Question about Samsung DVD-R155
Audio not working
Checked connections & they're fine. video plays, but no sound.
  • Samsung Expert
  • 244 Answers
Normally it is the scart lead not in properly or faulty.Your normally get pic no sound or sound no pic.I hope this helps.
Posted on Mar 02, 2009
No audio after recording from sat. Reciever
Double-check your input cables from the receiver to the LG 389. Do you have the sat. receiver AV out connected to the front AV In on the LG DRT389? Make sure that you haven't mixed up the L and R audio connections on either side. (I've done something similar with RCA cables myself.) Next, try a different set of cables.
If that doesn't work, there may be a problem with the audio jacks on either your receiver or the 389. To check, plug the AV cables from the Sat. Receiver directly into the TV. If you have sound and video, then the input jacks on the recorder may be damaged.
Try using another input. (It looks like some models have the SCART input; you may need to set the input source in the menu under AV2 Decoder.)
The fact that you have audio output on USB and DVD's means that cables/connections between the LG289 and the TV are fine.
I hope this helps. Please add a comment with the details of which AV port you are using on the LG389 for additional assistance.
Aug 31, 2012 | LG DR389 MULTISYSTEM DVD RECORDER FOR...
No sound game plays fine
Hi.
Check sound settings, but more than anything else check the sound cable. If you use the component (red green and blue) cables or if you use the yellow video cable you will need an external audio connection. The audio cable must be connected to the right input on TV or home theater. Most consoles allow use the red and white audio connection cables (AV), there is also an optical audio cable that can be used.
If you use HDMI you do not necessarily need external audio cable. In that case ensure that HDMI audio is not disabled on TV or console settings. Test using a different HDMI port on TV. Do not forget to turn power off when you connect or disconnect cables. A TV can easily be damaged by disconnecting cables with power on (HDMI carries +5V).
Regards.
Ginko.
Dec 13, 2010 | Video Game Consoles & Games
No picture
have you connected up correctly, have you selected correct EXTERNAL inputs, you do NOT "tune" a Channel to see picture, you choose external AV input on set. Must connect color to color. 3 for Composite Video AV.Yellow, Video, Red & White Audio. and 5 cables for Component 3 for Video , & 2 for Audio Blue, Green, Red, Also Red & White, Audio.
AV
Mar 18, 2010 | Panasonic DMR-ES10 DVD Recorder
Video is fine; audio will not play. All cables
Disconnect the cable from the ps3, the one that connects the ps3 and the monitor, for a few seconds, then reconnect it. You do this while video is playing or when you play games.
Jan 16, 2010 | Sony Playstation 3 (PS3) Console
"Protect" flashing on STR-D665 Receiver
Check if you connect corectly the speakers wiresnand if they are right connected the audio amplifier Ic are damaged
Nov 28, 2008 | Sony STR-D665 Receiver
Video on game and dvd seem to work
DO you have hdmi monitor turned on?
Jan 05, 2008 | Onkyo TX-SR605 Receiver
No sound from digital cable thru AVR3200 after adding HDTV - DVD plays fine
you need a digital coax cable and then connect it to 6.1 also the digital cable type is not a coomon type so check that also
Jan 04, 2008 | Denon AVR-3200 Receiver
Curtis Mathes CM32010 has no sound
any user manual online ?
unplug from wall
see if remote will get you to system settings audio
Apr 06, 2017 | Curtis-Mathis CM32010 TV
Samsung DVD-R155 Logo
115 people viewed this question
Henry  Thomas
Henry Thomas
