Question about Husqvarna Designer I
Designer 1 says thread is broke and it isn't
Designer 1 while embroidery machine stops an says thread is broke but it isn't. Sometimes it sews for a while and sometimes it keeps stopping. But it does start right up again. Please help, I have had 2 repair people look at this and say nothing is wrong. I have had this machine since 2001 and never had this happen before. help me please.
  • mvernick Apr 21, 2009
    I have this problem too. The machine sews 5 stitches and then tells me the spool thread is broken. The only possible way of avoiding this is to sew very FAST. While it has been intermittent in the past, the problem recurs with more frequency today. I would love to get my hands on the official Designer I repair and maintenance manual. Are they available?
  • Kent Sechrest
    Kent Sechrest May 11, 2010
    It is tricky. if you are very comfortable with mechanical things I can tell you what to do
    An expert whose answer gotĀ voted for 100 times.
  • 192 Answers
You may notice that the machine works if you sew very slowly, as most repair technicians do. If it warns you at high speed, make sure to demonstrate this when you take it in.
I don't know how kent581 is going to explain this to you. I do know what is wrong and you will need pictures to get this apart and back together by yourself. If you still have a good relationship with someone that has worked on it for you, have them contact me.
Posted on Apr 09, 2009
Viking Designer SE-Limited Edition 43 hours of sewing. bobbin thread comes up around edges of desing
try changing the needle
check for burrs in the needle plate area & bobbin area
check also the top thread tension
Mar 12, 2012 | Husqvarna Sewing Machines
Where can I locate the fuse<
The Pfaff 7570 Creative Designer is a computerized sewingand embroidery machine that has the ability to connect to the computer, andhave embroidery designs sent to the embroidery machine. The sewing andembroidery machine has many features, including hundreds of general sewingfunctions, a separate embroidery module, and on-screen editing features. TheCreative Designer 7570, manufactured in the 1990s, was the first sewing andembroidery combination machine ever made by Pfaff.
1. Usingthe Sewing Machine
1 Turn on your sewing machine using the "On"button located just below the turn wheel on the right side of the machine.Thread your Pfaff 7570. Note that Pfaff sewing machines thread from left toright, not right to left like other sewing machines. The upper tension discsshould be raised at their highest position while threading, and the presserfoot should be raised up until you thread the needle. Drop the presser footright before you thread the needle. The prevents thread problems during use. 2 Insert a full bobbin and retrieve the bobbin threadthrough the thread plate. Raise your sewing foot and needle to its highestposition; hold the needle thread taught with your left hand, lower the needleinto the thread plate using your right hand, and then raise the needle. As youraise the needle, the needle thread will catch the bobbin thread, and pull itup. There should be a loop of thread intertwined with the needle thread. Usetweezers, your finger, or a straight pin to retrieve the bobbin thread that isvisible through the thread plate, and pull it through the plate. 3 Place the fabric under the presser foot, and drop thepresser foot. Choose the stitch you want to use from the top stitch display,right above the top thread feed. Press the '0-9" button located on thesewing machine's front panel, and a display screen will come up. Input thethread number, and press the 'OK' button located on the sewing machine's frontpanel. The stitch will display, and you are ready to sew. Repeat Step 3 foreach stitch you want to use.
2. SettingUp the Embroidery Unit
1 Turn the sewing machine off. Take out the embroiderymachine unit, locate the connection bushing on the back of your embroideryunit, and match it up with the connection bushing on your sewing machine. Theconnection bushing should be located next to a yellow sticker on yourembroidery unit, and somewhat resembles a serial port on a computer. Slide theembroidery unit onto the sewing machine with the sewing machine turned off. Connectto the bushing carefully as you slide the embroidery unit onto the sewingmachine. Use your embroidery unit manual if you need assistance. 2 Insert an embroidery card. Your embroidery unitshould contain an embroidery card labeled embroidery card 1. Use that or useanother Pfaff 7570 card that you own. Turn on the sewing machine. 3 Open the bobbin case area just below the threadplate, and lower the feed dogs by pushing the feed dog switch to the right.Press the card button located on the front face of your sewing machine. Adisplay with pop up; choose embroidery designs or monogram and a new screenwill pop up with your design choices. Choose the design you want, and press"OK." A checklist screen appears. Do everything on the checklist, andpress "OK." Use your embroidery unit manual if you need help. 4 Start embroidery by pressing the foot pedal. At thistime, your hoop should already be attached to the embroidery unit becauseyou've already gone through the checklist. Your embroidery manual displayscolored picture diagrams that are very helpful in understanding everything inyour checklist menu.
