Question about GE Spacemaker JVM1640SJ Microwave Oven
No heat, does not cook
I bought a used micro thermador MBBS-01 that was not used much. I installed it and it does not heat anything in any mode. The front board works etc so I would like to check a fuse or something if I can prior to seeking repair. Any suggestions as to where to look or what I should look for ?
  • William Miller
    William Miller May 11, 2010
    Is that the full model number from the tag on the unit?
    MBBS-01 is not showing up...
  • 320 Answers
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave went dead when I opened the door ( same problem as closed the door ).
A - This often is a stuck or faulty door switch and it has blown the interior microwave fuse.
Q - My microwave is completely dead.
A - House fuse has blown or interior fuse inside the microwave has blown ( usually a part inside the microwave makes this fuse blow ) Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
Posted on Mar 06, 2009
Replacement or fix
just replaced our 6 year old Thermador MBBS ($750) with a GE JES2051SNSS from Home Depot ($179). The bottom guide piece from the Thermador bolted right on the bottom of the GE and positioned the new unit so the front trim piece fit perfectly.
Jun 06, 2013 | Thermador MBBS Microwave Oven
Is there a replacement microwave for the Thermador MBBS/01
The MBBS sereis was replaced by the MBES series.
Specs are here.
Nov 27, 2012 | Thermador MBBS Microwave Oven
Thermador opion 3 micrawave does not work
First if it has a turntable and everything lights up etc, does the table move or not? If it does but no heat/cook possible inverter board or even the Magnetron unit.
If table does not turn it may be a safety switch located in the unit that is not engaged (have to get at from inside unit).
Nov 04, 2012 | Thermador MBBS Microwave Oven
Mbbs 01 thermador micro oven: timer counts down, lights go on, but no heat, no fan and turntable does not turn. is it a fuse?
Key clue is table does not move---All microwaves with a table have a lever switch that is engaged when door closes--only can get at from inside the unit----it prevents the unit from operation if door not closed.
What happens from closing door a lot is the switch with a lever arm can come loose or even if snapped into a plastic holder break out of the holder.
IF this it is not too expensive a repair.
Jun 16, 2012 | Thermador MBBS Microwave Oven
I need to replace the waveguide in my Thermador MBBS / 01 microwave.
Waveguide "cover"I presume? The waveguide is part of the chassis and cannot be replaced.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 26, 2011 | Thermador MBBS Microwave Oven
Thermador built in microwave turns on but wont heat worked great this morning. model# MBBS/01 serial# FD8602
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
Apr 02, 2011 | Thermador MBBS Microwave Oven
TURNTABLE INOP on mbbs/01 thermador microwave
easy...first thought it was a program glitch. turntable could be turned off manually. nope ...just a bad motor needed replacement
Sep 14, 2009 | Thermador MBBS Microwave Oven
Thermador Built-In Microwave MBBS/01 Diminished Power
Smell could indicate burnt rectifier or mag. ( Or Both) Even a partially shorting transformer that hasnt yet fully shorted out and blown your fuse. I do not know that unit, but if it would happen to have 2 mag systems you could lose 1 and it still heat but probably only at around half power. It has been a long while since I have had to work on a Thermadore. But last time I did I rememeber most of their parts distributors I used to work with had all closed. Do you still have a manuel for that unit from when you purchased it?? Try to find a contact phone number to see if you can call thermador. Ask them if they have anyone in your area doing service for them. While it may no longer be under warranty, a servicer who represents them will have parts, or acces to parts and service literature that other servicers will not.
Aug 16, 2017 | Thermador MBBS Microwave Oven
I need to buy a new MBBS Thermador Microwave
I spent the better part of three days trying to find a microwave that will fit and it's hard because so many are on line only. Last night I successfully installed the 2.2 cu. ft. GE profile counter top unit with inverter technology. The unit is an exact match, the Thermador even fits in the GE box with the styrofoam! I installed the venting materials for the side and rear vents and the platform at the bottom. I put the clips and decorative molding on and it's perfect! I found it in stock at Lowe's for $198. I took me about 45 minutes total to install. If I can do it, anyone can - 48 year old mom with 5 kids!
Nov 27, 2008 | Thermador MBBS Microwave Oven
Microwave appears to work fine but will not heat at all.
Sounds like the thermal protector on the mag tube quit. It may have gotten too hot and opened up. That is the lesser of all the evils that can happen to a Microwave.
Feb 04, 2008 | Thermador MBBS Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
233 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
