Question about HP JBL Platinum Computer Speakers
I have the volume on high; the only sound i hear is a static now and then. I have not changed a thing. Speakers are JBL's external computer speakers.
  • mandycummins Mar 10, 2009
    my speakers will play sounds off music players like real play but when on the web wont have any sounds off sites
  • 77 Answers
THERE IS VOLUME KEY ON SPEKAERS ADJUST TO LOW
Posted on Apr 07, 2009
There is no label for external speakers on the sound application for selection of external speakers.
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
hope this helps
May 22, 2011 | JBL (JBLONTOUR) Computer Speakers
I can not increase or decrease volume on my JBL encounter speaker system
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
hope this helps
Apr 11, 2011 | JBL Encounter 2.1 Computer Speakers
I have Jbl speakers plugged into the computer. When i turn them on, i get no sound at all. When i try to go find them, the computer says that i do not have any system speakers.
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps don
Mar 10, 2011 | JBL Audio Players & Recorders
My jbl platinum speakers doesnt work again.may i get the driver pleaseeee....
also
hope this helps
don
Mar 03, 2011 | HP Compaq JBL Pro (401508-001) Computer...
No sound from speakers
Probably.
Do they connect to the computer via USB or mini plug?
If mini plug, make sure you have the right jack on the back of the computer (there's two)
Then go into System Preferences ... select "Sound" and see if you can select something other than "Internal Speakers" - the computer may just not be aware that you want to use the external speakers ...
Are the speakers powered? Is there a volume control on the subwoofer, or an external fob with a volume control on it? You probably know this if you used them previously with your Compaq computer ...
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.rexark.com
Jan 11, 2010 | HP JBL Platinum Computer Speakers
Lights are on in the small speakers but no sound is produced...there is a short scratchy sound when I juggle the speker wire from sub woofer. I hooked speakers up to a different MAC and now am trying to...
Hi there , the green light just means its getting Power, it doesnt mean that its going to give sound, It could be that you dont have Drivers installed for your Sound card which is causing it too not get sound , but when it makes that static noise , its the Wire just causing Static with the Sub , just means its getting power , The + and - sign is the volume control ...Try see if you can turn it louder with the + . maybe it is low enough not too hear.....Hope this helped Bud
Happy new year.
Jan 03, 2010 | JBL CREATURE II Computer Speakers
New speakers won't work with my computer
verify whit hear phones if is correct audio the problem is not in the computer...also check instalation driver sound is sound max for your computer
Sep 16, 2009 | Dell Dimension 3100 PC Desktop
Static from speaker
Try playing around on the volume control panel. The pan might have been played with, along with other things.
Feb 21, 2009 | Creative Labs Sound Blaster Live! 5.1...
JBL CREATURE II Computer Sattelite Speakers Sound Problem
check on the speaker software were you can set master volumeetc. check for balance volume .
Oct 27, 2007 | JBL CREATURE II Computer Speakers
HP JBL Platinum Computer Speakers Logo
103 people viewed this question
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
rfredey
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
