Burner won't work with my Acer aspire one netbook
Have acer aspire 5315 ,dvdram not working error code 39 comes up for hl-dt-st dvdram gsa-t40n ata
I am tryingto burn music to the HL-DT-ST DVDRRW GSA-2166D from an acre aspire one netbook. I am using Nero and when I attempt burn the songs, the software says that any disc I oput in the drive is not empty? ANY HELP, PLEASE????
    President:
  • 2,653 Answers
This seems to be going around a lot lately.
If you follow these steps from Microsoft it should fix the problem.
Let me know if you need any other help and please don't forget to rate my solution.
Thanks!
Manually delete the registry entries loadTOCNode(2, 'whattotry'); Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base: 322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in WindowsNote Before you use this method, uninstall all CD or DVD writing or recording programs. Deleting the corrupted registry entries might cause problems with any other CD or DVD writing or recording programs that are installed on your computer. Uninstalling these programs before you start will help you avoid any problems that removing the registry entries might cause. You can reinstall these programs after the problem is resolved.
This method provides step-by-step instructions for how to use Registry Editor to delete the following corrupted Registry entries:
  • UpperFilters
  • LowerFilters
Step 1: Start Registry Editor loadTOCNode(3, 'whattotry'); Start Registry Editor. Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'whattotry');
  1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
  2. Expand SYSTEM, and then expand CurrentControlSet.
  3. Expand Control, and then expand Class.
  4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
  5. In the details pane of Registry Editor, on the right side, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only.
    • If you see the UpperFilters registry entry in the details pane of Registry Editor, go to step 6.
    • If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to "Step 3: Delete the LowerFilters registry entry."
  6. On the Edit menu, click Delete.
  7. Click Yes when you receive the following message: Are you sure you want to delete this value?
The UpperFilters registry entry is removed. Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'whattotry');
  1. In the details pane of Registry Editor, on the right side, click LowerFilters.
    Note You might see a LowerFilters.bak registry entry. You do not have to remove that entry. Click LowerFilters only.
    If you do not see the LowerFilters registry entry, unfortunately this content is unable to help you any more. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  2. On the Edit menu, click Delete.
  3. Click Yes when you receive the following message: Are you sure you want to delete this value?The LowerFilters registry entry is removed.
  4. Exit Registry Editor.
Step 4: Restart your computer loadTOCNode(3, 'whattotry'); Restart your computer. After you have done this, try to access the CD or DVD drive. If you can access the CD or DVD drive, and if you do not receive an error message, the problem is resolved. You can reinstall your CD or DVD writing or recording software.
Posted on Mar 02, 2009
HL-DT-ST DVDRAM GSA-T20N ATA DEVICE error code 10
Here is a nice resource that should help you with this problem.
error code 10
Oct 08, 2009 | Acer Aspire 5315 Notebook
Dvd driver noy found
There is a Microsoft KB article on this subject. Here is the link :
http://support.microsoft.com/kb/314060
Just follow the instructions and it may solve your problem
Jun 09, 2009 | Computers & Internet
HL-DT-ST DVDRAM GSA-T40N HAS TAKEN OVER MY DRIVER.
Try going into your "Tools" & then into "Internet Options" click on "Programs" (tab) then @ the bottom click on "Manage Add-ons" then go to "Internet Options" (again) "Advanced" (tab) & at the bottom click the "reset" then restart your computer.
Good luck to you! Hope that helps
Jan 26, 2009 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
294 people viewed this question
David Payne
David Payne
