Question about Minn Kota Boating
Diagram of 36 volt hookup for trolling motor, i have a factory 24 volt wiring in my boat and I need to turn it into a 36 volt please help thank you
  • Anonymous Apr 08, 2009
    need diagram on how to hook all leads to the batteries to make the series
  • 4 Answers
To get 36 volts, number batteries 1 thru 3. connect pos 2 to neg 1, connect pos 3 to neg 2, connect pos 1 to trolling motor controller and neg 3 to ground on trolling motor.
This is only a solution for 3 battery system.
For 4 battery system, connect 4 to 3 pos to pos and neg to neg.
budman772357@embarqmail.com
Posted on Nov 12, 2009
I am getting a charge between my aluminum boat and the trolling motor system. I get a white buildup on the motor shaft and the outdrive anodes. It may also be burning up other electronics as my GPS antenna and 2 radio's have recently died.
Can I ground the batteries to the hull?
Posted on May 18, 2010
Show proper battery hookup for 24 volt trolling motor, 2' 12 volt batteries
to get b24 volts from 2 x 12 volt batteries
connect the negative (- ) terminal of one battery to the ground point on the motor
next connect the positive terminal (+ ) of that same battery to the negative terminal of the next battery
connect the positive terminal of the last battery to the power terminal of the motor
so it will be negative to ground , positive to negative , positive to motor or motor control
(-) to ground (+ ) to (-) , (+) to motor
That is called a series connection and increases the voltage available
Mar 23, 2017 | Boating
My motor guide trolling motor died . It was on the new boat that I bought in 2011 . Checked the breaker fuse and it's good, tested the wiring with a volt meter couldn't find anything. Could it be the micro...
do you have it hard wired to pos and neg or does it have the 3 prong plug in switch ..if 3 prong its for a 24/36 volt motor wont work on 12 volt less you have the 12 volt plug
Oct 16, 2013 | Boating
Great white trolling motor,bow mount,24 volt, 82lb thrust / big problems! Burned up Marinco plug,replaced plug,recetacle,fuses on. batteries, tech says motor runs fine on bench,but not on boat. Getting 24...
The heat is developed from to much resistance from batteries to TM, check for loose/corroded connections at batteries, including the jumperwire, also check the size of wire from battery to plug, should be at least 8 gauge if not 6 gauge depending on the length of run. If corrosion has built up inside the wires this will also cause high resistance causing excessive heat build up. I would prolly just replace boat wiring to make sure none of the above problems are present. Use tinned copper marine grade wire that is multi stranded.
Mar 08, 2012 | Boating
24 volt trolling motor (motorguide) not working. Have 24 volts at receptacle in hull of boat but when I plug in the trolling motor and check the volts on the plug, I only read 6 volts. Any idea whats...
You have a high resistance short either inside the wiring or the lower unit. This will cause a voltage drop. I would be very careful not to keep it connected too long cuz the battery is trying to keep up with the current demand and may explode.
Oct 03, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
I have a 2001 nitro bass boat an i am replaceing my 12v tolling motor w. a 24v. i installed the 2d battery and am ready to connect the wires. There are 2 positive wires, 1 states "battery a"...
Is this a straight 24V system... not a 12v - 24v.Correct..
The best advice is use a 50-60 amp resettable breaker..with 6 gauge wire (minimum 8 gauge) ... make sure your connections are clean, tight, and greased to prevent corrosion. USE a BIG HEAVY "jumper" cable between the + and - terminals.
Here are several sites that explain what you need to know..
I went from a 12-24v to a straight 36v Motorguide on my 21ft triton.. WOW!!!! talk about BAD A$$!!
I use the felt washers under all battery connections and the battery spray liberally on each connection..
24 and 36 volt Wiring Diagrams
24 volt trolling motor wiring Google Search
https://www.oreillyauto.com/shop/battery-accessories-16452/battery-accessories-16508/battery-cables---accessories-17650/2000/ford/contour?sort=price+asc
https://www.oreillyauto.com/detail/super-start-4986/chemicals---fluids-16461/battery-chemicals-17661/battery-protection/01342/4742198/2000/ford/contour
https://www.oreillyauto.com/detail/bwd-3123/battery-accessories-16452/battery-accessories-16508/battery-cables---accessories-17650/battery-cable/jc312/2601175/2000/ford/contour
Sep 18, 2017 | Nitro Boating
Just like a flashlight. Positive to neg, In a loop going to the motor. That is the jump between the batteries, One red wire coming in from motor, it will go to pos, from one battery, the neg will go to the 2nd battery pos. From the 2nd battery neg will go to the motor. That is it, one jumper connecting the 2 batteries, will create the 24 volts. Hope this helps.
Mar 22, 2010 | Boating
Wanting to install motorguide 24v trolling motor in boat, will it work on just 12 v system
No. you can put in extra batteries and use it, but you must remove you charging system from them to use it that way. Not really practical.
Mar 21, 2010 | Electrical Supplies
I have a minn kota 48 AT 12/24 volt bow mount that I run on a two battery 24 volt setup. The trolling motor is on a 3 prong plug into a panel at the front of my boat. That panel has an on/off/on toggle...
use a volt meter and check for voltage at the plug, if none..check in the back near your batterys and locate the circuit breaker and reset it ...basic system = battery-breaker-wires....hope this helps ....GL
Jul 05, 2009 | Boating
Converting From 12/24 to Starght 24 Volt
if it is 24v. then you need to connect 2 battery in parallel. since the battery is only 12v.
if one battery is shoing red and the other is sohwing green, that means you are using 12v only, not the 24v.
connetion as follow:
positve of battery 1 to the motor, the negative of battery 1 to postive of battery 2. the negative of battery 2 to the motor.
Oct 20, 2008 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Boating Logo
7,325 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
