Cars & Trucks Logo
Posted on Mar 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can i use a 96 4L80E transmission in a 2000 Chevy Express Van
I have a 2000 Chevy express 1TON Diesel and need a transmission.
I would like to know if i can use a 4L80E from a 1996 Chevy 1Ton to put in my van?
Is there any difference in them?
Please advise
davemar2009
Level 1:
New Friend:
Problem Solver:
  • Contributor 2 Answers
  • Posted on Sep 19, 2011
davemar2009
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
Helped
935
Points
96' Has trans cooler lines both in front of ******. They had overheating problems, so in 97' they moved the Return Line farther back on trans. You will have to change line fittings as well as move return line forward.
Marvin
Level 3:
Top Expert:
  • Chevrolet Master 85,242 Answers
  • Posted on Mar 01, 2009
Marvin
Chevrolet Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29055826
Points
266281
That trans is a little to lite duty for a diesel, u can use it but u will need to install the computer and the correct wiring harness.
How do I start 1997 chevy express 3500 with the wires?
You can't. It has an anti-theft device. The days of boosting a car with a couple of wires ended in the 1980s! You have to fix the problem, not find a way around it.
General Motors Vehicles Equipped with PASSLock ...
www.locksmithledger.com > keys-tools > article > gene...
The PassLock system was designed to prevent vehicle theft by disabling fuel to the engine if ... Chevrolet Silverado 1997-2004. Chevrolet Sport Van 1997-2000
CHEVY EXPRESS GMC SAVANNA VAN 2500 3500 ANTI ...
www.ebay.ca > ... > Other
REBUILT WITH LIFETIME WARRANTY GM Passlock Anti-Theft VATS module. PART NUMBER 16264985. THIS PART IS OBSOLETE AND UNAVAILABLE AT ... Rating: 5 · ‎2 reviews · ‎US$149.99 · ‎In stock
16264975 GM Passlock Chevy Express GMC ... - Amazon.com
www.amazon.com > 16264975-Passlock-Express-Anti-...
Buy 16264975 GM Passlock Chevy Express GMC Savanna Van C3500 Anti-Theft Vats Security Module REBUILT: Anti-Theft - Amazon.com ? FREE DELIVERY ...
2helpful
2answers
2006 chevy 2500 express cargo van .What is a good oil pressure for this van. it has 150,000 miles runs great
60psi cold / 30-45psi warm is ideal. I've seen (with that mileage) 45 cold/ 20 warm and that's acceptable - anything less start thinking about a new oil pump.
1helpful
Where is the starter located on my 2000 chevy
Under your van on the passenger side just above the oil pan on the side of the engine block, bolts into the transmission bell housing, hope this was very helpful.
4helpful
2000 chevy express 1500 van having starting issues
Start with fuel system. Listen for fuel pump humm at fuel tank No humm check wiring to pump for power. Then check for spark at plugs and wires. Remove wire from coil and hold near engine and see arch when you crank. No arch. Replace ignition Modular inside distributor cap or cap or rotor
1helpful
2answers
2004 chevy 3500 express passenger van transmission
if ur replacing it remove front grill disconnect both lines and carefully remove retaining clips from radiator if replacement is original eguipt mount & reconnect --if its a universal follow instructions usually cut off fittings and use clamps and hose to hook up
2answers
2000 Chevy 3500 Express Van Cranks but doesnt start
SOUND LIKE INOPERATIVE GLOW PLUGS. THE GLOW PLUG RELAY OR CONTROLLER COULD BE THE PROBLEM.LET DEALERSHIP FIX IT.YOU NEED CERTAIN TOOLS TO WORK ON DIESEL ENGINES.
3helpful
I need a diagram of fuse box for 2000 Chevy Express Van
i have a 2000 Chevy van where is the fuse for the two(2) rear power outlets
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
