Question about HP Computers & Internet
Memory on HP ipaq 114.
My PDA is running low on active memory so I have installed a 1GB storage card but this is not being used and built in memory continues to gradually disappear. How do I get to use the 986mB?
  • 1,223 Answers
There are two types of memory my friend
1. RAM
2. ROM both built in PDA
third type is Storage Card u can store music and photos there but u cannot merge it with RAM or ROM so pls try to understand this difference
secondly if u want me to help u out on this memory shortage
then u can reset the device i mean hard reset and re install ur applications by time ur ROM is occupied by some useless files and ur performance is de graded try to refresh ur OS
Hard reset
HP iPAQ Setup Assistant
Use HP iPAQ Setup Assistant to simplify configuring settings on your HP iPAQ.
HP iPAQ Setup Assistant lets you save the settings on your computer. This can help you restore configuration settings on your HP iPAQ at any time. HP iPAQ Setup Assistant also allows you to perform a factory reset on your HP iPAQ and view detailed product information.
To hard reset HP iPAQ 114:
- press and hold the 3 buttons Windows, OK and REC
- press the reset button for about 3-4 seconds and release it
- release the 3 buttons
u can see the video for that but it is in russian lang but self explanatory
third option is if u want to really get rid of this slow performance and shortage of space just get a clean CUSTOM ROM from for ur PDA strictly at ur OWN RISK
pls rate me fixya if i have fixed ur problem
Posted on Mar 02, 2009
Just bought 4GB SD card that hx4700 does not recognise - help pse
Your slot in the iPAQ is a SD slot, not a SDHC slot - therefore it will not read the card. Your PC card is probably a dual reader. The SD cards look the same but are different. Have a read of this...
Dec 10, 2008 | HP iPAQ HX4700 Pocket PC
HP IPAQ H4150 + Memory Cards
Your HP IPAQ has a SDIO expansions slot...
which is a new technology.
so will have to use an SDIO card ...
this is a secure digital IO card.
hope this will solve the problem
Oct 30, 2008 | HP iPAQ H4150 Pocket PC
HW6910 PDA - GPS Map problem
It needs to be in the same place as the map you have, but in a new directory ; e.g. "GB" as well as Southampton.
Easy way out to to load it using TomTom Home...
Dec 10, 2008 | HP iPAQ hw6515 Pocket PC
HP ipaq with navtec gps software and sd card fails
Ok, nice job Robert,
I'm posting your solution here to remove it from the unsolved problems list.
Solution by Robert:
This problem was finally resolved as a corrupted map file on the SD memory card in the hp ipaq 5550. Solution was to reformat the memory card using fat32 memory format. I used a SD memory card slot on my laptop and right click the drive letter and select format to format the memory card. After that, I reloaded map files to the memory card and all was OK. Note that previously I had loaded map files on the memory card successfully but that was not good enough. A reformat of the memory card was apparently needed.
I had also previously tried a hard full reset of the ipaq by pressing and holding the lower two buttons (calendar and itask) while holding in the reset button with the stylus for 5 seconds and resynced my contacts and reloaded the gps software, but this was to no avail. Try the re-format.
Jun 22, 2008 | HP iPAQ H5550 Pocket PC
What's max mem size for ipaq 1950
Mem cards are added as storage cards and do not add up to your iPaq RAM.
You can use mem cards to add up space to install applications. (ie. it is something similar to installing a new Harddrive on your PC). However the physical RAM of your iPaq cannot be extended.
PocketPC programs have small RAM requirements so your PDA's built-in RAM will suffice.
As far as the maximum card size if I understood your question right, if your iPaq comes with Windows Mobile v5 or earlier, it supports SD cards up to 2GB and perhaps some non SDHC standard SD cards up to 4GB. If you can upgrade to WM6, then WM6 supports SDHC cards, so you can install >4GB cards.
Hope this helps.
Feb 16, 2008 | HP iPAQ rx1950 Pocket PC
HP ipaq rx3715
Have you tried other SD cards?  The box is uncheck for default install folder?  Maybe update the device.
Oct 13, 2007 | HP iPAQ RX3715 Pocket PC
Ipaq H 3970 storeage card problem
Try soft resetting the unit, then try to access it afterwards. Hope that helps
Apr 25, 2007 | HP iPAQ h3970 Pocket PC
Storage Memory
memory card isn't really memory it's more like a disk drive. it's not like when you add memory to a PC and the new memory is automatically used. To make use of this card you need to transfer some of your larger files to the card.... You can move files from within the ipaq... Click and hold on file. Select Copy Click and hold Select Cut Navigate with File Explorer to the SD card.... Open File Explorer Select My device Now select SD Card You can create a new folder or select an existing folder Click on Edit at bottom of screeen. Select Paste. You can also move files directly from PC to Storage card...... While IPAQ is connected, go to My Computer, then double-click on Mobile Device, then double-click on Pocket PC. Now you will see your Storage Card, and you can use this just like a folder on your PC. You can create folders within it. You can click and drag files to it or to any of it's folders.
Sep 07, 2005 | HP iPAQ H4150 Pocket PC
Increasing Memory
The bad news is that many of the programs you might like to do away with are built into the ROM, and can't be deleted. The good news is that most programs will run perfectly well if installed on the storage card, so if you've got programs installed in main memory, you can realize some savings by running them from the storage card instead.. If you go that route, be sure to Remove the program from main memory and then re-install it to the storage card.
Sep 07, 2005 | HP iPAQ RX3715 Pocket PC
Computers & Internet Logo
653 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
