Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
I need to reset the date and year
I just installed a Honeywell RTH7500 programable thermostat. The date and year are wrong. How do I reset the time and year?
  • Anonymous Mar 10, 2009
    i have the same thermostat and the date is also wrong. it is stuck on the sunday schedule and will not change
I had exact same problem with RTH7500. Did not set the date properly at the beginning and than realized that there is no menu option to change the date after it is saved once (???!). I was very confused for few hours and wandering - trying to find changing option on thermostat menu; than I was looking online what can be done... I could not find solution...
Than I took out both AA batteries, open the thermostat (be very careful while doing this - you don't want to break plastic peaces that hold the thing together) and took out the button battery thinking that this will reset the thermostat... but it did not.
I repeated the same thing, but this time, while the button battery was out, I put two AA batteries back and this reset the thermostat... the old - blinking date appeared and I was very happy to see this on thermostat screen! This time I set the time properly and it works fine.
Hope this will be helpful if you did not solve the issue yet... if you did, someone else might find this solution useful.
Posted on Aug 03, 2009
  • Hung Bui
    Hung Bui Nov 13, 2013
    Thank you for the tip. The trick is you have to leave the button battery out long enough so the date info is erased. Do not know how long is needed, but a minute may be enough. I followed the instruction above, and took both sets of battery out for more than a minute, the date was reset.
  • Honeywell Expert
  • 252 Answers
The Thermostat Wizard is an interactive tool that will guide you through wiring and troubleshooting your thermostat, as well as programming it to the most comfortable settings for you and your family. Simply answer the questions from the Thermostat Wizard to correctly connect, troubleshoot and/or program your Honeywell Thermostat. You can even print the instructions and bring them right to the thermostat to help make things easier.
Go here: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Support/Thermostat+Wizard/
Please rate my answer!
Posted on Mar 12, 2009
I have just installed a RTH7400/RTH7500 thermostat. The wires are seem to be in the correct place, all functions are working, with the exception of no heat will come out, only cold air? I have set all...
Check function 0170 to make sure it is set on the proper type of heating system. Its a long list and specifics of system type make a difference. Also, Ive learned the hard way to always go by function, not color of wire. If you tossed the instructions they can be found on the Honeywell website https://customer.honeywell.com/resources/techlit/TechLitDocuments
Nov 16, 2017 | Honeywell Focus 6300B 5-2 Days...
Have the honeywell t8001c thermostat - no batteries - it holds the programming fine but not the date/time - what to do?
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Mar 06, 2010 | Honeywell Programmable Thermostat Heater
System will not turn off
Call the honeywell technical service number listed on the instruction sheet for the thermostat.
They can verify if you have the correct stat for your application and the wires are connected to the right terminals.
May 30, 2009 | Heating & Cooling
Permanent hold message on thermostat
press run program.... from there, set the schedule for maximum efficiency. permanent hold only shows up after the hold button has been pressed 2-3 times. If this does not fix the issue, there is a master reset button on the thermostat that will set all settings back to factory default.
May 16, 2009 | Honeywell Programmable Thermostat Heater
Heater on when not programmed
sounds like a bad t-stat , they have a 5 year warranty on them
Dec 28, 2008 | Honeywell Programmable Thermostat Heater
Honeywell Thermostat RTH 7500
Assumed all the wiring are correct,
to change from manual switching from heat to cool, press [system] button ( left ) to go into system setting.
then press and hold the [fan] middle button untill option display 120
use up down button to select option 300 ( Manual/Autochangeover) ,
select 0 for manual, 1 for automatic. ( read caution in page 22 of installation manual )
Good luck
Sep 30, 2008 | Heating & Cooling
Replace Carrier tstatccshp01 builders standard thermostat with Honeywell rth7500 series and wiring not matching Does O wire go to Aux..? fan working but no cool air.
No... Aux. is auxiliary heat strip. This is usually a white or black wire its up to the choice of the installers preferance. O or orange wire. is used to the reversing valve on a heat pump. If you do have a heat pump there is a programing section inside the Honeywell t-stat. which should say heat pump or straight cool, then another section that will ask if you want the reversing valve to energize in heat or cool. most Heat Pump brands energize in cool the exception is Rheem and Ruud they energize in heat.
May 17, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
4,034 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
