Question about Whirlpool 21.7 cu. ft. Side-by-Side Refrigerator ED22PQXF
Hotpoint csx22bc 21.7 cu. ft. leaking water on freezer side
Side by side freezer leaking from the freezer side.... notice glaze of ice at bottom of freezer side but no standing water inside..... has automatic ice maker which does not appear to be leaking from the tubing or water connection.... water puddles on the floor on the left front side of the freezer side (looking at the unit from the front) ....... will go for a couple of days without leaking onto the floor then all of a sudden a puddle of water will appear
  • 1 more comment
  • Anonymous Mar 14, 2014
    leaking water from freezer and water freezers in bottom of unit
  • Anonymous Mar 23, 2014
    The bottom freezer appears to be leaking. Inside the freezer floor has a frozen water puddle. In addition every other day or so I see water seeping from the bottom right and left corners of the floor. Not sure what is happening.
  • Anonymous Mar 24, 2014
    bottom freezer floor solid ice and leaking on floor
    New Friend:
Thank You,Thank You, Thank You. Need not call a repairman today. I did as you said and wala. I love the internet, but even more I love the kind people that offer their knowledge to help a person. There is not enough of that kind of camaraderie left in this world. Thanks again KayCee
Posted on Aug 24, 2013
  • 25 Answers
Look for obstruction at the drain tray for the freezer. Common to have plastic wrap sucked into that area.Or gunk in the drain line. Blow through line to insure the gunk is not an issue.
Posted on Mar 01, 2009
2 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: leaking hotpoint 21.7 cu. ft. csx22bc
Your defrost drain outlet is frozen over.
Turn off the fridge.
Remove the bottom drawers.
Look in the back section just below the back freezer panel and you will see an ice dam.
This must be defrosted. Use a hair dryer.
Once all the ice is gone pour water into the drain to make sure it is clear.
Then pour a 1/4 cup of bleach in the drain.
Turn the fridge back on and you will be OK until it happens to stop up again.
What are the dimensions of the kenmore elite 22.4 cu.ft. bottom freezer refrigerator?
26'wide X 19" deep X 21'' front to back. I'll never have a side by side again!
Jul 04, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water comes out from the bottom of the Freezer side of the refrigerator....
the defrost drain tube is clogged, located at the bottom of the back wall inside freezer. Use a hair dryer and hot water to rid the tube of all ice.
Jul 05, 2010 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Leak
Sounds like you have a clogged drain the water freezes melts during defrost. You have to take the freezer floor out. to clean the drain.
Apr 27, 2010 | Hotpoint  16.6 Cu. Ft. Top-Freezer...
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Aug 04, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Hotpoint FZA80 freezer: water leaking
There's a drain hole inside the freezer in the bottom of the back wall ;probably is clogh .Put hot water into it to melt the ice and then blow it with air pressure;keep it clean pouring bleach throught it every 2 or 3 months.
Jul 18, 2009 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Water drip from freezer to refrigerator
Defrost drain line in the freezer is frozen shut.
Remove the freezer panels.bottom and back panels.
Remove the visible ice.
Take a hair dryer and thaw the drain hole in the center rear drain trough.
Mar 12, 2009 | Hotpoint 18.2 cu. ft. Top Freezer No-Frost...
Leaking hotpoint 21.7 cu. ft. csx22bc
Mar 01, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
Freezer leaking water
The drain is plugged just below the coils in the back of the freezer. My fridge had the same problem and I found the hose (which can be accessed from the rear bottom) was plugged with mold. Also, i noticed the hose was connected to the water holding pan and was too close to the bottom and easy to plug. I removed it from the connector and just let it dangle in the holding pan.
Aug 30, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerators Logo
755 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
