Question about LG DLE2532W Electric Dryer
Lg Gas dryer Dlg0332w drum making noise
Dryer works fine it is just making a noise out of the back of the dryer. what could it be?
The drum on my DLG0332W was also making noise at the back of the dryer...kind of a thump thump thump as the drum rotated. My dryer is only 4 years old. I got brave, downloaded the service manual and opened up the dryer. I found that the drum's welded seam was starting to separate where the roller wheels were coming into contact with the drum at the back of the dryer. Looks like a new drum is in order.
Posted on Jul 25, 2009
LG DRYER DLG0332W GAS
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101[[]
Aug 05, 2011 | LG DLE0332 Gas Dryer
I have an LG DLG0332W gas dryer and it not getting hot. Read that the thermostat my need to be reset. have the dryer torn apart and I am having trouble locating the thermostat reset button. Where is it?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 30, 2010 | Dryers
LG gas dryer DLG0452W drum makes a clicking noise
one of the dry drum baffle screw might be lose are there might be something caught inbetween the dry drum front seal are rear
Apr 24, 2010 | LG DLG0452W Gas Dryer
Our LG Dryer DLG0332W is about 5 years old and now I have to manually turn the barrel around to get the dryer to start; otherwise when you hit the start button it just buzzes and doesn't start. What do...
the dryer has Defective Drum Glides/Rollers.
The dryer drum rests and spins on a set of rollers and/or drum glides. The glides and rollers provide low friction contact points that allow the drum to turn easily. When the glides and rollers become worn they can cause the drum to drag. The dryer might only spin without a load or only when assisted.
Hope this helps.
Aug 07, 2009 | LG Dryers
I have a thumping noise as the dryer runs, but it seems to work fine.
Look closely at the seam of the dryer drum, at the very front and the very back. I suspect that the seam has developed a crack, and makes a thumping noise each time the crack passes over the drum support rollers. You will have to replace the drum to eliminate the problem
Jun 28, 2009 | LG DLE5977 Electric Dryer
Did you resolve your dryer / noise?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
7687t
Apr 14, 2009 | LG DLG5932W Gas Dryer
Clunking noise
The clunking noise may be a broken weld on the drum.  Every time it turns and passes through the guide wheel supports, it makes a thunk thunk noise.  You will need to have a qualified LG technician diagnose the problem correctly but that's what it sounds like.
Jun 07, 2008 | LG DLG5988 Stainless Steel Gas Dryer
Noise from dryer
drum has worn drum bearing dryer top AND rear panel must be removed to acess the rear of drum to replace drum
Sep 24, 2007 | Zanussi TC7102W Electric Dryer
LG DLE2532W Electric Dryer Logo
714 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
