Question about Mitsubishi WS-55511 55" Rear Projection Television
Device Selection menu stays on constantly and flickers...
I have what I believe to be the 55511. Recently, the Device Selection menu started staying on constantly and flickering between every icon on the selection menu. It happened about 2 months ago and we were able to push the reset button located next to the power button and it worked. However, this time it stays on constantly and never goes off. I have tried reset, I have tried powering down, and I have tried multiple times to do something with the remote but the tv will not respond. It also does not respond to the menu on front of the tv, anyone have any advice on what to do.
    Sergeant:
  • 319 Answers
Sounds like a bad selector switch from the onboard card that has the console controls. my hitachi did something similar, and it turned out to be the board that the buttons are on
Posted on Mar 01, 2009
Display continueuly changes
Unplug your device for about 30 minutes to let the circuitry reset itself.
If it works normally after that, it means a hardware part(s) is overheating inside, more likely a power supply is starting to fail and does not provide the proper voltages for the microprocessor.
Jul 04, 2008 | Dell W2300 23 in. HD-Ready LCD Television
Hello, just recently started having a problem with my 98 grand prix gt headlights... while im driving at night my headlights will shut off and start to flicker after about 10 minutes of driving... if i...
COULD BE FAULTY DRL HEAD LIGHT RELAYS OR FAULTY DIMMER SWITCH.SINCE HEADLIGHTS TURN ON AUTOMATIC.TRY USING MANUAL HEAD LIGHT SWITCH ON TURN SIGNAL SWITCH LEVER SEE IF HEADLIGHTS STAY ON IF LIGHTS STAYS ON YOU HAVE FAULTY DRL HEADLIGHT RELAY.IF LIGHTS STILL FLICKER OFF.YOU HAVE BAD DIMMER SWITCH.
Jun 09, 2011 | 2006 Pontiac Grand Prix
Tv won't stay on
You need to replace one STK393-110 and 2 or more 5amp pico fuses. Very common problem.
Jul 03, 2010 | Mitsubishi WS-55511 55" Rear Projection...
How to get laptop connected with vga connector to
Unplug the television. Connect the VGA compatible monitor cable from the laptop's VGA monitor Output to the VGA Input on the back panel of the television. You will need a splitter to connect the audio cable from your laptop to the VGA Audio Input on the television. Never mind if you have speakers connected to your computer.
Press the Device button on the remote control or on the television front panel to display the Device Selection Menu. Select the device you want to view, in this case VGA. The only compatible resolution is 640X480 at a sync rate of 60 Hz.
Do not leave stationary or letter-box images on-screen for extended period of time to avoid uneven picture tube aging.
Jan 23, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Mistubishi WS-55511 won't stay on
23 is a horizontal deflection error could be ho transistor flyback or high voltage splitter
Sep 17, 2009 | Mitsubishi WS-55511 55" Rear Projection...
My laptop freezes on the main start screen
enter to bios set up then disable the f1 and f2
May 01, 2009 | Computers & Internet
Tv wont respond because device menu is changing through each device
I had a similar problem: my WS-55511 would not respond to the remote and the front control buttons (with the exception of Power) cycled through the Device Menu. I solved this problem by disconnecting the front panel. Here's how to do it: 0. Unplug the TV
1. Remove the speaker grill from the front by pulling forward: there are no screws. 2. Disconnect the two cables that are exposed after the grill is removed. 3. Plug the TV back in, wait for 5 minutes to reset. 4. Try using the remote.  Hope this helps!
Oct 06, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Flickering - Toshiba 62HMX84
it could be as simple as the tv feeding back on itself in a dark room.
it is adjusting the light level because of what it sees ambient in the room.
turn on a light near the tv and see if it stays constant now.
Mar 07, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Mitsubishi WS-55511 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
