Question about Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control
Fan and dimmer remote does not work
I bought a condo with an installed Hampton Bay fan with light. The remote is a Hampton Bay remote that should dim the light (low, med, hi) and turn fan on and off. I replaced the battery and do have a red light when I press the button but no response from fan or light. There is a light and dimmer switch on the way...and one that may flip on the fan...it doesn't work either.
  • Anonymous Mar 15, 2014
    Just installed this fan in our room. The fan is working perfectly fine, turning on and off/ low, med, & high with the remote but when we try the light it doesn't turn on at all. Please help us!
  • Anonymous Mar 19, 2014
    red lt on remote comes on then dims fan r lights notworking
    New Friend:
  • 3 Answers
Hi there, did you try checking the dip switches? I would recommend to read this remote control troubleshooting guide. It is generally helpful for these situations. Troubleshooting Ceiling Fan Remote Controls My Remote is Not Working...
Posted on Aug 09, 2014
The remote is a Hampton Bay remote that should dim the light and fan on and off. I replaced the battery and do not have a red light when I press the button. Light and fan does not turn off with remote.
Posted on Mar 02, 2009
Dimmer not working but the light does come on.
What kind of wall switch do you have? Is it a remote wall switch? You can't use a basic Fan/light control with a remote.
Jun 03, 2013 | Hampton Bay AC414-LRU 52'' Kemper...
My new fan with light fixture is hooked up but it only works through the pull strings not from my wall dimmer. Can someone please tell me why and what do I need to do to have it work from the wall dimmer....
It depends if the fan and lights are ran for separate control. If only one power line is ran from the fan to the switch location than you are out of luck. You should install a switch instead of a dimmer because a fan is not designed to work with a dimmer. A dimmer works by rapidly turning the power on and off faster than our eyes can detect creating a dimming effect for lights. This is not good for your fan. The strength of the fan speed will be limited by the dimming/power output of the light dimmer.
Nov 21, 2009 | Universal Remote Control Hampton Bay...
Dimmer or not?
Are you saying you have a dimmer for the fan light and it does not work, or you do not know if the fan came with a dimmer switch?
Most of these fans have two switches; one is for the fan speed(usually three speed) and the other is for the lights(on -off). Adding a Remote control , which is optional for this unit , will allow for remote speed control(variable or three speed), and light dimmer control. The remote controls can be purchased in your local Home Depot or Lowes store. Hope this helps....
Jul 12, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
Light is dim on my Hampton Bay ceiling fan
Check the lamp installed is of correct type / wattage,
If a light dimmer is connected, check its operation,
Check the light circuit socket and switch connections. - Take care not to get electrocuted! - mains power is dangerous.
Jul 07, 2009 | Hampton Bay 24002 Ceiling Fan
Bought a condo with 2 Hampton Bay ceiling fans with lights. Previous owner did not supply the remotes. Where can I get a remote without having to replace the base. The fans work with the light switch but...
Home depot makes hampton bay.
That's their brand name.
I know they sell remotes.
Just make sure the code switches on the remote (They're in the battery compartment....should be 4 of them) match the receiver switch positions ( located in the upper canopy of the fan).
The sales help are goodfor this kind of thing, as it happens all the time with lost remotes etc.
Jun 23, 2009 | Hampton Bay 52 In.Carriage House II in...
Remote controlled ceiling fan
unplug the fan then remove the batteries from the remote then plug the fan back in and, reinstall the batteries; this resets the fan control
Apr 22, 2009 | Hampton Bay 24002 Ceiling Fan
Hampton Bay Remote
You must use the switch on the fan itself.
Aug 01, 2008 | Hampton Bay 52 In. White Redington...
Diminished light
When our 2-year-old niece got hold of our Hampton Bay fan remote, we learned from her actions that holding down the button that controls the upper or lower light will, after a pause, either brighten or dim that light. Our fan is older than yours, but perhaps yours works the same way?
Apr 23, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Dimmer controls the fan / noisy
Sounds like a wireing problem, You wired the light dimmer into the fan control. thats why the fan slows down when you dim the lights.
good luck-------------tomtaso
Dec 13, 2007 | Hampton Bay 36 In. San Marino in Brushed...
Remote calibration
I installed three fans in the same room and one remote ran all three. In order to get the dimmers all to bring the lights up and down together, I changed the dip-switches in the fan housing so that the remote would only work one fan at a time. I then brought the dimmer lights all the way to bright. After all the lights were equally bright, I again altered the dip-switches so that all three and the remote were identical. The remote then dimmed all three lights equally.
Jun 16, 2007 | Hampton Bay AC438-VPW 52'' Vintage Pewter...
Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control Logo
1,408 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
