Question about Directv RC32RFK Remote Control
I have an Insignia NS-H2002 Home Theatre System...
I need the DirecTv Remote Code for it, I tried a Code search and all the DVD and STEREO codes on the receiver. I work for DirecTv and I know what I am doing, just curious if anyone has the code for it? Thank you.
em0ti0n1
  • 35 Answers
SOURCE: need code for Directv remote for 26LG Flat Screen TV
Program TV Code
1. Turn on the TV.
2. Locate the 5-digit code for your TV.
3. Slide the MODE switch to the TV position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
Program DVD, VCR, Stereo Receiver, and Stereo Amplifier Code
The AV1 and AV2 switch positions can be setup to control a VCR, DVD, STEREO, second DIRECTV Receiver or second
1. Turn on the component you wish to control (e.g. your DVD Player).
2. Locate the 5-digit code for your component.
3. Slide the MODE switch to the AV1 (or AV2) position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under AV1 (or AV2) flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of component being set up. If performed correctly, the green light under the selected position flashes twice.
6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Repeat steps 1 through 6 to set up a new component under AV2 (or AV1).
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
Verifying the Codes
Once you have set up the DIRECTV Universal Remote Control using the above steps, use the following instructions to find out the 5-digit code to which your component responded:
1. Slide the MODE switch to the appropriate position.
2. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
3. Enter 9-9-0. (The green light under the selected switch position flashes twice.)
4. To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down.
5. Repeat step 4 four more times for the remaining digits; i.e., press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.
Depending on how you set up your remote, the VOL and MUTE may control the volume only on your TV, regardless of the position of the MODE switch. This remote can be set up so that the VOL and MUTE keys work only with the component selected by the MODE switch. To enable this feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
2. Using the number keys, enter 9-9-3. (The green light will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light flashes 4 times.)
Now the VOL and MUTE keys will work only for the component selected by the MODE switch position.
To Lock Volume to AV1, AV2 or TV
1. Slide the MODE switch to the AV1, AV2 or TV position to lock the volume.
2. Press and hold the MUTE and SELECT keys until the green light under the selected switch flashes twice and release both keys.
3. Using the number keys, enter 9-9-3. (The green light flashes twice.)
4. Press and release the SELECT key. (The green light flashes twice.)
Posted on Jan 14, 2009
  • 86 Answers
SOURCE: I have a Oritron DVD player,Need Dirctv remote Code for DVD Playe
Try calling Oritron. If you are lucky, your DVD player is simply a rebadged model from a major manufacturer and there may be other codes they can suggest.
Posted on Mar 24, 2009
  • 10 Answers
SOURCE: code for directv remote control
The following code should work with your model. 11394
Setup Instructions
  • Set the "Mode Switch" to TV.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the 5 digit Code above.
  • Try your code.
  • These codes may also work:
    10180 10177 10236 10185 10039
    10179 10282 10463 11963 10171
    10178 11944 11911 10270 10280
    10623 11661 10158 10181 10183
    10017 10182 10451 10002 10019
    10038 10154 11928 11929
    Posted on Sep 09, 2009
    Macklintok
    • 122 Answers
    SOURCE: Have a Coby TFTV3225 and
    This a link to the direct TV rome code look up should be able to give you what you need
    Direct TV Remote Control Code Look up
    Don't forget to Rate if I helped you :-)
    Posted on Sep 17, 2010
    • 22 Answers
    SOURCE: need remote code so that
    Hi there, I entered your equipment info into a code search web site, and got the following back. Hope it works! nox.gif We could not find an exact match, we think this code will work. 30321
    Setup Instructions
  • Set the "Mode Switch" to AV 2.
  • Posted on Feb 12, 2011
    I need the remote code for an Insignia NS-H2002B
    Review your universal remote control user manual for available codes. If there are none, try those for Sherwood. If you still get no result, try your universal's scan feature to find a code.
    Jun 15, 2010 | Insignia NS-H2002 Theater System
    Insignia NS-H2002-U. can i burn an avi to disc and
    Just get this tool to help you.
    1. load your file to Video Sharer
    2. choose vob format
    3. click" convert" button.
    Then you will get the right format.
    Here is the tool for you: http://www.asharer.com/download-video-sharer
    May 31, 2010 | Insignia NS-H2002 Theater System
    Need an installation and owners manual for a ns-h2002b where can i find this online free?
    http://www.technostation.com/user-guide-owners-manual/Insignia/Insignia+NS-H2002B+Home+Theater+
    Mar 18, 2010 | Insignia NS-H2002 Theater System
    Need DirecTV universal remote code for Insignia NS-DXA1 converte
    Most universal remote controls have a scan feature to find a code where one is not available. If this process doesn't work, additional assistance may be found at Community.InsigniaProducts.com.
    Jan 30, 2010 | Universal Remote Control DIRECTV Universal...
    No sound from speakers on my Insignia NS-H2002 Theater System. heard a loud pop, nothing else.
    Very hard to know without actually seeing this first. You may have blown an internal fuse. Or, it simply may have died prematurely (if new and under warranty)
    Sep 09, 2009 | Insignia NS-H2002 Theater System
    No surround sound through tv
    May be you have to set the Pro-logic option soundfield, this will matrix a 5.1 surround sound effect, unless of course you are sending a Dolby Digital 5.1 audio signal from your TV broadcast into the Home theatre system, also have to check the TV audio output to send audio output to a Home theatre system in other than 2 channel stereo.
    Feb 09, 2009 | Insignia NS-H2002 Theater System
    Broken remote for insignia NS-H2002 home theater system
    When you do buy a universal remote if there is no Insignia codes in it you will have to use the Sansui codes for insignia products.
    May 01, 2008 | Televison & Video
    Directv RC32RFK Remote Control Logo
    152 people viewed this question
    Top Directv Televison & Video Experts
    john milligan
    rundiggity
    Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
