Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
'9E' error message on Model SE9900 Stackable Maytag Washer/Dryer
Washer/ Dryer shuts down periodically (more frequently of late) and control panel is dead (cannot activate anything) except for the '9E' error. Only way to reactivate is to pull the fuses in the house's main fuse box and re-insert. Note, the fuses do NOT blow. Occasionally, even pulling and reinserting fuses does nothing and control panel remains completely dead. After leaving the system inactive for a while and retrying over and over again, it eventually restarts. We have varied the load sizes and run washer and dryer separately, but problem keeps recurring on a periodic basis. I've cleaned the inner workings of the washer/dryer to ensure no dirt/dust accummulation is interfering with anything. Not sure if it's time for a service call?
jsrock516
  • 5911 Answers
SOURCE: seperate washer and dryer
Unfortunately, your washer and dryer are part of a "laundry center". Which means, the two together are one system. They cannot be separated. You can still use the dryer, obviously. Have you considered fixing the washer?
Posted on Jun 22, 2007
Illeagle
  • 525 Answers
SOURCE: dead Maytag washer
You will need to replace the lid switch assembly, not just the fuse. Below is a link that will go directly to an enlarged image of what you need, along with ordering and shipping information.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1468&PPStack=1
Note: Lid switch adjustment may be required when installing new kit. If instructions do not come supplied with the kit, post me back and I will try to guide you through it.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 18, 2008
  • 61 Answers
SOURCE: stackable maytag washer and dryer
Hello, on most Maytag units you can take the the front panel off by removing 2 phillips screws , 1 on each side of the front panel. With the panel off you can run the machine and see where the water is coming from. Good luck
Posted on Dec 26, 2008
jumptrout51
  • 3361 Answers
SOURCE: Maytag washer blows 1.5A fuse in back of the top compartment where the dial etc is
There is a micro switch next to the fuse. It is shorted out. Replace the micro switch and solve your problem.
Posted on May 20, 2009
  • 333 Answers
SOURCE: We have a Maytag Neptune stackable washer and
yes
Posted on May 16, 2010
I have a maytag stackable washer/dryer and I need to change the water temperature switch. Does anyone know how to go about doing this? I already have the part.
you will need to remove the front panel screws which will allow you to remove the end caps off the front panel after removing the control knobs,then you can replace the temp switch by removing the screws off the controls main body
Mar 07, 2010 | Maytag LSE7806A Top Load Stacked...
Model SE9900 Maytag Stackable Washer/Dryer - 9E Error
According to my data, a 9E error indicates door latch malfunction.
Apr 21, 2017 | Maytag Washing Machines
Stops mid cycle, won't spin
You need to check and see if the door-lock light is on ,if not then you have either a faulty door lock mech. or a defective solid state board in the control panel
Dec 27, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Neptune stackable washer...
You put the detergent directly on top of the clothes.
Jul 31, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag stackable LSE7806ACE - dryer wont run...washer is fine..
I had the same problem, take the easy rout first and check for obstructions in your venting. Mine was clogged and it shut itself down (to protect itself?)
Jul 06, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag Washer/Dryer stackable
well i am having about the same problem, but mine won't even fill, the dryer works but the washer won't fill or turn on at all. my husband had it all apart, too the control assembly to parts place and they said that hardly ever goes bad so it is still sitting unusable with no answer or money to spend on it in site.
Jan 15, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
343 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
