Question about Linksys Wireless-G WRT54G Router
Connect two wrt300N v1.1 linksysrouters,with some overlap
I have two linksys wireless routers,I want to install to small company with out any cable. how could I syncronize these two routers,or I think 10 % overlap ( I want extended service set(ESS)).
I need the step by step procedures. my client company has different floors(200 meters difference from end to end).
My routers can go up to 100 withour attenuation.so I want them to syncrhoize both so that they can aford me what i want( 200 meters).
Thank you very very much for your corporation
feysel from ethiopia
  • Pawel May 11, 2010
    the easiest way would be to set one of the routers as a router with Internet connection and the second one will work as an Access Point.
    However depending on environment you may have problems with WiFi range then you can connect the routers with Ethernet cable (maximum 100m).
  • Chuck May 11, 2010
    are you familiar with the setup pages via 192.168.1.1?
  • 404 Answers
Hi Feysel! cascading a router to another router is possible. here is the link so that u can follow the step by step procedure..
1.How do I connect my router to another router?
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3733
I hope this will help solve ur concern
Posted on Aug 16, 2009
How to set up Linksys WRT300N Wireless Router
To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security b>
Aug 30, 2011 | Linksys WRT300N Wireless Router
My WRT300N Linksys router shows all lights, I've hit the reset button onece, but I can not get online without plugging the cable directly into my computer.
Since you hit the reset button on the router, it will go back to default settings.
By default, the SSID is linksys and the wireless security is disabled.
So on the wireless network connections on your computer, you should see linksys and then just connect to it.
However, it is advisable to change the default SSID and to enable the wireless security.
Follow this link to change the SSID.
Follow this link to enable wireless security.
Dec 30, 2009 | Linksys WRT300N Wireless Router
I just rewired all my network connections, my wrt300n wireless indicator is not lit. The network is set up on a linksys broadband router on a cable modem and wrt300n was functioning properly when it was...
Try first resetting the router by pressing the reset button of the router fro 10 seconds while power is ON and then after that reconfigure the router.....
Dec 07, 2009 | Linksys WRT300N Wireless Router
Linksys wrt300N wireless light not blinking
the wireless connections says limited or no connectivity when it does not get IP address from the router.
There might be problem with the wireless settings of the router.
if your network is a secured network then you will need to check the network key.
You can try to upgrade the firmware of the router. that will be a good option.
Click Here for step by step solution
Oct 29, 2009 | Linksys WRT300N Wireless Router
How do you connect the new PSP Go to Linksys WRT300N router?
On the PSP make sure the WLAN Switch is turned on. To connect to your router, go to System Settings > Network Settings > Infrastructure Mode then select the Network that you want to connect. If it's Linksys, select Linksys and press X. Select Scan and choose the wireless network and Enter. If it asks you for network key, type your wireless network key and connect. That should do it.
Oct 06, 2009 | Linksys WRT300N Wireless Router
WRT300N is no longer detected
Hook up your ether cable to a port other than the WAN port.
Type this into a browser...
http://192.168.1.1
Linksys WRT300N Wireless Router. ... Default IP address: 192.168.1.1
Oct 01, 2009 | Linksys WRT300N Wireless Router
Linksys WRT300n will only allow local access wirelessly
go into the router interface and see if it is set for DHCP and reboot systems it should be fine
Jul 17, 2009 | Linksys WRT300N Wireless Router
Support
Try these steps:
1. First of all connect your PC Directly with Modem & check if you're able to go online or not.
2. If No , then contact your ISP.
3. If yes ,Disconnect CAT5 cable coming out of Modem from PC & connect into WAN port (on rear panel you'll find it) of Linksys WRT300N Router , After that on rear panel you'll find small hole with a Reset button inside it. Use needle or pen to press it quiet hard for 1 minutes continuosly, This'll restore all default settings.
4. After that give static IP - 192.168.1.2 to your PC ,subnet mask 255.255.255.0 ,default gateway - 192.168.1.1 & connect your PC directly with a LAN port on the back side of Router.
5. After that type 192.168.1.1 in the address bar of your explorer & login window will come , type username = admin & leave password field blank, then you'll get Blue coloured Router configuration page, From this page you can configure your Router.
6.Now if your Internet connection is Cable then default setting will work for you, However for DSL connection ,on this page you'll find internet connection type - selectiondrop down box - select PPPoE into it for DSL connection.
7. After that restart your computer & you should be able to go online.
Jan 07, 2008 | Linksys WRT300N Wireless Router
Router problem
Make sure you have the wireless icon on the taskbar lower right side. If it does not show connected, click the icon and search for wireless devices, you should see the router. connect to the router. Also make sure you have a solid DSL/CABLE status light on the service modem. BPCS
Dec 28, 2007 | Linksys WRT300N Wireless Router
Configure WRT300N wireless Router to connect internet using PPPoE
Often the nets and subnets are NOT the same.. ie The Fixed connection often uses 192.168.0.1, 192.168.1.1, however sometimes the wifi is setup 10.1.1.1, or 10.0.0.1 etc, have you checked this? Esentially tho ya router is an "Acess Point" and ya Lappy etc is ya "Client" the links below has a lot of tutorials to help have a look. http://portforward.com/routers.htm http://portforward.com/guides.htm
Aug 05, 2007 | Linksys WRT300N Wireless Router
Linksys Wireless-G WRT54G Router Logo
235 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
