I currently have a Toshiba DP5570 Digital Copier/Printer setup using NDPS printing system. The printer drivers download ok. My problem is that I have to manually configure each driver to be able to use the duplexer and stapler through the print driver. Is there a way to pre-configure this so that it is automatically setup when the driver downloads and installs?
Ok. Cause we are in an education environnment, you can imagine that it isn't so simple. Students do often things that they shouldn't
Thanks for your help.
Was this helpful?
Yes
No
Solution #2
posted on Aug 02, 2007
Ross - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
We didn't try to automate both processes.. we already had NDPS out at the workstations, and then just pushed the NAL app. This works because we're in a relatively stable environment, where printers are not being pushed to various machines all the time.
-- Jim Michael Novell Support Connection Sysop
Was this helpful?
Yes
No
Solution #3
kcw573 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Hi Jim.
How exactly do you do this ? We are distributing the drivers over NDPS and created a force run application object for changing paper size to A4. But we can't control the timing. That means there are times where it works for both printers, just for one or not at all.
NDPS distributes the drivers much or more slowly and the application often terminated to run, before NDPS finished distributing. So the changes are overwritten by NDPS and reset to Letter size.
Thanks for your help in advance
Was this helpful?
Yes
No
Solution #4
herself - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
If the printer supports postscript and you are installing the PS driver, you can edit the PPD (Printer Desc File) with options such as duplexer, trays, and memory set as you wish. When the driver is installed, the "defaults" will now be what you set in the PPD.
Jeff
Was this helpful?
Yes
No
Solution #5
Joey2 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Thank you for your prompt reply.
tippetts.vcf 1K
Was this helpful?
Yes
No
Solution #6
paulrmc - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Since there is no standard way of selecting pring options, NDPS is not able to control any of this functionality. The workaround we use is to create a NAL snapshot of the print driver configuration we want, and force-run that to all necessary users.
Was this helpful?
Yes
No
Popular Solutions for Toshiba DP5570 Laser Printer
I have HP PSC 1315, My HP Notebook says ready to print, when I hit print I get Error code-30. I...
(More)
I have HP PSC 1315, My HP Notebook says ready to print, when I hit print I get Error code-30. I checked control panel, this is marked as my default printer and is on, any ideas what I can do to fix this, I am attempting to print postage label. Thanks