Thanks for using fixya
Jul 31, 2011 | PfaFF Creative 7570
My Husqvarna diamond top thread keeps breaking while doing loop embroidery. It sews a couple of stitches and then you can hear when the thread breaks. Ive tried changing the needle and bobbin, and cleaning...
Primary causes of upper thread breakage:
-- misthreading: pull all the thread off and thread again, using the manual, step by step. Read each step aloud before you do it. (sounds dumb, but helps.) (And make sure you thread the takeup lever!)
-- thread has wrapped itself around a thread guide or spool pin from one of the breaks. Take the spool off the machine before rethreading.
-- bad or damaged needle. Replace with the right size for the fabric, turned correctly (backwards needles skip stitches)
-- dirty machine, especially in the bobbin case area: review cleaning instructions and do it, using brush and vacuum only
-- bad/cheap thread: should not be slubby or break easy. Try another spool.
-- top thread tension too tight. 4 is normal for most fabrics, most stitches.
1) do a light cleaning (brush and vacuum) every day you sit down to sew.
2) replace the needle if you hear it hit metal, if you've got a really bad thread jam, if you see it deflect as you sew (for instance, sewing over the side seam on jeans when hemming). Replace every 3-8 hours of actual stitching time anyhow.
3) buy good quality thread
4) when your machine isn't sewing right, stop; take all the thread off of/out of the machine (bobbin out of bobbin case, spool off spool pin) and give it a quick cleaning. Rethread from scratch, carefully. If that doesn't fix it, do it again, then replace needle and rethread one more time, manual in hand (yah, even if you've threaded it 8 million times before). #4 is curative about 98% of the time. The other 2% often requires professional attention.
Jul 11, 2011 | Husqvarna Designer I
How to thread the bobbin on designer 1 the bobbin thread keeps coming to the top of embroidery
Easy as pie to thread the bobbin, look it up in your book. It even shows you pictures.
Feb 11, 2010 | Husqvarna Designer I
Embroidery sewing machine stopped working
I am not sure what you mean: motor runs but nothing else moves?
Have you have turned the machine off and tried again? Like computers, sometimes they need rebooted.
More information is needed to evaluate further.
Dec 29, 2008 | Husqvarna Designer I
Designer 1 Embroidery Bobbin problem
Designer 1 bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
Oct 28, 2008 | Husqvarna Designer I
Designer 1: upper thread shredding while embroidering
I too, have the same problem withmy Designer 1. I just bought ISACORD brand polyester embroidery thread to hopefully solve this problem, but I believe it must be a tension problem. I have a "date" with the repair lady on Friday (11/22/08) and if it gets repaired I will re-post what the problem was. Still love the machine WHEN IT SEWS!!
Apr 17, 2008 | Husqvarna Designer I
Designer One "broken thread"
If the upper thread spool is spinning allowing slack to the inlet of the tension assy and the machine gives a broken thread indication shortly afterward, the pre-tension assy needs to be adjusted. If the machine has the original "snap in" tension assy that was in the first generation of Designer 1, have it replaced with the modern "lay in" tension assy. Slack at the spool should never cause a broken thread indication as long at the thread is in the pre-tension assy.
Sulky thread will work as well in a Designer 1 as any other embroidery thread as long as it is properly adjusted.
One thing that you can look for, when the machine is sewing, watch the thread as it passes out of the left hand side of the tension disks. It should exit the disks at the 9 o'clock position. If it starts to drift up to the 10 or 11 position and then you get a broken thread warning, the pre tension must be increased.
Feb 05, 2007 | Husqvarna Designer I
Sewing Machines Logo
124 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
