Question about Fisher Dishwashers
Need to know what kind of problem this is?
Fisher and Paykel Dishwasher Stainless Steel Double Drawer.
Model DD601 v2.
System powers up, but getting U2 error on dishwasher display. What does this mean? how much would it cost to get repaired? Also a hose needs repacing according to one of my friends,is this expensive?
  • layns1981 Mar 06, 2009
    Didnt quite answer my question. please somene else let me know.
    Thanks
  • layns1981 Mar 07, 2009
    Thanks.
  • 408 Answers
You can replace it yourself and get the part from an appliance dealer for about 10-20 bucks.  If you don't want to, you can get it fixed for around 50-60 bucks.  Hope it helps.
Posted on Mar 06, 2009
    Scholar:
  • 85 Answers
The prime suspect in this case is always the drawer limit switch. On the DD602's, the limit switch is located on the very back of the left drawer guide which means.to remove the switch the drawer needs to come out.
and for further instruction on how to do it manually without calling repair person just click this link and read the instructions and follow them properly
http://fixitnow.com/2004/10/appliance-repair-revelation-fisher.htm
thanks please do rate the solution if helped by it accordingly.
Posted on Mar 01, 2009
    Scholar:
  • 150 Answers
According to http://www.scribd.com/doc/6462163/DD601V2-Manual, the dishwasher thinks that the door is open. This means either that the microswitch has failed or the exhaust valve failed open circuit. Neither of these should be very expensive to fix. Your friend might be wrong or he might be right, if it's the microswitch then it'll be pretty cheap since it's a small part, or if he's right then it could be a little more, but still very reasonable.
Thanks for visiting Fixya.
    Scholar:
  • 165 Answers
First of all unplug the machine from poweroutlet and plug it again after some time and check wether the error goes away.if the error is still there.just check the door is getting closed properly or check if some button is stucked up.also you asked about the hose.its not much expensive .thanks.
  • Fisher Master
  • 19,396 Answers
Check the door latch.
    Sergeant:
  • 250 Answers
First unplug the dishwasher for couple of minutes from the main power outlet and check out.
Double dishdraw ss has ongoing bad residual odour problem on contents despite full and regular clening any suggestions
Buy Finish dishwasher cleaning kits from super market and clean each drawer according to the instructions on the kit.
Jan 07, 2013 | Fisher and Paykel DD605FD Stainless Steel...
How much is service and maintenance of Fisher Paykel bottom draw that does not work
THere could be lot of reasons for the drawer not to work. Need some description of what is happening before making any suggestions. If there are no lights on the panels then the controller or controller power is faulty. Could cost upto $300 to fix this.
Jan 03, 2013 | Fisher and Paykel DD605SS Stainless Steel...
Fisher & Paykel DD601v2 dishwasher
here's the manual..
i did not read thru the whole thing but there are quite a few removal items that i'm sure will lead you to drawer removal.
Hope this helps you.
https://www.scribd.com/doc/6462163/DD601V2-Manual
Jan 22, 2018 | Fisher and Paykel Dishwashers
Fisher & Paykal Refrigerator. E 522 B Plastic piece in door hinge fell out . Door now travels around and has big dent in front panel. I need to replace outer stainless door panel and plastic piece in...
The plastic piece that is moulded to the inner door that holds up the shelf on a fisher & paykel fridge has cracked and no longer holds the shelf. Can I buy a new door liner or does the whole door need to be replaced?
Jan 29, 2011 | Fisher and Paykel E522BRXFD Stainless...
Fisher and paykel dishwasher drawer adjustment instruction
HI- There is no adjustment for the drawers themselves, they just sit where they sit. If you have a more specific issue please repost. Thanks
Aug 09, 2010 | Fisher and Paykel DD605FD Stainless Steel...
Need to remove front drawer panel
There are two plastic bolts on each side of the dishwasher drawer holding the front cover. Get a plier to pull these out but make sure the cover is supported so that it does not fall down.
see installation manual page 7. The location of the plastic screws is shown in insert diagram of notation 6. This is for a later model but yours should be similar.
Hope this helps. Wonder why you want to remove the front cover?
Jul 07, 2010 | Fisher and Paykel DishDrawer DS605FDSM...
F&P DD601 TOP DRAWER IN ALARM F3 , ANY IDEAS?
F3 alarm in F&P DD601 is linked to water temperature. If you are using cold water supply connection, then it is likely the heater unit or temperature sensor has gone faulty. If you are using hot water supply direct then the inlet water temperature is exceeding recommended range of approx 65deg C. DD601 is a fairly old unit and not sure if you can still get some parts.
Nov 05, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Dishdrawer DD601 v2 Error F1 on the bottom draw.
Below is the link to the service manual
This will be able to explain the problems better that I can in the tiny space I get to write in.
Mat
Please rate me
Mar 15, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykell DD601 V2 Top Drawer Overflowing
I suggest pressing the keylock and power button together, hold for 5 secs, the display will change orange, the display should read HP if it says LP, press the start button to make display read HP.Then press power button to store. You will need to manually removed the water from the machine before restarting
Jul 03, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
Top Fisher Dishwashers Experts
Tony Houde
Tony Houde
George Merkley
George Merkley
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fisher Dishwasher Expert? Answer questions, earn points and help others
