Question about Marley PJ1257 Heater
Motor for bathroom exhaust fan
Looking for a replacement motor for a bathroom exhaust fan that also contains a heat lamp. It says UPPCO CHICAGO on it.
Same problem but l thing l solved it by ordering a new replacement from globalindustrial.com if you need more help email me at hugo698@aol.com
Posted on Mar 10, 2010
Exhaust Fan does not work
Motors are divided into many categories. Most bathroom fans use a shaded pole motor (having a transformer on one side, a laminated yoke and 2 circles of copper shorting around the laminations to create a north and south pole) Another type is a compound wound motor (having brushes) A third type is an induction motor. the rotor of the motor is a series of laminations where a magnetic frequency in the stator windings induce magnetism in the rotor and they repel each other. A squirrel cage capacitor start induction run has a large capacitor on the side.
You can not mix and match what you want from one motor style to another motor style. If you have a brush type motor, perhaps the commutator needs cleaning and the commutator could be shorted with metal filings. The brushes may have failed and needs replacing. The bearings may have seized and the windings heated up blowing the thermal cutoff just under the tape of the windings. The windings may have burned through the varnish that coats the wires on the start winding (on motors with a centrifugal switch only) Centrifugal switches can fail to open or close. Only someone knowledgeable with motors can tell you what you have and what the problem is. It is far cheaper to replace a motor with a similar one on inexpensive devices such as a bathroom fan. A new fan may be cheaper than getting a new motor.
Nov 13, 2013 | Dryers
When Exhaust button pressed, vent fans not working, but microwave running for 30 seconds.
test the components and fix it. God bless you
  1. Exhaust fan motorIf your exhaust fan motor is not running, there are a couple of things that you can check involving the motor to locate the problem. After removing the fan motor, you can manually attempt to turn the fan blades with your hand. If the fan motor is working properly, the blades should spin effortlessly. If this does not occur and the blades are taught, the motor will need to be replaced. Secondly, the fan motor itself can burn out due to time and usage. Using an ohm meter, the exhaust fan motor should read open for continuity. If it does not, then the fan motor has expired and will need to be replaced.
  2. ThermostatAnother part that could cause the microwave exhaust fan to not work is a faulty thermostat. A thermostat gauges the air temperature, which activates the exhaust fan when required. If this part becomes flawed, the exhaust fan will not energize and the thermostat will need to be replaced.
  3. Main control boardIf your exhaust fan is still not working and the microwave fan motor, wiring, and thermostat are operating accurately, the root cause could be with the main control board. Replace the main control board.
Oct 24, 2013 | Frigidaire Microwave Ovens
My bathroom exhaust fan has a dial timer. Sometimes lately the fan does not come on for a couple of minutes after starting the dial timer. Is that likely to be a problem with the dial timer, or with the...
This could be the timer or the motor. The timer could be going out or not starting up in the right position. Has anyone worked or removed the timer knob, it could have been put on just a little off causing the switch to be off just a bit. Again the motor could be going out,such as the bearings inside. I would see what type of warranty is on this fan. I know these exhaust fans can get a little pricey, so I would see what warranty options I have.
Mar 06, 2011 | Broan-NuTone Fan,Bathroom Exhaust Broan...
Replacement Motor for Bathroom Exhaust Fan Need motor and blower assembly or just the motor for a Sears Roebuck Model 864.892 Motor is Universal Electric Co Model 118JF5 S/N 1T26714
Not sure what you are asking, but you can get a replacement directly from Sears. It is okay to replace just the motor, but be sure the fan blades are completely cleaned. When you are all done, verify good air flow outside of the building.
Sep 19, 2010 | Home
Problems with exhaust fan NuTone Model LS 100SE
The fan/motor part of the Broan fan is replaceable. They are actually very simple to take out and install a new part.
The part can be easily purchase here...
http://parts.broan-nutone.com/broan/Shop
Heatman101
Feb 27, 2010 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Bathroom exhaust fan 16 years old and noisy. How to fix?
One drop of 30 wt oil at each bearing will quiet the thing for a while, but you will eventually want to replace it. Also consider the whole fan is about the same cost as the motor, and easier to find.
May 16, 2009 | Broan-NuTone N-671R Exhaust Fan Exhaust...
NEED NEW MOTOR FOR KICTHEN RANGE HOOD BLOWER
hey I am looking for the same thing I think I found one at emotorstore.com it's a cframe motor #k120
Feb 02, 2009 | Marley PJ1257 Heater
Noisey 8 x8 Broan Bathroom Exhaust Fan (With Light) (7 years old)
Mine was doing the same thing. I found it was coated with dust.
I took the blower out [unplugged it, and removed the single screw holding it to the box], took the face plate off [removed 4 or five screws] brushed the squirrel-cage fan blades using a narrow, long and stiff bristled brush, and reassembled it [used care to align the small plastic axle on the flap valve ] and reinstalled it. The vibration was greatly lessened and the fan was about as quiet as it had ever been.
Dec 23, 2008 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
I have a marley elect wall heater the little motor is shot
These motors are now made by Century electric motor Co. -who bought A.O. Smith, who bought UPPCO motor company.
The parts can also be requested Marley EP still manufactures a similar heater
HOW TO ORDER REPAIR PARTS
In order to obtain any needed repair or replacement
parts, warranty service or technical information, please
contact Marley Engineered Products Service Center tollfree
by calling 1-800-642-HEAT.
When ordering repair parts, always give the information
listed as follows:
1. The Model Number
2. The Part Description
3. Date of Manufacture
Dec 11, 2008 | Marley PJ1257 Heater
Marley PJ1257 Heater Logo
1,172 people viewed this question
Top Marley Heating & Cooling Experts
paulcarew
Ron Durham
Are you a Marley Heating and Cooling Expert? Answer questions, earn points and help others
