Question about Philips GoGear SA261 MP3 Player
My philips gogear 2mb. has stopped working.It will not turn on, and when I plug it into the computer, it does nothing.Usually when I plug it in it says "Ok to disconnect." Does anyone have a solution for my problem?? thanks!!
  • Anonymous Apr 09, 2009
    my player does not work, too. if i want to turn it on it does nothing and if i connect it with the pc it does not anything! what could i do?
  • Anonymous May 05, 2009
    my gogear cannot play songs
  • 101 Answers
Had the same problem, solved it by pressing the reset button (on the bootom of device) with a pin good luck from mr 02
Posted on Jun 18, 2009
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
My volume button broke
1 Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip, if you're device isn't working properly or there's a frozen display. Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off. If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
2 Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager." This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button. Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode. Click the "Repair" button when it appears on your computer, then follow the steps to fully recover the GoGear. Properly disconnect your GoGear from your computer and restart the device.
3 Recharge your device if your GoGear dies suddenly while playing. Connect the GoGear to your computer via the supplied USB cord. Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on. This will begin the charging process of your GoGear. If recharging doesn't work, the battery may need to be replaced. Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
Apr 17, 2012 | Philips GoGear ViBE Digital Media Player
I was charging my media player and now it is stuck in charge mode?
Hi,Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip, if you're device isn't working properly or there's a frozen display. Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off. If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Good luck.
Mar 11, 2011 | Philips GoGear ViBE Digital Media Player
My 16 gb gogear froze
1 On your computer, select Start >
Programs > Philips Digital Audio Player
> Aria Device Manager > Philips Device
Manager to launch the Philips Device
Manager.
2 Turn off GoGear Aria before you
continue.
3 Press and hold the volume button
while you connect GoGear Aria to your
computer.
4 Keep holding the key until the Philips
Device Manager acknowledges GoGear
Aria and enters the recovery mode.
5 On the computer, click the Repair
button and follow the instructions of the
Philips Device Manager to complete the
recovery process.
6 When the recovery is completed,
disconnect GoGear Aria from your
computer.
7 Restart GoGear Aria.
The full manual is found here: http://www.p4c.philips.com/files/s/sa1ara16k_17/sa1ara16k_17_dfu_aen.pdf
Oct 29, 2009 | Audio Players & Recorders
Philips gogear mp3 isnt working anymore
you probaly have an old comnputer and your mp3 player could have water damage. When you plug it in does it say you have to format it if you do then you have to get a better version of your computer.
Sep 05, 2009 | Philips GoGear SA178 MP3 Player
My philips gogear wont turn on
Disconnect the GoGear from the computer
Reset it first (pinhole in back - safety pins work best), even if nothing happens - just to be on the safe side
Nothing will happen still, but we are OK
Make sure the power is off, and hold in the volume + button, reconnect the GoGear to the computer while holding in the volume + button, and continue holding volume + until a window pops us saying Found New Hardware Wizard
Go through the Found New Hardware Wizard, and the GoGear should be working again - the player will be revived
Write me back if this fails to resolve the problem.
-Tha Mp3 Doctor
Jun 17, 2008 | Philips GoGear HDD6330 MP3 Player
Philips gogear
Windows XP has a native driver that will work - if your computer is not recognizing the device, then unplug the GoGear from computer, turn your GoGear off, and hold in the volume+ button. Reconnect the GoGear to your computer while still holding the volume+ button. After 5-50 seconds, Windows should say Found Hardware Wizard and will load/reload the needed drivers.
Otherwise, you may have to reinstall the installation CD (does not work with Vista) - it has a key component called Philips Device Plug-In which needs to be reloaded.
Mar 26, 2008 | Philips GoGear HDD6330 MP3 Player
Nothing happens when I plug it in.
This solution does not work. my device will NOT turn on, hence the Device Manager does not recognize the device, hence you can not do a device repair.
Dec 07, 2007 | Philips HDD082 MP3 Player
PROBLEMS!!!
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Mar 06, 2007 | Philips GoGear HDD1850 MP3 Player
Philips GoGear SA261 MP3 Player Logo
895 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
