Question about Sanyo DP32746 32 in. LCD Television
Sanyo ce32ldy1b lcd 160gb black screen with sound
Sanyo ce32ldy1-b hello i read on many sites that if tv comes on blue then goes black screen after a few seconds its mostly the inverter .so i got a new inverter for my tv and the tv came to life and gave me a perfect picture .but then after two minuets the screen goes black but i still have sound if i turn off and on it then stays on for approx 20 secs then black screen again ? can anyone help please .
regards wayne
  • hepcat Mar 02, 2009
    hi thanks for your quick reply .yes the inverter i got is new and a genuine sanyo part cost £76 GBP before i fitted the new inverter all i got was sound and a black screen the new inverter gave me a clear picture for a few mins then black screen but i still have sound? i will look at the caps thanks again
    PS. if i let the tv stand for an hour or so then turn on it will be ok for
    a few mins till it warms then screen goes black. then if i turn off then back on it lasts less time .
  • Anonymous Mar 31, 2014
    the screen stays black and no sound.power light comes on for a little bit and then goes off for a few seconds and repeats this
  • 44 Answers
It sounds like you have a power supply problem, this powers the inverter! Where you just replaced the inverter, we could assume it is good! Look for some bad caps (capacitors) on the power supply board. They will look bulged on the top an may be a little leaky (brownish stain). The power supply can fail on some output and be good on others. Was the back light inverter new? If all else fails, see if you can return the back light inverter and get another! I hope this is helpful!!
Posted on Mar 02, 2009
Hello... i have a sanyo DP42848 i turn it on and 3 sec the screen goes blank and the sound still on..i think it might be the black light converter board..can you point me in the right direction...
You are right, in most of the case It is the back lights inverter board.
If this TV uses a LG display panel, it uses a single, or double inverter board, you may check out that if there is any PUP-UP electrolytic capacitors, if you do change them all.
If it is not a LG panel, you have to change the inverter board.
Jun 01, 2017 | Sanyo Televison & Video
Sanyo DP46142 TV comes on for approximately 30 seconds and then screen goes black. Power LED stays on.
Sounds like a backlight problem to me. If you input a signal to the HDMI or Composite input and then it goes black have you tried taking a flashlight to the screen to see if the picture is still there but just dark? That would indicate a backlight issue. That model appears to be an LED edge lit backlight, so if the picture is still there after going black your going to have to trace out the backlight circuit and see whats going on. Usually with LED backlighting if it comes on at all then the LED's are good, its just the driver supply thats failing to keep them on. Some TV's have a small separate board that provides the backlight control, but i suspect with this model its on the power supply board and not the motherboard. Have you checked that board? It could be bad caps on the power supply board, check the voltages to the backlighting when it lights up and then when it goes dark. It could just be some failed capacitors on the power supply causing that voltage rail to drop off.
May 04, 2017 | Sanyo Televison & Video
TV SYMBOL COMES ON TV GOES BLACK NO SOUND OR ANYTHING HOW TO REPAIR THIS
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the ...the the tv turns on but there is no picture or sound and I can't seem to fix it the .... +tbones11234 I have the same on myHisense 55" TV,what did you ... The problem is when i turned it on it shows on the screen the sony logo three times then its ...
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Click Here to BUY TV REPAIR P... ... I Have a Hisense Tv in My Screen Is Not Working Right The brightness is ... Hi my TV shows the picture for a moment and then goes .... here the sounds but you cant see nothing and a sanyo flat screene.
Jan 16, 2016 | Hisense Televison & Video
Sanyo 37 LCD ce37ld33-b
Sounds like display panel fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 21, 2015 | Sanyo Televison & Video
Hello my name is Helal. I have Sanyo 42" lcd TV have no picture but have sound. Screen black.
look for a bad fuse on the power supply board. If all are ok then look at the board that has a flat ribbon cable going to the bottom of the screen. This board usually is close to the center of the screen once you take the back off the TV. Parts can be gotten from shopjimmy's web site.
Nov 19, 2014 | Televison & Video
Why my 42" sanyo DP42841 HDTV LCD SCREEN GOES BLACK ON THE LEFT SIDE?
That sounds like a faulty LCD panel tab. The only true fix is to replace the screen. This usually isn't cost effective.
Jan 19, 2013 | Sanyo DP46849 46 in. HDTV
Sanyo DP26649 screen blacks out and sound becomes loud static
Most likely you will need to get a diagnoses performed on the set. Your problem could be with either the main board or power supply board. The million dollar question is do you repair or replace? With parts and labor to repair this set, you could come out cheaper replacing it.
Jan 15, 2013 | Sanyo DP26649 26 in. TV
My Sanyo tv screen goes black for a few seconds but I still have sound. Happens normally when my central air clicks on even though I have my tv on a surge protector.
is this an lcd tv? if yes the cause is loose connection in the power inverter board connector for screen back light.
Oct 11, 2012 | Televison & Video
Tv screen goes black ater 10 seconds
there could be several things causing this, most often it's a defective inverter, or a bad CCFL lamp. You could also have a problem with 24vdc output from the power supply, or "backlight on circuit from the main board. Get a proper diagnoses.
Sep 08, 2012 | Westinghouse TX-47F430S 47 in. LCD TV
Sanyo DP32746 32 in. LCD Television Logo
483 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
