Question about StarTech.com StarView SV211K 2-port KVM Switch
Some channels ok some channels say code needs updating
I can't understand why some of my channels work then some say codes need updating I have power scanned and done everything i can to sort these channels out, has anyone any ideas whats gone wrong telewest, birmingham. I have had to reset everything.
    Problem Solver:
  • 19 Answers
Leave it on sly sports 1 for about 5mins,are you running the lastet firmware
Posted on Mar 03, 2009
How do I manually/automatically update the channels on my Samsung DNli DV3 TV?
Hi Hugh.
Please follow these instructions to manually/automatically update the digital (DTV) channels on the Samsung LE26R73BD.
Please use the following buttons on your Samsung remote control to navigate the on-screen menus:
- "D.MENU" - Opens/closes the on-screen menu (below the numerical key "0")
- DIRECTIONAL ARROW KEYS - To navigate up/down/left right through the on-screen menus
- "ENTER/OK" - Selects/confirms a selected option (in the centre of the arrows)
Automatic Channel Scan / Update:
1. Make sure you are in digital TV mode - Press the "TV/DTV" button on the remote to switch between analogue (ATV) and digital (DTV) modes.
2. Press the "D.MENU" key
3. Highlight "Installation" (first option) and press "OK/ENTER"
4. If asked for a PIN code, enter 0 0 0 0 using the numerical keys on the remote. If you have set a different PIN code, please enter your own code here.
5. Highlight "Select County" and press "OK/ENTER"
6. Use the LEFT/RIGHT arrows to select "UK" then press "OK/ENTER"
7. Highlight "Auto Scanning" and press "ENTER/OK"
8. Highlight "Scan Mode" and use the LEFT/RIGHT arrows to set the value to "Digital"
9. Highlight "Start Frequency" and use the LEFT/RIGHT arrows to set the value to "CH 21 . . ."
10. Highlight "End Frequency" and use the LEFT/RIGHT arrows to set the value to "CH 69 . . ."
11. Highlight "Start Frequency" again and then press "OK/ENTER" to start the channel scan.
Some of the options above will already be selected so will not need to be changed. I've provided the correct settings just in case they are incorrectly set. Note: UK Freeview stations are on channels 21 to 69 inclusive.
The scan will take a few minutes to complete and the progress will be displayed. When the channel scan is complete, the menu should close automatically and the TV will return to viewing mode. If not, press either the "D.MENU" or "EXIT" button to return to watching TV.
Manual Channel Scan / Update:
7. Highlight "Manual Scanning" and press "ENTER/OK"
9. Highlight "Channel Number" and use the LEFT/RIGHT arrows to choose which channel number you wish to scan . . .
UK Freeview stations are on channels 21 to 69 inclusive. In manual tuning mode, these need to be scanned one at a time. Please note, many of these channels are "empty". UK Freeview only uses 5 of these channels (called Multiplexes or MUX) or 6 if you have HD. I am unable to tell you which 5 channels these are as they vary according to whichever transmitter or repeater station your aerial is aligned to.
10. Press "OK/ENTER" to start the channel scan.
11. Repeat steps 9 and 10 for each additonal channel you wish to scan.
Please note: Manual scanning can cause some unexpected results - particularly if your aerial has a reception from more than one transmitter/repeater. For this reason it is better to use the automatical scan unless you have a specific reason for needing to scan manually.
Hopefully this will be all you need to update the digital channels on your TV. If you have any questions or need further assistance, please let me know.
Regards,
BElectric
Jan 07, 2011 | Samsung Televison & Video
I need the code for the philmore pm-rc1a so i cant watch my tv!
Try this as most remote controls work the same when manual setting.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 28, 2009 | Televison & Video
Have a Jumbo big remote. Lost all codes for the TV and video, need them to program jumbo big remote.
Try this as all remotes work about the same when manual setting.
Note:
I NEED CODES FOR MY SANYO TV
Note:
Sep 28, 2009 | GE JASRM24912 Remote Control
Need codes
Note:
Sep 25, 2009 | One For All URC-3021 Remote Control
Need code for rca remote control
Note:
Sep 25, 2009 | RCA RCR450 Remote Control
I have an emerson universal remote control and no codes i need the code to a magnavox dvd vcr combo please help!
Most universal remotes work the same. Try this.
Note:
Sep 23, 2009 | Innovage Jumbo Remote Control
Cannot find manual. need to program menu
Hi and welcome to FixYa,
The user manual for a Brookstone 538744 is available here. It is in pdf form and would need Adobe Acrobat Reader to view the file.
Good luck and thank you for using FixYa.
Jun 25, 2009 | Brookstone 538744 Remote Control
Certain channels says need code updating
hi,
some channel says code update, what can i do.
Apr 15, 2009 | Televison & Video
Need new codes for 'the box' for CHORUS or CHORUS CORK
5E 01
01
AA 26 9E F2 E9 14 D1 AE.
NEW CODES FOR CHORUS AS OF APRIL 3RD.HOPE THATS OK FOR YE.works in cork so that should be ok for u jim.enjoy all
Dec 19, 2008 | StarTech.com StarView SV211K 2-port KVM...
StarTech.com StarView SV211K 2-port KVM Switch Logo
35 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
