with the entire manual for how to fully operate the system including settingthe clock.
http://www.generalmanual.com/Audio/Panasonic-CQ-C1303U-CD-Receiver.htm
Posted on Mar 01, 2009
How do you remove a factory radio in a 1996 Buick Roadsmaster?
Here is av full walktthru on youtube:
https://www.youtube.com/watch?v=U_-ECgi1_ag
Hope it work, looks fun!
Best /THomas
Oct 02, 2014 | 1996 Buick Roadmaster
Buick roadmaster problems
Check your fuse to your blend door actuator. If it's good your actuator's are not working.
Dec 16, 2013 | Cars & Trucks
Heating problem: I have a 1996 buick roadmaster wagon 88,000 miles. sat in garage for years so we've put a new starter in it, new thermostat, radiator is great, flushed it both ways, maybe the vent? anyone...
Sounds like you need a plumber. Check the water flow through the heat exchanger, you may find it only needs flushing through or the blades on the water pump are corroded away.
Sep 06, 2017 | 1996 Buick Roadmaster
I have a 1993 Buick Roadmaster Limited Edition (not stationwagon). The battery, and alternator are brand new, but it won't start. I know it's not the battery because when you go to start it, you can feel...
The throttle body should be cleaned. There are sensitive wires in there that can be damaged if the proper spray cleaner is not used. Have a diagnostic test done on it to pinpoint the defective parts.
Mar 20, 2017 | 1993 Buick Roadmaster
If clock resets every time the car is cut off on 96 buick century what can be wrong. already has new battery and alternator. car wld not start and had to jump it off.
the memory power wire has a blown fuse ...the car has a hot wire going to ground sounds like it maybe behind the radio
May 08, 2010 | 1996 Buick Century
Hey
Try pushing the gas pedal to the floor three times with the key on the on position but, the motor off.
Jan 28, 2010 | 1996 Buick Roadmaster
Hi, I have a 96 buick century,if i dont use it battery goes dead
The radio in my 1996 Buick century had a clock light that did not go off when the car was shut off, so the battery would go dead after 2 days. Disconnected the radio and all was well. Getting ready for a new radio now.
Nov 03, 2009 | 1996 Buick Century
96 Buick roadmaster= interior lights stay on while driving
Check to see if the over head light has shorted to ground. EG: touching roof, from weight being put on the roof. EG: Cargo hauler.
Jun 01, 2009 | 1996 Buick Roadmaster
94 buick roadmaster... new battery new starter... -4degrees.....when i turn switch, i just get a ka-tink sound put heater under hood did not help
first thing is make sure your battery connections are clean, a little corrosion can cause a lot of problems at these low temperatures. make sure that the other ends of the battery cables are clean too. Hope this solves your problem.
Jan 16, 2009 | 1994 Buick Roadmaster
Need to know how to change an outer tie rod on a 96 buick roadmaster
you will need to back off on the lock nut on the tie rod end then remove the tie rod end from spindle turn tie rod counting the number of turns to take it off put new tie rod the same number of turns put back in spindle and tighten lock nut your steering wheel will probably be off center so you will need to have the toe reset on the alignment machine
Oct 05, 2008 | 1996 Buick Roadmaster
Panasonic CQ-C1303U CD Player Logo
131 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
