Question about Maytag Washing Machines
Model SE9900 Maytag Stackable Washer/Dryer - 9E Error
Model SE9900 Stacker system periodically shuts down with a 9E error. Have had system since '91 with problem over last 6-8 months. Only way to reactivate system seems to be to pull main fuse from house's fuse panel and reinsert; then try the washer/dryer again. Have cleaned the inner areas of system and control panel to remove all dirt/dust, etc. Have varied size of loads. Have tried running washer and dryer separately. Problem still comes and goes periodically - more frequently of late. Obviously, something needs attention. Not sure if it's time to call a service repair man.
    Top Expert:
  • Maytag Master
  • 43,969 Answers
According to my data, a 9E error indicates door latch malfunction.
Posted on Apr 21, 2017
aborcass
  • 2651 Answers
SOURCE: Model 417.94802301 stackable with electrical haywire?
you got a problem with your power supply for sure. check and make sure both your breakers are on inside the fuse box. turn them completely off and them back on(there should be 2 linked together for this unit. if that ok try to gt behind the unit and check the incoming power source(make sure wiring on rear of dryer is in tact. def sounds like inadequate power supplied to unit
Posted on Mar 10, 2008
SOURCE: Maytag front loading washing machine
3E = Drive system is not working correctly. Bad windings, speed sensor, wiring connections or Control Board.
Posted on Aug 25, 2008
aborcass
  • 2651 Answers
SOURCE: STACKABLE WASHER/DRYER DISASSEMBLY
FLSE72GCS6 this model number is showin as a complete laundry center, not 2 seperate peices. in which casse there is no seperating them
Posted on Dec 09, 2008
  • 113 Answers
SOURCE: Whirlpool stackable washer/dryer. Dryer squealing
Could be the idler pulley, or the dryer seals.
Posted on Dec 16, 2008
  • 1382 Answers
SOURCE: bosch washer dryer WVT2850GB error code E06
Remove the rectangular fascia at the bottom front of the machine - on my model you only need a coin to turn the two plastic screws. Unclip the black rubber drain pipe, remove the plug from the end and drain the water into a bowl (or several bowls).
Then undo the round plug at the bottom left of the machine (more water will come out) which will give you access to the extractor pump. Check that there are no obstructions in there and that the small propeller in there can turn freely.
If there is no obstruction there then we move onto the next steps.
If you can figure out how to remove the front of the machine then you will find this part easier
First, TURN OFF THE POWER. Then, on the front of the machine, on the bottom left, undo the screws that fasten the extractor pump onto the front of the machine. Then pull the machine out from the wall so that you can get to the back of it. Remove the back of the machine by taking out the ten or so screws.
Looking in from the back: At the bottom-front-right of the machine you will see the extractor pump. It will have two hoses attached to it - a fat one and a slightly thinner one. Reach into the bottom of the machine and remove the power plug from the back of the extractor pump. Then, using a pair of pliers (or something similar) to open the spring clip, remove the thinner of the two hoses (the drain hose) from the pump unit. This can be fiddly - especially if you're doing it from the back of the machine.
Pull the hose out of the machine and check it for obstructions. If there are no obstructions in there then move onto the next step.
Reach back into the machine and, again using the pliers, remove the fatter tube from the pump. Remove the pump from the machine and check it for obstructions in the entry and exit holes, and also make sure that the propeller isn't obstructed. Then shake and squeeze the fatter tube to see if there is an obstruction in there
Best of luck.
Posted on Mar 30, 2010
Maytag Epic Z Washing Machine shuts down during spin, can I fix it myself?
Hello Brain;
My name is Peter. I am a retired field service appliance technician.
Error codes are generalized. Both of your codes are drain relative. They will tell you to clean your drain, but there is more to it than that.
You may have a bad drain water level switch, a plugged drain line....
Please send me your model number, So I can see what your have.
Peter Goodwin
Glen Burnie, MD
Jan 13, 2015 | Maytag Epic Z and Performance Series 2000...
Error code 9E What does that mean? Cannot find tech sheet
9E code is a door switch circuit problem.
You can check the wiring and connections and the door switch.
If the problem is not isolated to one or more of these parts then the control board is malfunctioning and must be replaced.
The manual states "unplug the dryer for 1 minute" "reconnect and if the problem re-occurs to check the components.
Maytag has a special circuit board that can be plugged in to evaluate the existing circuit board. Only Maytag certified techs have these test boards, and not all of them have it.
Check your door switch and wires.
The door switch is a inexpensive part compared to the cost of the circuit board. If in doubt, replace the door switch before proceeding.
Door switch part # y305753 and cost about $20.00
Mar 20, 2009 | Maytag Dryers
What does the error code e9 mean on a maytag washer and dryer?
Maytag dryer 9E which is "Door Switch Failure"
Aug 16, 2008 | Maytag Dryers
Neptune stackable washer...
You put the detergent directly on top of the clothes.
Jul 31, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag stackable LSE7806ACE - dryer wont run...washer is fine..
I had the same problem, take the easy rout first and check for obstructions in your venting. Mine was clogged and it shut itself down (to protect itself?)
Jul 06, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag Washer/Dryer stackable
well i am having about the same problem, but mine won't even fill, the dryer works but the washer won't fill or turn on at all. my husband had it all apart, too the control assembly to parts place and they said that hardly ever goes bad so it is still sitting unusable with no answer or money to spend on it in site.
Jan 15, 2008 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
407 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
