Question about Garden
How to replace starting cord in Victa motor mower
The cord broke and now I have a spare. After reassembling, the cord does not retract. Please help !!
    Problem Solver:
  • 13 Answers
Or the spring has come out the locating thing inside ... put more tension on it and repeat the assembley.
Posted on Nov 02, 2011
How do I fix the pull string on a push mower?
Hi Barbara:
The pull start assembly is usually attached by 3 or 4 bolts.
Start by removing it. Depending on where the pull cord broke, you may be able to use it shortened a bit, but replacement is probably a good idea.
There is a spring inside the thing the cord winds around (spool)that retracts it after you've pulled on it. The tricky part is making sure that the spring is wound up enough after you've installed the replacement cord.
Look at the way the old cord is installed. If you can, grab it with some pointy pliers and pull it all the way out, winding up the spring tension at the same time. There should be a way to hold the spool (look for a hole you can slip the end of a nail into) so you can change the cord. Then Take the nail out and make sure the cord retracts all the way.
Next step is to re-install it on the mower.
Cheerfuls!
Jun 13, 2015 | Garden
Fix recoil when pull cord on sanli lawnmower broke
Take the starter assembly off the mower. Unwind the spool using whatever method works (2 screwdrivers?) until you capture the remaining. cord. Pull it all the way out. Pin the spool so that it can't retract. Remove and replace the cord. Re-assemble. Back to cutting grass!
Mar 15, 2015 | Garden
How do I reinstall the manual pull cord on a 20 inch lawnboy lawn mower?
I think you need to replace the whole rewind unit as the dawgs must have engaged the starter cup if it was running !
Sep 21, 2014 | Garden
My accelerator cable on my Victa V40 appears to be looser now so when I pull the cord off choke the revs no longer increase, how do I fix it?
hi.. the thottle cable has round end has poped out of its cam housing(gray plastic) inside the plastic carby... the only way to fix that is to remove the carby, but before you do clean your mower as you will create more issues if dirt/grass gets into the parts you will be working on...also take pictures before you start taking thing off, so you know how to reassemble it, as the carby will need to be taken apart....good luck
Jan 01, 2014 | Briggs & Stratton Garden
Manual for victa 4016 trx ride on mower
hello, to get your victa manual you are going to have to contact the dealer in your area,they just don't post manuals,hope this helps,,
Feb 16, 2012 | Mtd Garden
How to replace starter cord on a victa corvette 400 series mower,cord snapped,i put it back on....now it doesnt retract properly when trying to start it
Not sure what engine that machine uses but they are all similar, you need to prewind the reel before you slip the rope thru the hole, let the spring/reel pull the rope in.
Nov 15, 2009 | Garden
Need to buy starter pull cord --- size??
take your cord with you and get something similar in size
Jul 22, 2009 | Garden
Victa lawnmower
how do you replace the zip cord on a victa tornado last years model
Oct 12, 2008 | Garden
Garden Logo
464 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
