Question about Brother IntelliFAX 560 Plain Paper Fax
Brother 560 fax. replaced old cartridge ,now copys come out all black
  • 1,959 Answers
Try removing the print cartridge, cleaning the roller with alcohol, replace the print cartridge and press firmly to ensure it's installed correctly and replace cover. This should solved your problem.
Posted on Apr 19, 2009
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Prints only right 1/3 of page with new cartridge.
remove the cartridge and install it again
try to remove and putt back for three times if this not help return the cartridge from where you had both it
Jul 11, 2009 | Brother IntelliFAX 560 Plain Paper Fax
Looking for printable manual for 560 brother fax machine
Go To this link
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20ManualUM_IntelliFax_600_600A_650M_EN_78.PDF
May 31, 2009 | Brother IntelliFAX 560 Plain Paper Fax
Which way to laod paper to fax on Brother 560 plain paper fax
Does not matter.
If you mean when sending, make a copy, then you'll be sure.
Dec 16, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Copy machine won't copy
you will probably have to have all cartridges working.
Aug 04, 2008 | Brother MFC-8220 Fax
Ink cartridges, recieving fax
It sound like your machine is receiving but as soon as it tries to prints the fax it has this problem.
Rewind the ink ribbon so it is nice and tight in the housing. Clean the black roller above it with some cleaning alcohol or equivalent (nothing too harsh).
See how that goes if you are still having problems replace the whole cartridge (not the refills) PC-401.
Feb 19, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Automated Document Feeder Problem
It sound like the paper is not getting recognised by the original sensor. Check for an obstruction in the feedpath - piece of paper, paper clip, pin, cockroach, apple core, tube of cake decorator (I've seen it all). Do this by opening the control panel cover (the one you open when you replace your cartridge and look through where the original feeds. Also see if the original sensor arm is in place. In the white plate there will be a black arm. The original sensor arm will be directly behind this sensor.
Feb 12, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Brother Fax 560 will not stop running the cartridge. The cartridge can be replaced, the door closed and it will not stop running until the cartridge is empty. How can I fix this problem?
Unfortunately there is no fix for this problem as the system board is corrupted. Try powering the machine of from the wall socket and then powering back on. If this doesn't work the machine will be more cost effective to replace.
One question though is it an original cartridge that is installed if not install a new original ink cartridge.
Cheers J
Jan 05, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Brother IntelliFAX 560 Plain Paper Fax Logo
114 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
