Question about Dometic Rooftop RV Air Conditioner
Can you tell me what type of refrigerant is in my a/c it is a 15 k btu dometic brisk air roof top unit and is about 4-5 years old.I can't find it on the unit also how much will it hold and if its not 134 a can it be converted
  • Ken Bledsoe May 11, 2010
    Really hard to tell what kind of refrigerant is in unit I would think R22 and it should have a data plate might have to take off the top protective cover to see data plate. On the data plate it will tell you type and amount that inside the unit.
    Guru:
  • 462 Answers
USUALLY its R22. DO NOT USE ANY REFRIGERANT TIL YOU KNOW IT NEEDS IT THOUGH. The plate is usually inside the top cover and you can read it after removing the cover. If its a 110or 220 AC unit Im almost sure its R22. And the weight listed will be the most you should try to put in it. BUT before you do that you have to put on a piercing valve. And the pressures are higher for R22 than R134A. It will ofcourse depend on the outdoor and indoor temps as to what pressures youll be running as well as fan speed. Freezing is 57-58psig on R22 so the pressure after ruinnign 10 to 15 minutes has to be greater than 57 or 58 PSIG. It is normal for some units to run for a while at a lower pressure when 1st started though so dont jump the gun.
Posted on Mar 02, 2009
What code is E-7
loss of 120 volts to relay module
Jun 14, 2015 | Brisk Air Dometic A/C Roof Top Air...
Can you recharge. a dometic a/c rooftop unit serial number 991762724
No service ports on the unit. It needs to have a service port soldered to it and the system breached before you can check / charge.
Aug 29, 2014 | Brisk Air Dometic A/C Roof Top Air...
Why would a Dometic 13500 rv rooftop A/C runs fine when plugged in to normal power but when hooked up to a 4000 w gen.runs for a while then kicks breaker have tried on 2 different generators any ideas
Are both the test breakers the same size (15A or 20A, etc)? Perhaps the breaker in the RV has a lower amp rating then the other one you are testing it on? If that's the case your test doesn't really tell you anything, they both need to be the same size to know where the problem may be.
Aug 08, 2014 | Brisk Air Dometic A/C Roof Top Air...
Fan not blowing in coleman trs rv roof air
well check a few things first....have someone remove the cover and reach in with a hand and try to manually spin the blade...free spinning?....then tell the person below to click in the on postion while someone views from up top.....is it humming? or even trying to spin?....if not check the fuse on the RV that protects the A/C unit.....good?.....now replace the capacitor ( it the silver or gray can looking thing that the motor wires run to) only the correct size will work w/o causing further motor damage.
Jul 08, 2010 | Dometic Rooftop RV Air Conditioner
AC compressor won't start
hi,you might need a new compressor...you will need need to go back were you bought capacitor...buy a hard start capacitor too..this might crank the compressor...hope this helps.if you buy it..call an ill tell you how to wire it...if it dont ,you need new compressor...call michael..doctor airr..appl.repair...843-384-8474...
Mar 27, 2010 | Dometic Rooftop RV Air Conditioner
Fan blades on dometic brisk air needs to be replaced
Roof top cover will have to come off, to get accesss to it. Not too hard to do, but may want to spray shaft in area of blade with WD_40 or similar to remove rust , and make on & off easier. Here's a link to dealer locator for Dometic. Any dealer should be able to get you a new one pretty quick, or most even have used ones from units previously removed from RV's if your stuck. ( http://www.dometic.com/enus/Americas/USA/Customer-Support/Dealer-Locator/ )
Jul 25, 2009 | Dometic Rooftop RV Air Conditioner
Btu for dometic 59516.531
59516 is a Brisk Air 15000 BTU.
Thanks for using Fixya
Jerry
Mar 29, 2009 | Dometic Rooftop RV Air Conditioner
2000 roof-top Brisk-Air
I think you have a high pressure cutoff cycling the compressor on and off. Clean the filter inside the unit. Then with a hose clean out the foil condenser filter on top of the camper. Also you may need to buy a coil comb and comb out bent or damaged areas of the condenser coil on the unit that is above the roof of the camper.
Jun 09, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
579 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
